<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Has anyone got MMM-Remote-Control working on MM 2.11 ?]]></title><description><![CDATA[<p dir="auto">I updated to MM 2.11and the MMM-Remote-Control module quit working. I have tried checking settings, totally removing the module and reinstalling. I have not been successful in getting it to work.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 14:56:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12485.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2020 16:22:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Thu, 08 Oct 2020 16:37:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Looks like I have got it.<br />
I just had to remove the 8080 out of <code>http://192.168.xxx.xxx:8080/remote.html </code></p>
<p dir="auto">Sorry for that.<br />
Thanks for helping me.</p>
]]></description><link>https://forum.magicmirror.builders/post/83029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83029</guid><dc:creator><![CDATA[MrCoffee]]></dc:creator><pubDate>Thu, 08 Oct 2020 16:37:00 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Thu, 08 Oct 2020 15:05:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Thank you. I did not know these commands.<br />
But unfortunately I have got the latest MM-Release.<br />
So I farther have to search for the error.</p>
]]></description><link>https://forum.magicmirror.builders/post/83024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83024</guid><dc:creator><![CDATA[MrCoffee]]></dc:creator><pubDate>Thu, 08 Oct 2020 15:05:57 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 07 Oct 2020 20:44:08 GMT]]></title><description><![CDATA[<p dir="auto">may your image is to old. You can execute <code>docker images</code> and see how old your images are. You can get a new version with <code>docker pull xy</code> (replace xy with the image name).</p>
]]></description><link>https://forum.magicmirror.builders/post/83006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83006</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 07 Oct 2020 20:44:08 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 07 Oct 2020 19:43:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Oh. Sorry for that.<br />
But thank you for your answer.</p>
<p dir="auto">However I thougt I had the same issues.<br />
Ok. I will give it another try and in case I can’t fix it, i will open a new thread.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/82992</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82992</guid><dc:creator><![CDATA[MrCoffee]]></dc:creator><pubDate>Wed, 07 Oct 2020 19:43:23 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 07 Oct 2020 19:21:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrcoffee" aria-label="Profile: MrCoffee">@<bdi>MrCoffee</bdi></a></p>
<p dir="auto">sorry, don’t understand your question.</p>
<p dir="auto">This thread is about a problem with MMM-RemoteControl with MM v2.11.</p>
<p dir="auto">If you use the mentioned docker setup this should have MM v2.13 where the problem is solved.</p>
]]></description><link>https://forum.magicmirror.builders/post/82990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82990</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 07 Oct 2020 19:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 07 Oct 2020 18:42:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
Sorry for asking, but I am pretty new to docker.<br />
I installed my MagicMirror using <a href="https://github.com/bastilimbach/docker-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">docker-MagicMirror</a>.<br />
There I don´t have the <code>~/magicmirror/run</code> folder.</p>
<p dir="auto">Could you please help me out, where I have to look?</p>
<p dir="auto">Thanks.<br />
Mr.Coffee</p>
]]></description><link>https://forum.magicmirror.builders/post/82988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82988</guid><dc:creator><![CDATA[MrCoffee]]></dc:creator><pubDate>Wed, 07 Oct 2020 18:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 17 Jun 2020 21:10:00 GMT]]></title><description><![CDATA[<p dir="auto">There is a fix for this provided as PR <a href="https://github.com/Jopyth/MMM-Remote-Control/pull/141" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> but still not merged. But you can apply the fix yourself.</p>
]]></description><link>https://forum.magicmirror.builders/post/77237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77237</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 17 Jun 2020 21:10:00 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 17 Jun 2020 07:19:24 GMT]]></title><description><![CDATA[<p dir="auto">I did the fix in the socketclient.js file. but here are two issues that i am still facing. Anyone knows, how to fix them?</p>
<ol>
<li>The icons aren’t still visible, like it was in earlier versions.</li>
