<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hourly weather forecast]]></title><description><![CDATA[<p dir="auto">Hey, I know that providers are dropping API support like dead flies but I’m wondering if there are any weather modules that do good hourly forecasts? Looked at MM-NOAA3 but it doesn’t seem to do hourly</p>
]]></description><link>https://forum.magicmirror.builders/topic/12720/hourly-weather-forecast</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 07:06:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12720.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Apr 2020 07:57:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hourly weather forecast on Wed, 13 May 2020 17:07:42 GMT]]></title><description><![CDATA[<p dir="auto">@hango thank you so much :)</p>
]]></description><link>https://forum.magicmirror.builders/post/75127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75127</guid><dc:creator><![CDATA[BenGregg01]]></dc:creator><pubDate>Wed, 13 May 2020 17:07:42 GMT</pubDate></item><item><title><![CDATA[Reply to Hourly weather forecast on Wed, 13 May 2020 04:15:19 GMT]]></title><description><![CDATA[<p dir="auto">@hango Hi, How do i change it to 12hr time instead of 24hr time?</p>
]]></description><link>https://forum.magicmirror.builders/post/75103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75103</guid><dc:creator><![CDATA[BenGregg02]]></dc:creator><pubDate>Wed, 13 May 2020 04:15:19 GMT</pubDate></item><item><title><![CDATA[Reply to Hourly weather forecast on Mon, 04 May 2020 17:56:58 GMT]]></title><description><![CDATA[<p dir="auto">@hango I make wildlife documentaries so knowing what hour the weather is going to change from sunny to overcast, for example, would be really useful. Every 3 hours is much less useful, especially if it’s only showing my the weather every three hours after the sun has set. I can’t think of anyone would need the min and max temp hourly. Generally, the temperature on any given day reaches it’s peak 2-3 hours after the sun has reached its zenith, and its coolest sometime just before dawn. Therefore a min and max temp for the day will suffice for 99% of users.</p>
]]></description><link>https://forum.magicmirror.builders/post/74649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74649</guid><dc:creator><![CDATA[mrlowndes]]></dc:creator><pubDate>Mon, 04 May 2020 17:56:58 GMT</pubDate></item><item><title><![CDATA[Reply to Hourly weather forecast on Thu, 30 Apr 2020 20:16:19 GMT]]></title><description><![CDATA[<p dir="auto">@hango Also, it is currently 13:14 and the first time in the hourly forecast is 21:00 - how do I shift it to show the 6 hours immediately after this current time? I also don’t need min and max temperature for each hour so I would like to remove those to de-clutter the space. Any tips?</p>
]]></description><link>https://forum.magicmirror.builders/post/74109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74109</guid><dc:creator><![CDATA[mrlowndes]]></dc:creator><pubDate>Thu, 30 Apr 2020 20:16:19 GMT</pubDate></item><item><title><![CDATA[Reply to Hourly weather forecast on Thu, 30 Apr 2020 20:02:01 GMT]]></title><description><![CDATA[<p dir="auto">@hango ok got it working, do you know how I would remove temperature?</p>
]]></description><link>https://forum.magicmirror.builders/post/74106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74106</guid><dc:creator><![CDATA[mrlowndes]]></dc:creator><pubDate>Thu, 30 Apr 2020 20:02:01 GMT</pubDate></item><item><title><![CDATA[Reply to Hourly weather forecast on Thu, 30 Apr 2020 17:44:16 GMT]]></title><description><![CDATA[<p dir="auto">@hango cool. Sorry, I’m a noob. When you say make modification in js file, do you mean the config.js, or the js file for the module?</p>
]]></description><link>https://forum.magicmirror.builders/post/74082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74082</guid><dc:creator><![CDATA[mrlowndes]]></dc:creator><pubDate>Thu, 30 Apr 2020 17:44:16 GMT</pubDate></item></channel></rss>
