<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM on Ubuntu]]></title><description><![CDATA[<p dir="auto">So, I have an old laptop that I will use to a smart mirror.<br />
I installed MM via Snap Store<br />
How can edit that config files now to be personalized to my country?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12487/mm-on-ubuntu</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 14:09:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12487.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2020 22:56:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 18:22:11 GMT]]></title><description><![CDATA[<p dir="auto">Right.  I’ll watch more carefully for any error messages I receive from Ubuntu.  Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/73685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73685</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:22:11 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 18:19:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> said in <a href="/post/73678">MM on Ubuntu</a>:</p>
<p dir="auto">calendar, radar, traffic, weather</p>
<p dir="auto">all of those need internet access… so its possible…<br />
many modules do not handle lack of connection properly</p>
]]></description><link>https://forum.magicmirror.builders/post/73684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:19:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 18:18:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I just restarted my Ubuntu MiniPC 3 times after minimizing the MM2 window and MM2 started up perfectly each time.  If it starts to act up again I’ll install the MMM-Logging module.  When the problem was more evident the other day Ubuntu was displaying an error message that indicated it had some kind of issue with my WiFi and a “localhost”.  I was focused on other things at the time and didn’t pay enough attention to this error message.  I’ve not been receiving it lately so maybe something got resolved between my Ubuntu and my WiFi connection that also took care of this startup issue with MM2???</p>
]]></description><link>https://forum.magicmirror.builders/post/73682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73682</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:18:00 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 18:02:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> weird…</p>
<p dir="auto">install this module , and add it to config.js as the 1st in the module list<br />
<a href="https://github.com/sdetweil/MMM-Logging" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-Logging</a></p>
<pre><code>		{
            module: 'MMM-Logging',
            disabled: false,
                // Module functions out of the box with nothing set here.
                // See below for configurable options.
                echoLocal: true,
                echoRemote: true,
                overwriteBrowserMethods: true,
                format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
<p dir="auto">stop MM via pm2,<br />
pm2 stop 0<br />
pm2 flush<br />
pm2 start 0</p>
<p dir="auto">then reboot (this is where it comes up partway, right)</p>
]]></description><link>https://forum.magicmirror.builders/post/73679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73679</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 18:02:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 17:58:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’m using the MiniPC solely for the MM2.  The MiniPC is mounted to the back of an old wall-mounted LCD monitor and serves, basically, as an information kiosk for me running clock, calendar, radar, traffic, weather and to-do list modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/73678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73678</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 27 Apr 2020 17:58:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 17:52:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> hm… my desktop is ubuntu 18.04, w MM running… on second display</p>
]]></description><link>https://forum.magicmirror.builders/post/73676</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73676</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 17:52:43 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 17:32:49 GMT]]></title><description><![CDATA[<p dir="auto">This is on a MiniPC running Ubuntu 18.04.4.</p>
]]></description><link>https://forum.magicmirror.builders/post/73674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73674</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 27 Apr 2020 17:32:49 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 12:12:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> hm… what system is this on?  I have 9 instances running… never seen it behave that way… MM controls all the modules</p>
]]></description><link>https://forum.magicmirror.builders/post/73647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73647</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 12:12:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Mon, 27 Apr 2020 05:59:48 GMT]]></title><description><![CDATA[<p dir="auto">No, just 1…MagicMirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/73639</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73639</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 27 Apr 2020 05:59:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 25 Apr 2020 03:44:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> i have never seen that behavior…</p>
<p dir="auto">do you have two entries in pm2??<br />
show the results of</p>
<pre><code>pm2 status
]]></description><link>https://forum.magicmirror.builders/post/73533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73533</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Apr 2020 03:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 25 Apr 2020 03:42:47 GMT]]></title><description><![CDATA[<p dir="auto">OK…your script did a great job in getting a new MM installed onto another Ubuntu machine.  There’s one odd behavior I’m noticing.  When the MM2 first comes up after power-on or reboot, not all the modules get started.  I have to press the  key and the File -&gt; Close.  When the MM2 comes up again all is well.  I’m wondering why that is???  Is it possible to place a delay in the config.js (or somewhere else) so each module has plenty of time to get started.  Maybe there’s another solution to this behavior???<br />
BTW…thanks for all your work on the installation scripts and the help you’ve provided!</p>
]]></description><link>https://forum.magicmirror.builders/post/73532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73532</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Sat, 25 Apr 2020 03:42:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 21:46:59 GMT]]></title><description><![CDATA[<p dir="auto">I may have given you the wrong impression…I really don’t know my way around Linux/Ubuntu.  However, I was able to run your fixuppm2 script and I now see what you mean about not having to do anything else.  I’m getting the behavior I want.  When I reboot my machine MM2 starts right up.  I’m getting ready to make another MM2 on a mini PC running Ubuntu.  This time, I’m going to use your install script!</p>
