<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installing Magic mirror on windows 10]]></title><description><![CDATA[<p dir="auto">I’ve tried installing MM on windows 10, while I wait for my new raspberry.<br />
I’ve been following these instructions: <a href="https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10">https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10</a></p>
<p dir="auto">But when I want to start it I get this error:</p>
<pre><code>
$ DISPLAY=:0 npm start
&gt; magicmirror@2.11.0 start C:\Users\andre\Desktop\MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
'DISPLAY' is not recognized as an internal or external command,
operable program or batch file.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.11.0 start script.
npm ERR!     C:\Users\andre\AppData\Roaming\npm-cache\_logs\2020-04-10T21_40_49_270Z-debug.log
]]></description><link>https://forum.magicmirror.builders/topic/12543/installing-magic-mirror-on-windows-10</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 04:52:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12543.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Apr 2020 21:44:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Mon, 29 Mar 2021 20:05:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi all, I am giving this a try and running into the same errors as above, i have followed the advise but i dont get the black screen, after the error fix for display, i get new error:<br />
$ npm start</p>
<p dir="auto">magicmirror@2.14.0 start C:\Users\Richard\MagicMirror<br />
electron js/electron.js</p>
<p dir="auto">‘electron’ is not recognized as an internal or external command,<br />
operable program or batch file.<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno 1<br />
npm ERR! magicmirror@2.14.0 start: <code>electron js/electron.js</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.14.0 start script.<br />
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     C:\Users\Richard\AppData\Roaming\npm-cache_logs\2021-03-29T19_41_46_132Z-debug.log</p>
<p dir="auto">any help here would be great, thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/90054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90054</guid><dc:creator><![CDATA[rdcullis]]></dc:creator><pubDate>Mon, 29 Mar 2021 20:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Wed, 23 Sep 2020 11:51:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/suqiqi" aria-label="Profile: suqiqi">@<bdi>suqiqi</bdi></a> where do u see that?<br />
the folder is node_modules</p>
]]></description><link>https://forum.magicmirror.builders/post/82269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82269</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 11:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Wed, 23 Sep 2020 07:54:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ‘node_moudles’ is not recognized as an internal or external command,<br />
please help me thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/82260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82260</guid><dc:creator><![CDATA[suqiqi]]></dc:creator><pubDate>Wed, 23 Sep 2020 07:54:57 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Wed, 23 Sep 2020 07:45:35 GMT]]></title><description><![CDATA[<p dir="auto">‘node_moudles’ is not recognized as an internal or external command,<br />
operable program or batch file.</p>
]]></description><link>https://forum.magicmirror.builders/post/82259</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82259</guid><dc:creator><![CDATA[suqiqi]]></dc:creator><pubDate>Wed, 23 Sep 2020 07:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Mon, 10 Aug 2020 13:55:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vivian0239" aria-label="Profile: vivian0239">@<bdi>vivian0239</bdi></a> said in <a href="/post/79980">Installing Magic mirror on windows 10</a>:</p>
<p dir="auto">~/MagicMirror/vendor<br />
$ cd …\fonts<br />
bash: cd: …fonts: No such file or directory<br />
ssdrive@home MINGW64 ~/MagicMirror/vendor<br />
$ cd …<br />
ssdrive@home MINGW64 ~/MagicMirror<br />
$ cd fonts<br />
ssdrive@home MINGW64 ~/MagicMirror/fonts<br />
$ npm install<br />
added 1 package from 1 contributor and audited 1 package in 0.993s<br />
found 0 vulnerabilities</p>
<p dir="auto">there are 3 dots in the CD commands change it to 2 dots</p>
<p dir="auto">do NOT  install under min.</p>
<p dir="auto">just open a command prompt (CMD.exe) and do npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/79983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79983</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Aug 2020 13:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sun, 09 Aug 2020 20:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi, everyone!</p>
<p dir="auto">I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.<br />
I also changed package.json from:<br />
“start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,<br />
to<br />
“start”: “node_modules/.bin/electron js/electron.js”,<br />
I am new to JS, please tell me where I am wrong. Thank you!</p>
<p dir="auto">This is my log:<br />
$ npm install --only=prod</p>
