<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Carousel config.js Help Please]]></title><description><![CDATA[<p dir="auto">Hello. I’ve been trying to program one of my MM projects with a small screen. After a long process, and lots of help on this forum, I’ve finally got my project working with the LCD I’m using. I’ve been researching about the MMM-Carousel module and I am a bit confused with the configuration. I’ve had a look around and don’t seem to have an answer for my question. I apologise in advance if I’m being really thick or missed the answer.</p>
<p dir="auto">Having a look at the config for the Global setting, it’s my understanding that my <code>config.js</code> file should look something like this:</p>
<pre><code>var config = {
            module: 'MMM-Carousel',
                transitionInterval: 10000,
                ignoreModules: ['clock'],
                mode: 'global'
<p dir="auto">I guess I’m having trouble getting the code to work with the configuration of the other modules I’m using, still being in my <code>config.js</code>.  When I try to add the above to my existing <code>config.js</code> I get an error and it tells my my config is wrong. I have tried adding just this to my config just under <code>var config = {</code>  and still got an error:</p>
<pre><code> {
                mode: 'global'
<p dir="auto">Can someone please help me with this? Below is my working <code>config.js</code> with the API Keys redacted. How do I integrate these with the MMM-Carousel config? I essentially want each module to show full screen for a certain duration before flipping to the next, making them much more readable on my 4 inch display. Any help is greatly appreciated.</p>
 * MIT Licensed.
var config = {
	port: 8080,
	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
	language: "en",
	timeFormat: 24,
	units: "imperial",
			module: "alert",
			module: "clock",
			position: "top_left"
			header: "What are we doing?",
						symbol: "calendar-check-o ",
						url: "webcal://my.secret.link.to.shared.calendar"
			       module: 'MMM-TFL',
			       position: 'bottom_right',    // This can be any of the regions but works best on either side of the display
				               updateTime: 600000,
				               modes: ['tube', 'overground', 'national-rail'],
				               lines: ['c2c', 'bakerloo', 'central', 'district', 'hammersmith-city', 'jubilee', 'metropolitan', 'northern', 'piccadilly', 'victoria', 'waterloo-city'],
			units: "imperial",
			module: "currentweather",
				locationID: "*******",  //ID from http://www.openweathermap.org/help/city_list.txt
				appid: "********************************",
				roundTemp: 'true',
				degreeLabel: 'true',
				showPeriod: 'fasle',
				onlyTemp: false,
				iconTable: {
					    					'01d': 'wi-day-sunny',
					    					'02d': 'wi-day-cloudy',
					    					'03d': 'wi-cloudy',
					    					'04d': 'wi-cloudy-windy',
					    					'09d': 'wi-showers',
					    					'10d': 'wi-rain',
					    					'11d': 'wi-thunderstorm',
					    					'13d': 'wi-snow',
					    					'50d': 'wi-fog',
					    					'01n': 'wi-night',
					    					'02n': 'wi-night-cloudy',
					    					'03n': 'wi-night-cloudy',
					    					'04n': 'wi-night-cloudy',
					    					'09n': 'wi-night-showers',
					    					'10n': 'wi-night-rain',
					    					'11n': 'wi-night-thunderstorm',
					    					'13n': 'wi-night-snow',
					    					'50n': 'wi-night-alt-cloudy-windy'
			units: "imperial",
			module: "weatherforecast",
			header: "Weather Forecast",
					module: 		'MMM-UKNationalRail',
					position: 		'bottom_left',
					header:			'Departures',		//Optional - delete this line to turn OFF the header completely
									stationCode: 		'***', 		// CRS code for station
									app_id: 			'*********', 		// TransportAPI App ID
									app_key: 			'********************', 		// TransportAPI App Key
									maxResults: 		5,  		//Optional - Maximum results to display.
