<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Importing the Google calendar authentication and password.]]></title><description><![CDATA[<p dir="auto">The default module looks like this.</p>
<p dir="auto">url: ‘<a href="http://www.calendarlabs.com/templates/ical/US-Holidays.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.calendarlabs.com/templates/ical/US-Holidays.ics</a>’,<br />
symbol: ‘calendar’,<br />
auth: {<br />
user: ‘username’,<br />
pass: ‘superstrongpassword’,<br />
method: ‘basic’</p>
<p dir="auto">However mine does not have the following.</p>
<p dir="auto">auth: {<br />
method: ‘basic’</p>
<p dir="auto">I tried to ad these manually but that just corrupts the code.</p>
<p dir="auto">I am doing this in Windows 10 using Note++ to edit.</p>
<p dir="auto">your help is appreciated</p>
]]></description><link>https://forum.magicmirror.builders/topic/12735/importing-the-google-calendar-authentication-and-password</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 19:31:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12735.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 May 2020 09:46:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Importing the Google calendar authentication and password. on Sat, 02 May 2020 17:18:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Great thanks for the advice I will follow it.</p>
]]></description><link>https://forum.magicmirror.builders/post/74365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74365</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Sat, 02 May 2020 17:18:35 GMT</pubDate></item><item><title><![CDATA[Reply to Importing the Google calendar authentication and password. on Sat, 02 May 2020 15:20:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisflex" aria-label="Profile: Chrisflex">@<bdi>Chrisflex</bdi></a> said in <a href="/post/74317">Importing the Google calendar authentication and password.</a>:</p>
<p dir="auto">Other holidays such as Russian holidays, Christian and Orthodox holidays show on the Google Calendar but are not imported in the .ics file</p>
<p dir="auto">go to the <a href="http://calendarlabs.com" target="_blank" rel="noopener noreferrer nofollow ugc">calendarlabs.com</a> site and find the right  calendars, add entries for for each, they will merge together<br />
MagicMirror is not google, YOU have to do all the work</p>
]]></description><link>https://forum.magicmirror.builders/post/74320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74320</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 May 2020 15:20:29 GMT</pubDate></item><item><title><![CDATA[Reply to Importing the Google calendar authentication and password. on Sat, 02 May 2020 15:18:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisflex" aria-label="Profile: Chrisflex">@<bdi>Chrisflex</bdi></a> said in <a href="/post/74291">Importing the Google calendar authentication and password.</a>:</p>
<pre><code>url: ‘http://www.calendarlabs.com/templates/ical/US-Holidays.ics’,
symbol: ‘calendar’,
 auth: {
 user: ‘username’,
 method: ‘basic’
<p dir="auto">right??  every { has to have a }  , same for [ and ]</p>
]]></description><link>https://forum.magicmirror.builders/post/74318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 May 2020 15:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Importing the Google calendar authentication and password. on Sat, 02 May 2020 15:09:08 GMT]]></title><description><![CDATA[<p dir="auto">I have managed to get this sorted by importing the .ics file from Gmail that is public and does not require authentication.</p>
<p dir="auto">Next I  have a problem with the .ics file since it only shows South African public holidays.</p>
<p dir="auto">Other holidays such as Russian holidays, Christian and Orthodox holidays show on the Google Calendar but are not imported in the .ics file.</p>
]]></description><link>https://forum.magicmirror.builders/post/74317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74317</guid><dc:creator><![CDATA[Chrisflex]]></dc:creator><pubDate>Sat, 02 May 2020 15:09:08 GMT</pubDate></item></channel></rss>
