<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Time format help me please]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/8419/mmm-sort">MMM-SORT</a><br />
Hello Mikle1 and well done for what you do, I live in France and I write with a translator, I installed your MMM-SORT module which is really great and I would like to know if it was possible to have the time format in 24 hours because I am not familiar with the AM PM format, thank you for your help and congratulations again</p>
]]></description><link>https://forum.magicmirror.builders/topic/12472/time-format-help-me-please</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 14:58:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12472.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Apr 2020 10:34:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 20:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85" aria-label="Profile: Manu85">@<bdi>Manu85</bdi></a> said in <a href="/post/71740">Time format help me please</a>:</p>
<p dir="auto">do you think you can add the tidal coefficient?</p>
<p dir="auto">The tidal coefficients are not present in the data from the api.</p>
<p dir="auto">Sample:</p>
<pre><code>Array(28)
date
"2020-04-03T14:52+0000"
dt
1585925563
height
-0.725
type
"Low"
__proto__
Object
date
"2020-04-03T20:42+0000"
dt
1585946563
height
0.575
type
"High"
__proto__
Object
date
"2020-04-04T03:07+0000"
dt
1585969622
height
-0.695
type
"Low"
__proto__
Object
date
"2020-04-04T09:06+0000"
dt
1585991195
height
0.813
type
"High"
__proto__
Object
date
"2020-04-04T15:45+0000"
dt
1586015158
height
-0.829
type
"Low"
__proto__
<p dir="auto">I think that if you do that you will have a lot of success with this module</p>
<p dir="auto">It took me a few minutes to recover from this. hahaha</p>
<p dir="auto">Please mark the post that solved your first request as solved.</p>
<p dir="auto">Also, this page has a tide coefficient table for the entire year of 2020<br />
<a href="https://tides4fishing.com/tides/tidal-coefficient" target="_blank" rel="noopener noreferrer nofollow ugc">https://tides4fishing.com/tides/tidal-coefficient</a></p>
]]></description><link>https://forum.magicmirror.builders/post/71798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71798</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 03 Apr 2020 20:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 12:32:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you very much for that info :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/71749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71749</guid><dc:creator><![CDATA[Manu85]]></dc:creator><pubDate>Fri, 03 Apr 2020 12:32:36 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 11:56:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85" aria-label="Profile: Manu85">@<bdi>Manu85</bdi></a> if you use the @ in front of the users name, the system will send them a notification</p>
]]></description><link>https://forum.magicmirror.builders/post/71745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71745</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 11:56:56 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 11:47:54 GMT]]></title><description><![CDATA[<p dir="auto">oh excuse me it’s not Mikle1 but Mykle1, sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/71744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71744</guid><dc:creator><![CDATA[Manu85]]></dc:creator><pubDate>Fri, 03 Apr 2020 11:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 10:31:10 GMT]]></title><description><![CDATA[<p dir="auto">hi Mikle1, do you think you can add the tidal coefficient? I think it would be a real advantage, I live on the west coast of France and here most of the inhabitants have boats, as it is the Atlantic Ocean to be able to go out at sea you have to know the coefficients, I think that if you do that you will have a lot of success with this module :-) while waiting bravo for everything<br />
cordially</p>
]]></description><link>https://forum.magicmirror.builders/post/71740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71740</guid><dc:creator><![CDATA[Manu85]]></dc:creator><pubDate>Fri, 03 Apr 2020 10:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 08:16:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello Mikle1, you are really AWESOME, Thanks for your help, have a nice day</p>
]]></description><link>https://forum.magicmirror.builders/post/71735</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71735</guid><dc:creator><![CDATA[Manu85]]></dc:creator><pubDate>Fri, 03 Apr 2020 08:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 01:52:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85" aria-label="Profile: Manu85">@<bdi>Manu85</bdi></a></p>
<p dir="auto">Is this what you had in mind?</p>
<img src="https://www.dropbox.com/s/64gliheub7ztepi/SORT.png?raw=1" />
<p dir="auto">Run <code>git pull</code> in the MMM-SORT directory to get the updated files</p>
<p dir="auto">Add <code>timeFormat: " HH:mm",</code> to your config entry for MMM-SORT</p>
]]></description><link>https://forum.magicmirror.builders/post/71723</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71723</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 03 Apr 2020 01:52:14 GMT</pubDate></item><item><title><![CDATA[Reply to Time format help me please on Fri, 03 Apr 2020 00:36:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85" aria-label="Profile: Manu85">@<bdi>Manu85</bdi></a></p>
<p dir="auto">Je vous remercie pour vos aimables paroles. J’habite à NYC-USA et je vous réponds en utilisant un traducteur. Je pense que je peux le faire. Je vous répondrai dans un jour ou deux. Assez bien?</p>
<p dir="auto">Thank you for your kind words. I live in NYC-USA and I am answering you using a translator. I think I can do that. I will get back to you in a day or two. Good enough?</p>
]]></description><link>https://forum.magicmirror.builders/post/71716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71716</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 03 Apr 2020 00:36:53 GMT</pubDate></item></channel></rss>
