<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0]]></title><description><![CDATA[<p dir="auto">Hi there!</p>
<p dir="auto">I need help with the configuration of my display after the upgrade to version 2.11.0</p>
<p dir="auto">I’m using a Pi 3 Model B+ with an old laptop screen in portrait orientation. As far as I remember there were no problems with the default display sections during the setup of my MagicMirror. Everything ended up where I wanted it to be.</p>
<p dir="auto">But since the upgrade the different modules are shifted all together and are overlapping. I did a <code>git pull</code> and <code>npm install</code>, run also the <code>npm audit fix</code> and installed the latest Node.js version as described in the Manual Installation guide.  I also moved to the standard config.js and made a screenshot to show the issue:</p>
<p dir="auto"><img src="/assets/uploads/files/1586462727929-1569539256498.remmina-2020-4-9-19-50-54-871535.png" alt="1569539256498.remmina-2020-4-9-19:50:54,871535.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It seems like the lower part of the display is no longer taken into account for the calculation of the display sections.<br />
Has anybody an idea where this could come from and how this could be solved?</p>
<p dir="auto">I’m happy to provide more information, but at the moment I have no clue where to look for the problem.</p>
<p dir="auto"><code>uname -a</code><br />
Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux</p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12534/allocation-of-display-sections-e-g-lower-third-and-so-on-gives-strange-results-after-upgrade-to-2-11-0</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 05:39:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12534.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Apr 2020 20:14:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 14:14:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> you will probably need to do npm install in some of the module folders when u change electron versions…</p>
<p dir="auto">I would do the test with the sample config…</p>
<p dir="auto">anyhow… u didn’t open this as a problem, so it can’t be closed…</p>
]]></description><link>https://forum.magicmirror.builders/post/72739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72739</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Apr 2020 14:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 13:07:45 GMT]]></title><description><![CDATA[<p dir="auto">I have the following results now:</p>
<p dir="auto"><code>electron 3.x.x</code> : working as expected<br />
<code>electron 4.x.x</code> : not working at all, the screen stays black<br />
from <code>electron 5</code> up to latest version (8.2.2) : The text of the different modules gets overlaid as shown in the screenshots.</p>
<p dir="auto">For the moment I stay at version 3.0.13 as all the modules I’m using are working fine.<br />
(alert, updatenotification, clock, calendar, compliments, newsfeed, helloworls, MMM-ImageSlideshow)</p>
<p dir="auto">But I fear at some point I’ll have to update to be able to use the latest MagicMirror commit…</p>
<p dir="auto">Can I somehow set this topic to “Closed” or “Solved” (at least for now ;-) )?</p>
<p dir="auto">And, thank you very much for your help, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> !</p>
]]></description><link>https://forum.magicmirror.builders/post/72732</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72732</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Tue, 14 Apr 2020 13:07:45 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 11:12:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> the last version of MM 2.10 was using electron 3.0.13</p>
]]></description><link>https://forum.magicmirror.builders/post/72722</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72722</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Apr 2020 11:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 11:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> yes, meant portrait</p>
]]></description><link>https://forum.magicmirror.builders/post/72721</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72721</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Apr 2020 11:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 10:41:06 GMT]]></title><description><![CDATA[<p dir="auto">“I last tested 6.0.12, but don’t know if it was ok for profile use”<br />
Did you mean ‘portrait’ use? But I have this problem also in landscape mode without rotated screen.</p>
<p dir="auto">I removed the electron folders in <code>node_modules</code> and did</p>
<pre><code>npm install electron@3.0.6 --only=prod
<p dir="auto">With this version everything is fine again. I try to figure out for which version of electron it breaks…</p>
]]></description><link>https://forum.magicmirror.builders/post/72713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72713</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Tue, 14 Apr 2020 10:41:06 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Tue, 14 Apr 2020 11:36:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> erase the node_modules/electron folder<br />
Then do</p>
<pre><code>npm install electron@version --only=prod
<p dir="auto">The --only keeps from loading the stuff used by testing…  like the chromedriver</p>
<p dir="auto">I last tested 6.0.12, but don’t know if it was ok for portrait mode use</p>
<p dir="auto">U may have to redo npm install in module folders.  As many modules depend on electron levels</p>