<li>The top buttons just showing “All” and not “Show all” or “Hide All”.</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/77202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77202</guid><dc:creator><![CDATA[qqqqqqqq]]></dc:creator><pubDate>Wed, 17 Jun 2020 07:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Tue, 02 Jun 2020 06:09:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunnr1469" aria-label="Profile: RoadRunnr1469">@<bdi>RoadRunnr1469</bdi></a></p>
<p dir="auto">This fixed the issue I was having with Remote Control</p>
<p dir="auto">issue I was having was when logging into remote control, it would display all modules as ‘unavailable’ and would be in a constant loading… loop when trying to turn on/off modules.</p>
<p dir="auto">Now its running as expected.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/76369</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76369</guid><dc:creator><![CDATA[zeeboguy]]></dc:creator><pubDate>Tue, 02 Jun 2020 06:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 22:56:25 GMT]]></title><description><![CDATA[<p dir="auto">what I told you in my last reply was the solution to use the <code>develop</code> image.</p>
<p dir="auto">Now I tried to write down the other solution (how to patch a mm-file in a docker setup) <a href="https://gitlab.com/khassel/magicmirror/-/wikis/How-to-patch-a-file-of-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/75599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75599</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 20 May 2020 22:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 20:04:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> said in <a href="/post/75588">Has anyone got MMM-Remote-Control working on MM 2.11 ?</a>:</p>
<p dir="auto">~/magicmirror/ru</p>
<p dir="auto">THANK YOU!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/75589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75589</guid><dc:creator><![CDATA[snikolaidis]]></dc:creator><pubDate>Wed, 20 May 2020 20:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:57:20 GMT]]></title><description><![CDATA[<p dir="auto">then goto <code>~/magicmirror/run</code> and edit the <code>docker-compose.yml</code> with an editor (e.g. nano or vi).</p>
<p dir="auto">In this file replace <code>karsten13/magicmirror:latest</code> with <code>karsten13/magicmirror:develop</code>, save the file.</p>
<p dir="auto">You are still in <code>~/magicmirror/run</code>, then run <code>docker-compose up -d</code>.</p>
<p dir="auto">It will take a while because this will pull a new docker image.</p>
<p dir="auto">After the app is up again, the problem should be fixed.</p>
]]></description><link>https://forum.magicmirror.builders/post/75588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75588</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 20 May 2020 19:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:52:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> I am a complete novice to it, but I will figure out a way, thank you so much for pointing me in the correct path!</p>
]]></description><link>https://forum.magicmirror.builders/post/75587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75587</guid><dc:creator><![CDATA[snikolaidis]]></dc:creator><pubDate>Wed, 20 May 2020 19:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:51:11 GMT]]></title><description><![CDATA[<p dir="auto">then you will not find the socketclient.js on your pi because this file is in the used docker image.<br />
2 possibilities:</p>
<ul>
<li>you have to mount a fixed version of this file into the running container with a volume mount</li>
<li>you can use the <code>develop</code> version of the docker image which contains the current <code>develop</code> branch of mm where this is already fixed (this is the current base of the upcoming MM v2.12)</li>
</ul>
<p dir="auto">Don’t know how experienced you are in docker, 2. option is easier to explain.</p>
]]></description><link>https://forum.magicmirror.builders/post/75586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75586</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 20 May 2020 19:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:44:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> yes I am</p>
]]></description><link>https://forum.magicmirror.builders/post/75585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75585</guid><dc:creator><![CDATA[snikolaidis]]></dc:creator><pubDate>Wed, 20 May 2020 19:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:43:47 GMT]]></title><description><![CDATA[<p dir="auto">you are using <a href="https://github.com/guysoft/MagicMirrorOS" target="_blank" rel="noopener noreferrer nofollow ugc">this setup</a>?</p>
]]></description><link>https://forum.magicmirror.builders/post/75584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75584</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 20 May 2020 19:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Wed, 20 May 2020 19:31:53 GMT]]></title><description><![CDATA[<p dir="auto">what if cat ./js/socketclient.js says the file doesn’t exist? Would it be located somewhere else for the MagicMirrorOS?</p>
