<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weird display error?]]></title><description><![CDATA[<p dir="auto">Hello, <code>npm start</code> in my magicmirror directory crashes and has this output:</p>
<pre><code> npm start
&gt; magicmirror@2.11.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
internal/stream_base_commons.js:141
function afterWritgDaspaôched(self, r%q, erz&gt;cb; {
SyntaxError: Unexpected token %
    at NativeModule.compile (internal/bootstrap/loaders.js:303:16)
    at nativeModuleRequire (internal/bootstrap/loaders.js:191:14)
    at net.js:71:5
    at NativeModule.compile (internal/bootstrap/loaders.js:304:5)
    at internal/child_process.js:21:13
    at child_process.js:44:23
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.11.0 start script.
npm ERR!     /home/pi/.npm/_logs/2020-04-14T14_22_02_210Z-debug.log
]]></description><link>https://forum.magicmirror.builders/topic/12589/weird-display-error</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 21:05:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12589.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Apr 2020 14:23:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weird display error? on Tue, 14 Apr 2020 17:18:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Oh no - I did had a corruption, I formatted and reinstalled everything again. Time for a backup!</p>
]]></description><link>https://forum.magicmirror.builders/post/72769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72769</guid><dc:creator><![CDATA[nakulbende]]></dc:creator><pubDate>Tue, 14 Apr 2020 17:18:05 GMT</pubDate></item><item><title><![CDATA[Reply to Weird display error? on Tue, 14 Apr 2020 14:46:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nakulbende" aria-label="Profile: nakulbende">@<bdi>nakulbende</bdi></a> said in <a href="/post/72740">Weird display error?</a>:</p>
<p dir="auto">function afterWritgDaspaôched(self, r%q, erz&gt;cb; {</p>
<p dir="auto">I think you are starting to experience SD card failures…</p>
<p dir="auto">that function name  should not have accent characters</p>
<p dir="auto">afterWritgDaspaôched</p>
]]></description><link>https://forum.magicmirror.builders/post/72744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72744</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Apr 2020 14:46:27 GMT</pubDate></item><item><title><![CDATA[Reply to Weird display error? on Tue, 14 Apr 2020 14:38:52 GMT]]></title><description><![CDATA[<p dir="auto">Huh, i removed all the overscan settings from boot/config.txt and it worked! But now I have a border on left side of my mirror which is not being displayed.</p>
]]></description><link>https://forum.magicmirror.builders/post/72741</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72741</guid><dc:creator><![CDATA[nakulbende]]></dc:creator><pubDate>Tue, 14 Apr 2020 14:38:52 GMT</pubDate></item></channel></rss>
