<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fresh install of MM on pi 3- buster]]></title><description><![CDATA[<p dir="auto">Running into some problems with this install. I had a working mirror ~a year ago but it stopped working and I didn’t have the time to fix it until now. Formated card, and did a fresh install of the latest OS and followed the manual install on docs.magicmirror.builders/</p>
<p dir="auto">I had some problems with npm install (it kept crashing and rebooting with no warnings, after running it enough it said it was successful) Tried to run the</p>
<pre><code>npm install electron@6.0.12
<p dir="auto">and ran into some errors too. Looking for some guidance to get this build back online</p>
<p dir="auto">Thanks<br />
~R<br />
<img src="/assets/uploads/files/1586647356041-pic1.png" alt="pic1.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1586647413260-pic2.png" alt="pic2.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/12556/fresh-install-of-mm-on-pi-3-buster</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 17:43:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12556.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Apr 2020 23:28:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fresh install of MM on pi 3- buster on Sun, 12 Apr 2020 04:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigmans" aria-label="Profile: bigmans">@<bdi>bigmans</bdi></a> what version of node and npm are you running?</p>
<p dir="auto">node -v  should be 10.1x.y  (mine is 10.19.0)<br />
npm -v   should be 6.1x.y   (mine is 6.14.3)</p>
<p dir="auto">the 2.11 install will try to install electron 6.1.7</p>
<p dir="auto">use my script, it handles a lot of the issues</p>
]]></description><link>https://forum.magicmirror.builders/post/72511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72511</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Apr 2020 04:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install of MM on pi 3- buster on Sun, 12 Apr 2020 01:15:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
See the installer command here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/72504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72504</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Apr 2020 01:15:23 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install of MM on pi 3- buster on Sun, 12 Apr 2020 00:26:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigmans" aria-label="Profile: bigmans">@<bdi>bigmans</bdi></a></p>
<p dir="auto">User <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> has a script/installer that does all the dirty work for you, and it does it well. He’ll put the link here when he sees this post.</p>
<p dir="auto">All credit to him. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/72500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72500</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 12 Apr 2020 00:26:05 GMT</pubDate></item></channel></rss>
