<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A strange mistake ...]]></title><description><![CDATA[<p dir="auto">Hello everybody.<br />
I am a beginner and when I launch MM on the terminal this message appears:</p>
<pre><code>[10:58:22.082] [ERROR]  (node:3529) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
[10:58:22.083] [ERROR]  (node:3529) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
<p dir="auto">What does it mean?</p>
<p dir="auto">Thank you all!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12479/a-strange-mistake</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 06:39:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12479.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2020 09:16:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A strange mistake ... on Fri, 03 Apr 2020 11:28:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> nothing for you…</p>
<p dir="auto">a piece of code uses a library method that is going away some time in the future and its a warning…</p>
]]></description><link>https://forum.magicmirror.builders/post/71742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71742</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 11:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to A strange mistake ... on Fri, 03 Apr 2020 12:15:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/71742">A strange mistake ...</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/post/71747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71747</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Fri, 03 Apr 2020 12:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to A strange mistake ... on Fri, 03 Apr 2020 11:28:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> nothing for you…</p>
]]></description><link>https://forum.magicmirror.builders/post/71742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71742</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 11:28:58 GMT</pubDate></item></channel></rss>
