<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[newbie ... can't make magicmirror boot on startup]]></title><description><![CDATA[<p dir="auto">hi there,</p>
<p dir="auto">from the /home/pi folder I can run my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> file without issue and get a magic mirror display working. Huzzah.</p>
<p dir="auto">when I follow these instructions magic mirror won’t auto boot…</p>
<p dir="auto">environment:</p>
<ul>
<li>Rpi B+</li>
<li>running latest version of raspbian buster</li>
<li>VNC enabled</li>
<li>pm2 version:  npm -v 6.14.4</li>
<li>electron installed manually as per guide</li>
</ul>
<p dir="auto">the pi keeps booting to desktop.</p>
<p dir="auto">Any clues?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12748/newbie-can-t-make-magicmirror-boot-on-startup</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 06:06:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12748.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 May 2020 09:17:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to newbie ... can't make magicmirror boot on startup on Mon, 04 May 2020 10:41:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you ever so much… I should have used the automated installer and will do so next time. This script fixed things right up.</p>
]]></description><link>https://forum.magicmirror.builders/post/74618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74618</guid><dc:creator><![CDATA[dawnwiener]]></dc:creator><pubDate>Mon, 04 May 2020 10:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to newbie ... can't make magicmirror boot on startup on Mon, 04 May 2020 04:14:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Many thanks for your clarification… been playing with pm2 status and a few other bits and pieces… I’m learning! Great!</p>
]]></description><link>https://forum.magicmirror.builders/post/74598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74598</guid><dc:creator><![CDATA[dawnwiener]]></dc:creator><pubDate>Mon, 04 May 2020 04:14:31 GMT</pubDate></item><item><title><![CDATA[Reply to newbie ... can't make magicmirror boot on startup on Sun, 03 May 2020 16:41:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawnwiener" aria-label="Profile: dawnwiener">@<bdi>dawnwiener</bdi></a> said in <a href="/post/74494">newbie ... can't make magicmirror boot on startup</a>:</p>
<p dir="auto">pm2 version:  npm -v 6.14.4</p>
<p dir="auto">PM2 is a program that is installed via NPM. You have reported the NPM version, not the PM2 version.</p>
<p dir="auto">NPM is the Node Package Manager. It’s responsible for installing and configuring applications. PM2 is a process manager. It’s responsible for monitoring your Magic Mirror application and auto-starting it when your mirror boots.</p>
]]></description><link>https://forum.magicmirror.builders/post/74528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74528</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sun, 03 May 2020 16:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to newbie ... can't make magicmirror boot on startup on Sun, 03 May 2020 12:56:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawnwiener" aria-label="Profile: dawnwiener">@<bdi>dawnwiener</bdi></a> run the fixuppm2 script from here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">read the readme for the command to issue.</p>
<p dir="auto">(if u had used the automated installer, also from this site, it would have done this for you)</p>
]]></description><link>https://forum.magicmirror.builders/post/74511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74511</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 May 2020 12:56:17 GMT</pubDate></item></channel></rss>