]]></description><link>https://forum.magicmirror.builders/post/73511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73511</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Fri, 24 Apr 2020 21:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 19:02:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> ok, but you don’t have to do ANY of this… if you used my install script, it set pm2 to autostart on boot</p>
<p dir="auto">to fix if you DIDN’T use my install script, use my fixuppm2 script<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">read the readme.</p>
<p dir="auto">if MM crashes, pm2 auto restarts</p>
<p dir="auto">YOU don’t have to have any additional commands any where</p>
]]></description><link>https://forum.magicmirror.builders/post/73492</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73492</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Apr 2020 19:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 18:53:00 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm…installed the default MTA for Ubuntu 18 which fixed the error message in the logfile, but pm2 still didn’t restart the MM2.  I’m afraid I don’t really understand your note about pi versus root cron running.  I can “sudo crontab -e” if that’s a better idea.  I will add, my Ubuntu is starting up with its GUI and then I’m opening a terminal window to start MM2 using “pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>”.</p>
]]></description><link>https://forum.magicmirror.builders/post/73491</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73491</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Fri, 24 Apr 2020 18:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 18:20:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> said in <a href="/post/73486">MM on Ubuntu</a>:</p>
<p dir="auto">(CRON) info (No MTA installed, discarding output)</p>
<p dir="auto">see the last answer here<br />
<a href="https://superuser.com/questions/445347/why-is-my-crontab-not-running" target="_blank" rel="noopener noreferrer nofollow ugc">https://superuser.com/questions/445347/why-is-my-crontab-not-running</a></p>
<p dir="auto">but that doesn’t some why  pm2 was not executed<br />
note that you saved the pm2 config as user pi, and cron will run as root</p>
]]></description><link>https://forum.magicmirror.builders/post/73487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73487</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Apr 2020 18:20:04 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 18:16:40 GMT]]></title><description><![CDATA[<p dir="auto">Well…I learned something.  I didn’t know about crontab logs and I found this command to try:</p>
<p dir="auto">sudo grep CRON /var/log/syslog</p>
<p dir="auto">When I did that I found this line on the end of the log:</p>
<p dir="auto">Apr 24 10:40:01 dave-ubuntu CRON[2931]: (CRON) info (No MTA installed, discarding output)</p>
<p dir="auto">I guess I need to install an MTA???</p>
]]></description><link>https://forum.magicmirror.builders/post/73486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73486</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Fri, 24 Apr 2020 18:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 18:00:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> what does crontab say when i tries to launch pm2?</p>
]]></description><link>https://forum.magicmirror.builders/post/73482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73482</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Apr 2020 18:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Fri, 24 Apr 2020 16:05:22 GMT]]></title><description><![CDATA[<p dir="auto">My MM2 is running well under Ubuntu 18.04.  I’ve installed pm2 and that works as well to start/stop MM2.  However, I’m not able to get pm2 to work when using crontab.  My crontab script looks like this:</p>
<p dir="auto">40 * * * * pm2 restart <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">so I can restart MM2 at 40 minutes after each hour.  I don’t really plan to restart MM2 that often, I just want to get this working.  I don’t know my way around Linux well enough to figure out what’s wrong.  Can anyone point me to solution or an approach to one?  Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/73479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73479</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Fri, 24 Apr 2020 16:05:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 18:10:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Probably i was editing on the wrong files. Already re-edited on the correct ones. Thanks for your kind help</p>
]]></description><link>https://forum.magicmirror.builders/post/71926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71926</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sat, 04 Apr 2020 18:10:31 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 18:09:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goncalovsc" aria-label="Profile: goncalovsc">@<bdi>goncalovsc</bdi></a> what?</p>
<pre><code>pm2 stop 0
cd ~/MagicMirror
npm start
]]></description><link>https://forum.magicmirror.builders/post/71925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71925</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Apr 2020 18:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 18:00:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> deleted magucmirror.old and everything went back to zero, all the changes i´ve made :/</p>
]]></description><link>https://forum.magicmirror.builders/post/71922</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71922</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sat, 04 Apr 2020 18:00:54 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 17:59:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goncalovsc" aria-label="Profile: goncalovsc">@<bdi>goncalovsc</bdi></a> sorry, no idea on the RSS feed</p>
]]></description><link>https://forum.magicmirror.builders/post/71921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71921</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Apr 2020 17:59:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 17:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goncalovsc" aria-label="Profile: goncalovsc">@<bdi>goncalovsc</bdi></a> u don’t need to do anything with the old ones… u edited the new one…</p>
<p dir="auto">if there is nothing else in the old, throw it away</p>
<pre><code>cd ~/
rm -rf MagucMirror.old
]]></description><link>https://forum.magicmirror.builders/post/71920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71920</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Apr 2020 17:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Ubuntu on Sat, 04 Apr 2020 17:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and btw, how can i solve this?<br />
<a href="https://gyazo.com/02cd494d4c3777805806e0c2be69a533" target="_blank" rel="noopener noreferrer nofollow ugc">https://gyazo.com/02cd494d4c3777805806e0c2be69a533</a><br />
already changed from UTF-8 to the other thats on the config but same result</p>
]]></description><link>https://forum.magicmirror.builders/post/71919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71919</guid><dc:creator><![CDATA[goncalovsc]]></dc:creator><pubDate>Sat, 04 Apr 2020 17:58:12 GMT</pubDate></item></channel></rss>