									showOrigin: 		false   	//Optional - Show the origin of the train in the table
]]></description><link>https://forum.magicmirror.builders/topic/12643/mmm-carousel-config-js-help-please</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 00:07:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12643.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Apr 2020 12:39:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Thu, 23 Apr 2020 17:34:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aecandroid" aria-label="Profile: aecandroid">@<bdi>aecandroid</bdi></a> no idea.  haven’t used this module.</p>
<p dir="auto">a module needs an npm install ONLY IF is contains a package.json file</p>
]]></description><link>https://forum.magicmirror.builders/post/73404</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73404</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Apr 2020 17:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Thu, 23 Apr 2020 17:18:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> right, feeling pretty stupid at the moment. I’ve added the code with global setting but it doesn’t appear to have changed anything. No errors are coming up. Do I need to add or change any code of the existing modules in my config? I was a bit confused as most modules need an <code>npm install</code> but this one doesn’t appear to need that according to the readme. Sorry to be a continuous pain. Your help is greatly appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/73403</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73403</guid><dc:creator><![CDATA[aecandroid]]></dc:creator><pubDate>Thu, 23 Apr 2020 17:18:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Thu, 23 Apr 2020 15:49:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> right you are!! “Your configuration file doesn’t contain syntax errors :)” is now what I’m seeing. Thank you for all your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/73399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73399</guid><dc:creator><![CDATA[aecandroid]]></dc:creator><pubDate>Thu, 23 Apr 2020 15:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Thu, 23 Apr 2020 15:33:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aecandroid" aria-label="Profile: aecandroid">@<bdi>aecandroid</bdi></a> said in <a href="/post/73390">MMM-Carousel config.js Help Please</a>:</p>
<pre><code>    }
  	module: "alert",
<p dir="auto">yes,</p>
<p dir="auto">each module is</p>
<pre><code>{
  module: name,
},   //&lt; ---- note the trailing comma
<p dir="auto">there is a missing comma before the module alert {</p>
]]></description><link>https://forum.magicmirror.builders/post/73393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73393</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Apr 2020 15:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Thu, 23 Apr 2020 14:35:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the <code>npm run config:check</code> That has helped me to clean up my <code>config.js</code> to not have any errors. After fixing all the issues (mainly with the use of ( ’ ) as opposed to ( " ), which is confusing when most of the code already written uses the single quote instead of the double?) I then went to add the Carousel to the top of my code as below:</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "imperial",
			module: "MMM-Carousel",
				mode: "global"
			module: "alert",
			module: "clock",
						url: "webcal://it's-still-my-secret.ical"
			       module: "MMM-TFL",
			       position: "bottom_right", // This can be any of the regions but works best on either side of the display
				               updateTime: 600000,
				               modes: ["tube", "overground", "national-rail"],
				               lines: ["c2c", "bakerloo", "central", "district", "hammersmith-city", "jubilee", "metropolitan", "northern", "piccadilly", "victoria", "waterloo-city"],
			units: "imperial",
				locationID: "********", //ID from http://www.openweathermap.org/help/city_list.txt
				roundTemp: "true",
				degreeLabel: "true",
				showPeriod: "fasle",
				onlyTemp: false,
				iconTable: {
					    					"01d": "wi-day-sunny",
					    					"02d": "wi-day-cloudy",
					    					"03d": "wi-cloudy",
					    					"04d": "wi-cloudy-windy",
					    					"09d": "wi-showers",
					    					"10d": "wi-rain",
					    					"11d": "wi-thunderstorm",
					    					"13d": "wi-snow",
					    					"50d": "wi-fog",
					    					"01n": "wi-night",
					    					"02n": "wi-night-cloudy",
					    					"03n": "wi-night-cloudy",
					    					"04n": "wi-night-cloudy",
					    					"09n": "wi-night-showers",
					    					"10n": "wi-night-rain",
					    					"11n": "wi-night-thunderstorm",
					    					"13n": "wi-night-snow",
					    					"50n": "wi-night-alt-cloudy-windy"
			units: "imperial",
			module: "MMM-UKNationalRail",
			position: "bottom_left",
			header: "Departures", //Optional - delete this line to turn OFF the header completely
				stationCode: "***", // CRS code for station
				app_id: "********", // TransportAPI App ID
				app_key: "*********************************", // TransportAPI App Key
<p dir="auto">With the code implemented at the top, I ran <code>npm run config:check</code> and it now comes back that it doesn’t like the <code>{</code> before "<code>module: "alert"</code>, referring to it as an Unexpected token. When I’ve taken that out, it says the Unexpected token is now <code>module</code>. I’m thinking I’m missing something that should be there as opposed to something that shouldn’t but I’m not sure what the token it’s expecting is?</p>
]]></description><link>https://forum.magicmirror.builders/post/73390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73390</guid><dc:creator><![CDATA[aecandroid]]></dc:creator><pubDate>Thu, 23 Apr 2020 14:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Wed, 22 Apr 2020 20:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks, that worked. Looks like I’ve got some clean up to do in my initial code before moving on. I’ll clean this up tonight and implement the new module tomorrow. Thanks again for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/73337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73337</guid><dc:creator><![CDATA[aecandroid]]></dc:creator><pubDate>Wed, 22 Apr 2020 20:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Wed, 22 Apr 2020 16:23:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aecandroid" aria-label="Profile: aecandroid">@<bdi>aecandroid</bdi></a> ok try<br />
npm run config:check</p>
]]></description><link>https://forum.magicmirror.builders/post/73326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73326</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 22 Apr 2020 16:23:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Wed, 22 Apr 2020 15:28:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for your help. Unfortunately that doesn’t seem to be working for me. I can’t post what it’s telling me as the reply keeps getting flagged for spam? Essentially it’s telling me the proper usage of npm and asking if I meant <code>npm config</code>. Maybe I’m doing something wrong? I’m doing <code> cd MagicMirror</code> then <code>npm config:check</code>. Sorry, it would be much easier if I could copy / paste but for whatever reason, it won’t let me.</p>
]]></description><link>https://forum.magicmirror.builders/post/73324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73324</guid><dc:creator><![CDATA[aecandroid]]></dc:creator><pubDate>Wed, 22 Apr 2020 15:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel config.js Help Please on Wed, 22 Apr 2020 12:53:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aecandroid" aria-label="Profile: aecandroid">@<bdi>aecandroid</bdi></a> from the ~/MagicMirror folder, run</p>
<pre><code>npm config:check
<p dir="auto">to check the syntax of the config file.</p>
<p dir="auto">find and fix errors, repeat til none</p>
]]></description><link>https://forum.magicmirror.builders/post/73314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73314</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 22 Apr 2020 12:53:12 GMT</pubDate></item></channel></rss>