<p dir="auto">magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror<br />
echo "Installing vendor files …<br />
" &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error</p>
<p dir="auto">"Installing vendor files …</p>
<p dir="auto">magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror<br />
npm run install-fonts &amp;&amp; echo "MagicMirror installation finished successfully!<br />
"</p>
<p dir="auto">magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror<br />
echo "Installing fonts …<br />
" &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error</p>
<p dir="auto">"Installing fonts …<br />
audited 1050 packages in 16.723s</p>
<p dir="auto">75 packages are looking for funding<br />
run <code>npm fund</code> for details</p>
<p dir="auto">found 3 low severity vulnerabilities<br />
run <code>npm audit fix</code> to fix them, or <code>npm audit</code> for details</p>
<p dir="auto">ssdrive@home MINGW64 ~/MagicMirror<br />
$ cd vendor</p>
<p dir="auto">ssdrive@home MINGW64 ~/MagicMirror/vendor<br />
$ npm install<br />
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):<br />
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})</p>
<p dir="auto">added 82 packages from 57 contributors and audited 150 packages in 15.029s<br />
found 8 vulnerabilities (7 low, 1 high)<br />
$ cd …\fonts<br />
bash: cd: …fonts: No such file or directory</p>
$ cd …</p>
$ cd fonts</p>
<p dir="auto">ssdrive@home MINGW64 ~/MagicMirror/fonts<br />
$ npm install<br />
$ cd …</p>
$ notepad package.json</p>
$ npm start<br />
npm ERR! code EJSONPARSE<br />
npm ERR! file C:\Users\ssdrive\MagicMirror\package.json<br />
npm ERR! JSON.parse Failed to parse json<br />
npm ERR! JSON.parse Unexpected token ， in JSON at position 209 while parsing near ‘…tron js/electron.js"，<br />
npm ERR! JSON.parse             “server”: "node …’<br />
npm ERR! JSON.parse Failed to parse package.json data.<br />
npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.</p>
npm ERR!     C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log</p>
$ npm start<br />
npm ERR!     C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log</p>
$</p>
]]></description><link>https://forum.magicmirror.builders/post/79980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79980</guid><dc:creator><![CDATA[vivian0239]]></dc:creator><pubDate>Sun, 09 Aug 2020 20:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Thu, 14 May 2020 20:05:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This is solid gold :shooting_star:  for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!<br />
p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!</p>
]]></description><link>https://forum.magicmirror.builders/post/75197</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75197</guid><dc:creator><![CDATA[sojourner]]></dc:creator><pubDate>Thu, 14 May 2020 20:05:12 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sat, 25 Apr 2020 04:27:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thanks I will do that</p>
]]></description><link>https://forum.magicmirror.builders/post/73534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73534</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Sat, 25 Apr 2020 04:27:12 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 21:16:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/73483">Installing Magic mirror on windows 10</a>:</p>
<p dir="auto">read the readme for each module</p>
<p dir="auto">I second this motion. :thumbs_up_light_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/73508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73508</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Apr 2020 21:16:26 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 18:03:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisflex" aria-label="Profile: Chrisflex">@<bdi>Chrisflex</bdi></a> read the readme for each module</p>
]]></description><link>https://forum.magicmirror.builders/post/73483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73483</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Apr 2020 18:03:07 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 15:39:35 GMT]]></title><description><![CDATA[<p dir="auto">Thank you again it works!</p>
<p dir="auto">I now have to figure out a way to change the news feed and get the local weather.</p>
]]></description><link>https://forum.magicmirror.builders/post/73477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73477</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Fri, 24 Apr 2020 15:39:35 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 15:31:50 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much I will try it.</p>
]]></description><link>https://forum.magicmirror.builders/post/73475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73475</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Fri, 24 Apr 2020 15:31:50 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 11:06:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisflex" aria-label="Profile: Chrisflex">@<bdi>Chrisflex</bdi></a> looks like you missed these steps</p>
<pre><code>cd ~/MagicMirror
cd vendor
npm install
cd ..\fonts
npm install
cd ..