]]></description><link>https://forum.magicmirror.builders/post/75582</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75582</guid><dc:creator><![CDATA[snikolaidis]]></dc:creator><pubDate>Wed, 20 May 2020 19:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 20:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> put his fix on the js/socketclient.js</p>
]]></description><link>https://forum.magicmirror.builders/post/71797</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71797</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 20:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 20:01:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunnr1469" aria-label="Profile: RoadRunnr1469">@<bdi>RoadRunnr1469</bdi></a> so…After restart MM …Remote Control is not working anymore :worried_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/71794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71794</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Fri, 03 Apr 2020 20:01:06 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 19:52:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> actually no I didn’t. I had backed up my entire MagicMirror folder and all sub folders before upgrading. I saw another post where they said they changed the socketclient back to before upgrade. so I did the same thing. after making a backup of the new socketclient.js file.</p>
]]></description><link>https://forum.magicmirror.builders/post/71793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71793</guid><dc:creator><![CDATA[RoadRunnr1469]]></dc:creator><pubDate>Fri, 03 Apr 2020 19:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 19:47:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunnr1469" aria-label="Profile: RoadRunnr1469">@<bdi>RoadRunnr1469</bdi></a></p>
<p dir="auto">didn’t ask you, because I know your socketclient.js, you applied my patch …</p>
]]></description><link>https://forum.magicmirror.builders/post/71792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71792</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Fri, 03 Apr 2020 19:47:36 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 19:50:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a></p>
<pre><code>var MMSocket = function(moduleName) {
	var self = this;
	if (typeof moduleName !== "string") {
		throw new Error("Please set the module name for the MMSocket.");
	self.moduleName = moduleName;
	// Private Methods
	self.socket = io("/" + self.moduleName);
	var notificationCallback = function() {};
	var onevent = self.socket.onevent;
	self.socket.onevent = function(packet) {
		var args = packet.data || [];
		onevent.call(this, packet);    // original call
		packet.data = ["*"].concat(args);
		onevent.call(this, packet);      // additional call to catch-all
	// register catch all.
	self.socket.on("*", function(notification, payload) {
		if (notification !== "*") {
			notificationCallback(notification, payload);
	// Public Methods
	this.setNotificationCallback = function(callback) {
		notificationCallback = callback;
	this.sendNotification = function(notification, payload) {
		if (typeof payload === "undefined") {
			payload = {};
		self.socket.emit(notification, payload);
]]></description><link>https://forum.magicmirror.builders/post/71791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71791</guid><dc:creator><![CDATA[RoadRunnr1469]]></dc:creator><pubDate>Fri, 03 Apr 2020 19:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 19:32:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a></p>
<p dir="auto">may you can post the content of your <code>./js/socketclient.js</code>?<br />
So please go into the magicmirror folder and execute <code>cat ./js/socketclient.js</code> and post the output here. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/71789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71789</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Fri, 03 Apr 2020 19:32:17 GMT</pubDate></item><item><title><![CDATA[Reply to Has anyone got MMM-Remote-Control working on MM 2.11 ? on Fri, 03 Apr 2020 19:23:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roadrunnr1469" aria-label="Profile: RoadRunnr1469">@<bdi>RoadRunnr1469</bdi></a> said in <a href="/post/71785">Has anyone got MMM-Remote-Control working on MM 2.11 ?</a>:</p>
<p dir="auto">I can’t seem to get the upload screenshot to work, but yes I see all my modules.</p>
<p dir="auto">posting images is broken</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/issues/1969" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/1969</a></p>
]]></description><link>https://forum.magicmirror.builders/post/71788</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71788</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Apr 2020 19:23:26 GMT</pubDate></item></channel></rss>
