<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[White Screen with the message "The site can't be reached"]]></title><description><![CDATA[<p dir="auto">Good morning everyone, today at the end of the installation of my magic mirror, my screen displays: “The site can’t be reached”.<br />
so I did some research and with the command:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ node serveronly
<p dir="auto">I was able to get this error :</p>
[2020-04-18 21:19:50.958] [LOG]    Starting MagicMirror: v2.11.0
[2020-04-18 21:19:51.073] [LOG]    Loading config ...
[2020-04-18 21:19:51.126] [LOG]    Loading module helpers ...
[2020-04-18 21:19:51.145] [LOG]    No helper found for module: alert.
[2020-04-18 21:19:51.906] [LOG]    Initializing new module helper ...
[2020-04-18 21:19:51.923] [LOG]    Module helper loaded: updatenotification
[2020-04-18 21:19:51.933] [LOG]    No helper found for module: clock.
[2020-04-18 21:19:56.473] [LOG]    Initializing new module helper ...
[2020-04-18 21:19:56.481] [LOG]    Module helper loaded: calendar
[2020-04-18 21:19:56.494] [ERROR]  WARNING! Could not load config file. Starting        with default configuration. Error found: TypeError: Cannot read property 'split        ' of undefined
[2020-04-18 21:19:56.504] [LOG]    Loading module helpers ...
[2020-04-18 21:19:56.513] [LOG]    No helper found for module: alert.
[2020-04-18 21:19:56.522] [LOG]    Initializing new module helper ...
[2020-04-18 21:19:56.530] [LOG]    Module helper loaded: updatenotification
[2020-04-18 21:19:56.540] [LOG]    No helper found for module: clock.
[2020-04-18 21:19:56.549] [LOG]    Initializing new module helper ...
[2020-04-18 21:19:56.555] [LOG]    Module helper loaded: calendar
[2020-04-18 21:19:56.568] [LOG]    Whoops! There was an uncaught exception...
[2020-04-18 21:19:56.575] [ERROR]  TypeError: Cannot read property 'split' of un        defined
    at loadModule (/home/pi/MagicMirror/js/app.js:112:25)
    at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
    at /home/pi/MagicMirror/js/app.js:167:6
    at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:19:3)
    at loadModule (/home/pi/MagicMirror/js/app.js:148:6)
    at loadModule (/home/pi/MagicMirror/js/app.js:150:4)
[2020-04-18 21:19:56.621] [LOG]    MagicMirror will not quit, but it might be a        good idea to check why this happened. Maybe no internet connection?
[2020-04-18 21:19:56.628] [LOG]    If you think this really is an issue, please...
<p dir="auto">By deleting now my config.js file I have this result without any error:</p>
[2020-04-18 21:27:39.144] [LOG]    Starting MagicMirror: v2.11.0
[2020-04-18 21:27:39.257] [LOG]    Loading config ...
[2020-04-18 21:27:39.291] [ERROR]  WARNING! Could not find config file. Please create one. Starting with default configuration.
[2020-04-18 21:27:39.305] [LOG]    Loading module helpers ...
[2020-04-18 21:27:39.751] [LOG]    Initializing new module helper ...
[2020-04-18 21:27:39.762] [LOG]    Module helper loaded: updatenotification
[2020-04-18 21:27:39.777] [LOG]    No helper found for module: helloworld.
[2020-04-18 21:27:39.784] [LOG]    All module helpers loaded.
[2020-04-18 21:27:41.147] [LOG]    Starting server on port 8080 ...
[2020-04-18 21:27:41.324] [LOG]    Server started ...
[2020-04-18 21:27:41.335] [LOG]    Connecting socket for: updatenotification
[2020-04-18 21:27:41.344] [LOG]    Sockets connected &amp; modules started ...
[2020-04-18 21:27:41.354] [LOG]
Ready to go! Please point your browser to: http://localhost:8080
<p dir="auto">So I think the problem comes from my config.js so here it is:</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "fr",
	timeFormat: 24,
	units: "metric",
			     // false, default for all  NON-armv6l devices
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "Calendrier",
						symbol: "calendar-check",
						url: "https://www.data.gouv.fr/fr/datasets/r/b580138b-ae5c-4b4d-8cbf-110ffd373192"
			//module: "compliments",
			//position: "lower_third"
			module: "currentweather",
				locationID: "6454928", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "xxxx"
			module: "weatherforecast",
			header: "Weather Forecast",
				appid: "xxxx"
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "Le Monde",
						url: "https://www.lemonde.fr/rss/une.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
<p dir="auto">thank you in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/12622/white-screen-with-the-message-the-site-can-t-be-reached</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 20:37:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12622.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Apr 2020 06:36:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to White Screen with the message "The site can't be reached" on Sat, 18 Jul 2020 02:27:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/creatibofficiel" aria-label="Profile: CreatibOfficiel">@<bdi>CreatibOfficiel</bdi></a> So this is solved rite</p>
]]></description><link>https://forum.magicmirror.builders/post/78739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78739</guid><dc:creator><![CDATA[Ethyx]]></dc:creator><pubDate>Sat, 18 Jul 2020 02:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen with the message "The site can't be reached" on Sun, 19 Apr 2020 14:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you very much.</p>
]]></description><link>https://forum.magicmirror.builders/post/73063</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73063</guid><dc:creator><![CDATA[CreatibOfficiel]]></dc:creator><pubDate>Sun, 19 Apr 2020 14:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen with the message "The site can't be reached" on Sun, 19 Apr 2020 11:43:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/creatibofficiel" aria-label="Profile: CreatibOfficiel">@<bdi>CreatibOfficiel</bdi></a> said in <a href="/post/73032">White Screen with the message "The site can't be reached"</a>:</p>
<pre><code>  {
<p dir="auto">u can’t just comment out the middle, you need to comment out the braces too…</p>
<p dir="auto">a better approach, is to add<br />
disabled:true,<br />
to the module definition, then no comments</p>
<pre><code>		{
                        disabled: true,
]]></description><link>https://forum.magicmirror.builders/post/73044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73044</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Apr 2020 11:43:18 GMT</pubDate></item></channel></rss>
