<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HUGE FLAW IN MY PLAN]]></title><description><![CDATA[<p dir="auto">At first, I thought I had everything figured out.  I soon realized that I need a way to turn it my mirror on and off cleanly.  I have found the remote control module, but I don’t completely understand it.  Could anyone help me?  The only thing I can think of is connecting the main cable with a switch to turn it on and using the remote control to turn it on once I figure things out.  Also, how could I set up a PIR sensor?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1272/huge-flaw-in-my-plan</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 13:18:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1272.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Dec 2016 15:46:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Tue, 24 Jan 2017 02:02:13 GMT]]></title><description><![CDATA[<p dir="auto">Never mind. It just doesn’t work with Microsoft Edge. Not a problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/12286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12286</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Tue, 24 Jan 2017 02:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Tue, 24 Jan 2017 00:52:34 GMT]]></title><description><![CDATA[<p dir="auto">Everything’s fine except for the bottom section called Magic Mirror 2. When I click on it, there is just a black screen. How can I fix this? Is it just because I did it from  Microsoft Edge?</p>
]]></description><link>https://forum.magicmirror.builders/post/12282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12282</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Tue, 24 Jan 2017 00:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Thu, 19 Jan 2017 03:30:57 GMT]]></title><description><![CDATA[<p dir="auto">Oh thanks! I figured out why the black screen happened. I installed the module in the wrong directory. Now everything is fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/11599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11599</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Thu, 19 Jan 2017 03:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Thu, 19 Jan 2017 03:29:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aaps" aria-label="Profile: AAPS">@<bdi>AAPS</bdi></a> hi, if your are using Raspberry pi, you can change the Timezone using raspi-config from terminal</p>
]]></description><link>https://forum.magicmirror.builders/post/11598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11598</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Thu, 19 Jan 2017 03:29:27 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Wed, 18 Jan 2017 20:05:06 GMT]]></title><description><![CDATA[<p dir="auto">Something weird happened. Every time I try to add remote control to my config.js file, when I reboot it shows a black screen. Why is this? Also, I can’t figure out how to change the time zone.</p>
]]></description><link>https://forum.magicmirror.builders/post/11581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11581</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Wed, 18 Jan 2017 20:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Tue, 03 Jan 2017 01:06:59 GMT]]></title><description><![CDATA[<p dir="auto">I finally figured out what to do.  <a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> explained it to me here: <a href="https://forum.magicmirror.builders/topic/735/mmm-remote-control/112">https://forum.magicmirror.builders/topic/735/mmm-remote-control/112</a></p>
]]></description><link>https://forum.magicmirror.builders/post/10283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10283</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Tue, 03 Jan 2017 01:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Mon, 02 Jan 2017 19:52:05 GMT]]></title><description><![CDATA[<p dir="auto">i also get this error message…</p>
]]></description><link>https://forum.magicmirror.builders/post/10251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10251</guid><dc:creator><![CDATA[schmo90]]></dc:creator><pubDate>Mon, 02 Jan 2017 19:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Mon, 02 Jan 2017 03:10:54 GMT]]></title><description><![CDATA[<p dir="auto">I installed the module, but when I go to the website it says : “This device is not allowed to access your mirror.<br />
Please check your config.js or config.js.sample to change this”</p>
<p dir="auto">What does this mean? What can I do to fix it?</p>
]]></description><link>https://forum.magicmirror.builders/post/10179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10179</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Mon, 02 Jan 2017 03:10:54 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Fri, 30 Dec 2016 12:52:52 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!  This helps a lot.</p>
]]></description><link>https://forum.magicmirror.builders/post/10070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10070</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Fri, 30 Dec 2016 12:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Thu, 29 Dec 2016 14:31:52 GMT]]></title><description><![CDATA[<p dir="auto">For reference: <a href="https://github.com/Jopyth/MMM-Remote-Control#installation" target="_blank" rel="noopener noreferrer nofollow ugc">Installation - Step 2</a></p>
<p dir="auto">Add the following to the module section of your <code>config.js</code>:</p>
<pre><code>{
    module: 'MMM-Remote-Control',
    position: 'bottom_left'
<p dir="auto">If you only copied the example config, paste these lines, for example, between <a href="https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample#L17" target="_blank" rel="noopener noreferrer nofollow ugc">lines 17 and 18</a>.</p>
<p dir="auto">Hopefully this shows you your IP address right on your mirror in the bottom right corner.</p>
<p dir="auto">If not you can execute the command <code>ifconfig</code> on your raspberry and look at the output, make sure to take the IP of the correct adapter (i.e. WLAN if you are using WLAN).</p>
]]></description><link>https://forum.magicmirror.builders/post/10025</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10025</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Thu, 29 Dec 2016 14:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Thu, 29 Dec 2016 12:37:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! How do I add it to the config.js file and how do I find my pi’s IP address?</p>
]]></description><link>https://forum.magicmirror.builders/post/10020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10020</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Thu, 29 Dec 2016 12:37:23 GMT</pubDate></item><item><title><![CDATA[Reply to HUGE FLAW IN MY PLAN on Thu, 29 Dec 2016 12:30:58 GMT]]></title><description><![CDATA[<p dir="auto">What is your issue with the remote control module? Once you installed it, and add it to your <code>config.js</code>, restart your mirror and go to the remote control page. It is hosted on your pi, so you need to know the IP, e.g. if your IP is <code>192.168.0.111</code> you need to go to <code>192.168.0.111:8080/remote.html</code>. There you should be able to switch off/on your display.</p>
]]></description><link>https://forum.magicmirror.builders/post/10019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10019</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Thu, 29 Dec 2016 12:30:58 GMT</pubDate></item></channel></rss>
