<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-synology-ds]]></title><description><![CDATA[<p dir="auto">I´ve tried to install this module, but when I try start the Mirror I get this error:</p>
<pre><code>
[2020-04-11 13:20:57.913] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
<p dir="auto">Yes - I’m a bit noob and could use some help :face_with_stuck-out_tongue:</p>
]]></description><link>https://forum.magicmirror.builders/topic/12546/mmm-synology-ds</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 12:07:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12546.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Apr 2020 11:22:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-synology-ds on Sat, 11 Apr 2020 13:02:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vintage89" aria-label="Profile: vintage89">@<bdi>vintage89</bdi></a> my post on your other topic gave u instructions to fix this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/12542/installing-modules-on-windows/5">https://forum.magicmirror.builders/topic/12542/installing-modules-on-windows/5</a><br />
no… the module was precompiled with an older level of node… he is running an uplevel version<br />
he needs to recompile the module</p>
]]></description><link>https://forum.magicmirror.builders/post/72446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72446</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Apr 2020 13:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-synology-ds on Sat, 11 Apr 2020 12:59:06 GMT]]></title><description><![CDATA[<p dir="auto">Seems like your node version is out of date. As stated in the error message try reinstalling node to get it to the latest version.</p>
]]></description><link>https://forum.magicmirror.builders/post/72445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72445</guid><dc:creator><![CDATA[FlameShotBow]]></dc:creator><pubDate>Sat, 11 Apr 2020 12:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-synology-ds on Sat, 11 Apr 2020 11:41:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vintage89" aria-label="Profile: vintage89">@<bdi>vintage89</bdi></a> my post on your other topic gave u instructions to fix this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/12542/installing-modules-on-windows/5">https://forum.magicmirror.builders/topic/12542/installing-modules-on-windows/5</a></p>
]]></description><link>https://forum.magicmirror.builders/post/72441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72441</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Apr 2020 11:41:49 GMT</pubDate></item></channel></rss>
