<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I dont even know]]></title><description><![CDATA[<p dir="auto">So, Ai Mirror problem<br />
I ran<br />
sudo ./setup.sh. it worked for a bit and then</p>
<p dir="auto">Bam!!</p>
<pre><code> ERROR: Command errored out with exit status 1:
     command: /home/pi/AI-Smart-Mirror/hhsmartmirror/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-MExvPe/pyaudio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-MExvPe/pyaudio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' build_ext -I/usr/local/include -L/usr/local/lib install --record /tmp/pip-record-4BVCfU/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/AI-Smart-Mirror/hhsmartmirror/include/site/python2.7/pyaudio
         cwd: /tmp/pip-install-MExvPe/pyaudio/
    Complete output (11 lines):
    running build_ext
    building '_portaudio' extension
    creating build
    creating build/temp.linux-armv7l-2.7
    creating build/temp.linux-armv7l-2.7/src
    arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/local/include -I/usr/include/python2.7 -c src/_portaudiomodule.c -o build/temp.linux-armv7l-2.7/src/_portaudiomodule.o
    src/_portaudiomodule.c:29:10: fatal error: portaudio.h: No such file or directory
     #include "portaudio.h"
    compilation terminated.
    error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /home/pi/AI-Smart-Mirror/hhsmartmirror/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-MExvPe/pyaudio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-MExvPe/pyaudio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' build_ext -I/usr/local/include -L/usr/local/lib install --record /tmp/pip-record-4BVCfU/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/AI-Smart-Mirror/hhsmartmirror/include/site/python2.7/pyaudio Check the logs for full command output.
<p dir="auto">What do i do??!!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12574/i-dont-even-know</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 04:07:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12574.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Apr 2020 13:40:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I dont even know on Wed, 13 May 2020 02:37:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/72644">I dont even know</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mahieedaboss" aria-label="Profile: Mahieedaboss">@<bdi>Mahieedaboss</bdi></a> said in <a href="/post/72643">I dont even know</a>:</p>
<p dir="auto">portaudio.h: No such file or directory</p>
<p dir="auto">google is your friend</p>
<p dir="auto"><a href="https://stackoverflow.com/questions/33513522/when-installing-pyaudio-pip-cannot-find-portaudio-h-in-usr-local-include" target="_blank" rel="noopener noreferrer nofollow ugc">https://stackoverflow.com/questions/33513522/when-installing-pyaudio-pip-cannot-find-portaudio-h-in-usr-local-include</a></p>
<p dir="auto">Great, thank you very much!<br />
It worked…</p>
<p dir="auto">greeting</p>
]]></description><link>https://forum.magicmirror.builders/post/75101</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75101</guid><dc:creator><![CDATA[manuspen]]></dc:creator><pubDate>Wed, 13 May 2020 02:37:09 GMT</pubDate></item><item><title><![CDATA[Reply to I dont even know on Mon, 13 Apr 2020 13:42:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mahieedaboss" aria-label="Profile: Mahieedaboss">@<bdi>Mahieedaboss</bdi></a> said in <a href="/post/72643">I dont even know</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/72644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72644</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Apr 2020 13:42:45 GMT</pubDate></item></channel></rss>
