<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[clone image raspberry]]></title><description><![CDATA[<p dir="auto">Hello everybody,</p>
<p dir="auto">i’m looking for to clone my image of raspberry pi directly on my pc without take off my card from the raspberry…<br />
Is it possible via my vnc or winscp application to clone ?<br />
thanks and be careful with virus</p>
]]></description><link>https://forum.magicmirror.builders/topic/12484/clone-image-raspberry</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 18:25:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12484.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2020 14:55:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 18:32:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> yes, just erase the node_modules folders in each place, base and modules, and then redo npm installs each place…</p>
]]></description><link>https://forum.magicmirror.builders/post/71777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71777</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 18:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 18:18:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i have copied MagicMirror on my pc after load the new version… if i have a pb with my sd card, i clone with an old image containing an old MagicMirror. If i change the old by the new, the version will be ok ?</p>
]]></description><link>https://forum.magicmirror.builders/post/71776</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71776</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 03 Apr 2020 18:18:16 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 18:03:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> you can use scp commandline to copy file(s) from there to here.</p>
<p dir="auto">syntax</p>
<p dir="auto">scp options user@ip:path_to_file(s) path_to_save_files_here</p>
<p dir="auto">for example</p>
<p dir="auto">scp -r user@ip:~/MagicMirror  ~/save_folder/MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/71775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71775</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 18:03:46 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 17:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
i do this with winscp. I need just  to upgrade after a flash. you’re right but i wanted to know for my  experience if there is a simple way to copy sd card to my pc, like a script</p>
]]></description><link>https://forum.magicmirror.builders/post/71774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71774</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 03 Apr 2020 17:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 17:45:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> - Rather than clone the entire image, why not just zip up the MagicMirror folder? Or possibly just the <code>config</code> and <code>modules</code> folders. That way you’re not saving all the standard Raspbian files.</p>
<p dir="auto">If you ever need to restore from backup, you can just re-flash Raspbian onto the SD card, run your OS updates, run the Magic Mirror installer and then unpack your config and modules folders. Run the <code>npm install</code> in the particular folders and you should be good to go.</p>
]]></description><link>https://forum.magicmirror.builders/post/71771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71771</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 03 Apr 2020 17:45:20 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 15:02:12 GMT]]></title><description><![CDATA[<p dir="auto">yes…if i have a pb a day. I do a backup each big changes config or css or upload</p>
]]></description><link>https://forum.magicmirror.builders/post/71762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71762</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 03 Apr 2020 15:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to clone image raspberry on Fri, 03 Apr 2020 14:59:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> r u trying to backup?</p>
]]></description><link>https://forum.magicmirror.builders/post/71761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71761</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 14:59:43 GMT</pubDate></item></channel></rss>