<p dir="auto">All this from the MagicMirror folder</p>
]]></description><link>https://forum.magicmirror.builders/post/72352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72352</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Apr 2020 11:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Fri, 10 Apr 2020 01:00:11 GMT]]></title><description><![CDATA[<p dir="auto">I’m not sure if electron is the issue. I tried with several commits and figured out <code>7b3a594</code> is still working fine for me, but <code>6e7edd9</code> (the one before the “Upgrade to Electron 6”) already causes this problem for me.</p>
<p dir="auto">Oh, I just realized there is an electron upgrade already in this commit (although it is not stated in the commit message):</p>
<pre><code>&gt; electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
&gt; node ./download-chromedriver.js
&gt; electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
&gt; node install.js
<p dir="auto">So might well be an electron issue. Can you give me some advice how I can try different versions to see which one is working for my setup?</p>
]]></description><link>https://forum.magicmirror.builders/post/72351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72351</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Fri, 10 Apr 2020 01:00:11 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 22:07:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> very interesting…</p>
<p dir="auto">this version does update electron  to v6.1.7</p>
]]></description><link>https://forum.magicmirror.builders/post/72335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72335</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Apr 2020 22:07:12 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 21:46:44 GMT]]></title><description><![CDATA[<p dir="auto">Well, the backup is still working as before. So it is somehow related to the new version 2.11.0</p>
<p dir="auto"><img src="/assets/uploads/files/1586468789293-1569539256498.remmina-2020-4-9-21-46-16-173352.png" alt="1569539256498.remmina-2020-4-9-21:46:16,173352.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/72334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72334</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Thu, 09 Apr 2020 21:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 21:07:49 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I have a <code>display_rotate=1</code> in my /boot/config.txt</p>
<p dir="auto">But even when I turn it back to 0 and restart the raspberry the issue seems to stay the same.</p>
<p dir="auto"><img src="/assets/uploads/files/1586466384854-1569539256498.remmina-2020-4-9-21-5-31-807371.png" alt="1569539256498.remmina-2020-4-9-21:5:31,807371.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’ll try to go back to the previous commit and my backup folder and have a look if the issue vanish or persist. Maybe it’s a driver problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/72327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72327</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Thu, 09 Apr 2020 21:07:49 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 20:46:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> npm is the node package manager</p>
<p dir="auto">if you project requires a node library/package, u add it to you projects package.json file and then npm install will read the package.json list and install them (and their dependencies)</p>
<p dir="auto">like apt-get for the OS, but just for node apps like MM</p>
<p dir="auto">no idea the problem tho…  but don’t have any portrait layout systems<br />
you did the portrait thing as part of the pi setup, right… desktop is vertical after logon…</p>
]]></description><link>https://forum.magicmirror.builders/post/72320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72320</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Apr 2020 20:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 20:41:53 GMT]]></title><description><![CDATA[<p dir="auto">Wow, this was a fast reply. Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> !</p>
<p dir="auto">Yes, I have a backup from before the upgrade. But the main.css and custom.css are identical to the current version.</p>
<p dir="auto">There was also no change in my repo which prevented me from a fast forward pull. So I guess there was no change from me which was overwritten by the upgrade.</p>
<p dir="auto">I’m not familiar with the functionality of <code>npm</code>. Was there maybe some update of another software package?</p>
]]></description><link>https://forum.magicmirror.builders/post/72319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72319</guid><dc:creator><![CDATA[phil]]></dc:creator><pubDate>Thu, 09 Apr 2020 20:41:53 GMT</pubDate></item><item><title><![CDATA[Reply to Allocation of display sections (e.g. &#x27;lower third&#x27; and so on) gives strange results after upgrade to 2.11.0 on Thu, 09 Apr 2020 20:18:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phil" aria-label="Profile: phil">@<bdi>phil</bdi></a> I suspect u had a custom cs file… which got overlayed during the update.<br />
do you have a backup?  if so, you are looking for MagicMirror/css/main.css and custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/72314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72314</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Apr 2020 20:18:40 GMT</pubDate></item></channel></rss>