]]></description><link>https://forum.magicmirror.builders/post/73452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73452</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Apr 2020 11:06:06 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Fri, 24 Apr 2020 04:02:12 GMT]]></title><description><![CDATA[<p dir="auto">The screen remains  blank after start up.</p>
<p dir="auto">Here is the log from the Console</p>
<p dir="auto"><img src="https://i.postimg.cc/nVSxDGJJ/Capture-1.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/73439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73439</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Fri, 24 Apr 2020 04:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Thu, 23 Apr 2020 11:18:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisflex" aria-label="Profile: Chrisflex">@<bdi>Chrisflex</bdi></a> said in <a href="/post/73363">Installing Magic mirror on windows 10</a>:</p>
<p dir="auto">I am having the exact same problem</p>
<p dir="auto">what problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/73376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73376</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Apr 2020 11:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Thu, 23 Apr 2020 07:33:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am having the exact same problem<br />
I will followed the suggested remedies mentioned but still no luck.<br />
Please assist if you can even via Teamviewer.</p>
]]></description><link>https://forum.magicmirror.builders/post/73363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73363</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Thu, 23 Apr 2020 07:33:07 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Thu, 23 Apr 2020 11:18:10 GMT]]></title><description><![CDATA[<p dir="auto">easy peasy</p>
<pre><code>install nodejs  (google search)
(includes npm)
install git (google search)
open cmd.exe
git clone magicmirror repo
cd MagicMirror\config
copy config.js.sample config.js
cd ..
when finished
cd vendor
npm install
cd ..\fonts
npm install
cd ..
change start line to
    "start": "node_modules/.bin/electron js/electron.js",
ctrl-s to save
alt key, file, exit to close ( or use mouse, file, exit)
npm start
<p dir="auto">voila</p>
]]></description><link>https://forum.magicmirror.builders/post/72562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72562</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Apr 2020 11:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sun, 12 Apr 2020 13:38:28 GMT]]></title><description><![CDATA[<p dir="auto">Is working for me . Need others to try. And let us knwo.</p>
]]></description><link>https://forum.magicmirror.builders/post/72540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72540</guid><dc:creator><![CDATA[Omeliel]]></dc:creator><pubDate>Sun, 12 Apr 2020 13:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sun, 12 Apr 2020 04:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omeliel" aria-label="Profile: Omeliel">@<bdi>Omeliel</bdi></a> said in <a href="/post/72486">Installing Magic mirror on windows 10</a>:</p>
<p dir="auto">Now trying to start mm I got black screen only.<br />
I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.<br />
Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.</p>
<p dir="auto">is it working or not?   prior message says working, your new question seems it is not</p>
]]></description><link>https://forum.magicmirror.builders/post/72513</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72513</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Apr 2020 04:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sat, 11 Apr 2020 19:43:55 GMT]]></title><description><![CDATA[<p dir="auto">Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .<br />
Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: Michmich">@<bdi>Michmich</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/vintage89" aria-label="Profile: vintage89">@<bdi>vintage89</bdi></a> and all others who spend their time share with us noobs :)) their knowlege.<br />
Kind regards</p>
]]></description><link>https://forum.magicmirror.builders/post/72487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72487</guid><dc:creator><![CDATA[Omeliel]]></dc:creator><pubDate>Sat, 11 Apr 2020 19:43:55 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sat, 11 Apr 2020 19:38:44 GMT]]></title><description><![CDATA[<p dir="auto">So<br />
What worked for me was so far :<br />
Installation:<br />
I installed this: <a href="https://nodejs.org/en/download/" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/en/download/</a><br />
In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.<br />
From <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror</a> I download the zip file, extracted in C: in windows (not as described in that tutorial).<br />
I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.<br />
Open cmd in windows go in C:\MagicMirror and run npm install<br />
Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js<br />
After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause<br />
It should start with "node_modules, like this<br />
]]></description><link>https://forum.magicmirror.builders/post/72486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72486</guid><dc:creator><![CDATA[Omeliel]]></dc:creator><pubDate>Sat, 11 Apr 2020 19:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sat, 11 Apr 2020 16:58:52 GMT]]></title><description><![CDATA[<p dir="auto">Sorted. I post in few minutes solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/72478</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72478</guid><dc:creator><![CDATA[Omeliel]]></dc:creator><pubDate>Sat, 11 Apr 2020 16:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic mirror on windows 10 on Sat, 11 Apr 2020 16:35:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omeliel" aria-label="Profile: Omeliel">@<bdi>Omeliel</bdi></a> ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)</p>
]]></description><link>https://forum.magicmirror.builders/post/72475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72475</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Apr 2020 16:35:09 GMT</pubDate></item></channel></rss>
