<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyCommute not showing up today.]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I’ve been working on my MagicMirror for a while now, and installed MMM-MyCommute a while back along with MMM-GoogleMapsTraffic at about the same time. Today I booted up my Magic Mirror to find that the MyCommute module did not show up, and there was an update notification at the top. I updated MyCommute, applied the new changes to the config, and still, nothing showed up when I ran Magic Mirror again. I tried running it with the exact example config shown in the readme with my API key from google, and still nothing. It was running fine before today. Does anyone have any ideas?</p>
<p dir="auto">Note - MMM-GoogleMapsTraffic is still working well, and when I ran npm start dev I found that there was a potential error with using the same API keys for both modules (which I thought was weird since It’s been running fine this whole time), so I made a brand new API key, but still nothing.</p>
<p dir="auto">Thanks so much for the help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12749/mmm-mycommute-not-showing-up-today</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 14:17:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12749.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 May 2020 09:19:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Tue, 12 May 2020 23:05:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> I don’t know</p>
<p dir="auto">the code says<br />
if (this.isInWindow(this.config.startTime, this.config.endTime, this.config.hideDays)) {</p>
<p dir="auto">startTime defaults to 00:00<br />
and endTime defaults to 23:59<br />
and hideDays defaults to []</p>
]]></description><link>https://forum.magicmirror.builders/post/75095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75095</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 May 2020 23:05:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Tue, 12 May 2020 21:14:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I don’t have any time parameters set up on the module. Weird… It fixed itself later in the day without me doing anything. Do you think there’s anything I can do to prevent that in the future?</p>
<p dir="auto">Thanks for the help!</p>
]]></description><link>https://forum.magicmirror.builders/post/75093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75093</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Tue, 12 May 2020 21:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 11:11:54 GMT]]></title><description><![CDATA[<p dir="auto">still looks like it hides itself is there are no destinations or  not in the time window to need to show results.<br />
(commute set for 9am -10am, and its now 2 pm…</p>
<p dir="auto">also hides itself immediately after startup.</p>
]]></description><link>https://forum.magicmirror.builders/post/74951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74951</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 10 May 2020 11:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 04:47:20 GMT]]></title><description><![CDATA[<p dir="auto">Okay here it is</p>
<p dir="auto"><img src="/assets/uploads/files/1589086037367-screen-shot-2020-05-09-at-9.50.33-pm.jpg" alt="Screen Shot 2020-05-09 at 9.50.33 PM.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/74942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74942</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Sun, 10 May 2020 04:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 03:57:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> in the module folder, MMM-MyCommute</p>
]]></description><link>https://forum.magicmirror.builders/post/74941</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74941</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 10 May 2020 03:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 02:58:02 GMT]]></title><description><![CDATA[<p dir="auto">Sorry I’m not sure what you mean, I ran the command and this is what it gave me:</p>
<p dir="auto"><img src="/assets/uploads/files/1589079478701-screen-shot-2020-05-09-at-8.01.07-pm.jpg" alt="Screen Shot 2020-05-09 at 8.01.07 PM.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/74940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74940</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Sun, 10 May 2020 02:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 02:32:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> said in <a href="/post/74938">MMM-MyCommute not showing up today.</a>:</p>
<p dir="auto">but I do use VNC Viewer to connect and edit the mirror</p>
<p dir="auto">shouldn’t have anything to do with it…  I edit thru an ssh connection all the time.   never touch the mirror itself</p>
<p dir="auto">looking at the code it hides itself if its outside the configured times or there are no destinations…</p>
<p dir="auto">there are 4 different ones, which are u using?</p>
<p dir="auto">git remote -v in the module folder will tell you</p>
]]></description><link>https://forum.magicmirror.builders/post/74939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74939</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 10 May 2020 02:32:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 02:27:21 GMT]]></title><description><![CDATA[<p dir="auto">Here is what it shows me:</p>
<p dir="auto"><img src="/assets/uploads/files/1589077559604-screen-shot-2020-05-09-at-7.30.05-pm.jpg" alt="Screen Shot 2020-05-09 at 7.30.05 PM.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Not sure if what you asked, but I do use VNC Viewer to connect and edit the mirror without taking the frame off. Could that have something to do with it?</p>
<p dir="auto">Thanks for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/74938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74938</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Sun, 10 May 2020 02:27:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 02:23:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> do you use pages,   or some activity monitor?  pir, or somesuch</p>
<p dir="auto">sadly there is no notification for the call to suspend on WHO, but now that you found that line,<br />
you can re-enable other messages (remove filter) and then find the suspend again (search works)<br />
and find if some module said something just before</p>
]]></description><link>https://forum.magicmirror.builders/post/74937</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74937</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 10 May 2020 02:23:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 10 May 2020 02:20:24 GMT]]></title><description><![CDATA[<p dir="auto">It says suspended but I’m not sure why, how can I check the reason?</p>
]]></description><link>https://forum.magicmirror.builders/post/74936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74936</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Sun, 10 May 2020 02:20:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sat, 09 May 2020 22:11:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> i have no idea… if you open the developers window (ctrl-shift-i or F12 on the keyboard),<br />
and select the console tab, and put commu in the filter field, do you see any errors?</p>
]]></description><link>https://forum.magicmirror.builders/post/74926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74926</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 09 May 2020 22:11:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sat, 09 May 2020 22:08:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>,</p>
<p dir="auto">I’m having the same exact problem again, do you think it could be interfering with MMM-GoogleMapsTraffic again? I have no updates to install, and MMM-MyCommute keeps shutting off.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/74924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74924</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Sat, 09 May 2020 22:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Tue, 05 May 2020 17:46:49 GMT]]></title><description><![CDATA[<p dir="auto">That worked perfectly! Thanks so much!</p>
]]></description><link>https://forum.magicmirror.builders/post/74740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74740</guid><dc:creator><![CDATA[gwiz]]></dc:creator><pubDate>Tue, 05 May 2020 17:46:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyCommute not showing up today. on Sun, 03 May 2020 13:00:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gwiz" aria-label="Profile: gwiz">@<bdi>gwiz</bdi></a> said in <a href="/post/74495">MMM-MyCommute not showing up today.</a>:</p>
<p dir="auto">MMM-GoogleMapsTraffic<br />
there was a bug in this module, I provided a fix for the developer, but they have not incorporated it yet<br />
it caused interference with other modules</p>
<p dir="auto">u can try  my version<br />
rename the modules/MMM-GoogleMapsTraffic folder out of the way<br />
cd ~/magicMirror/modules<br />
git clone <a href="https://github.com/sdetweil/MMM-GoogleMapsTraffic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-GoogleMapsTraffic</a></p>
<p dir="auto">then restart your mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/74512</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74512</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 May 2020 13:00:26 GMT</pubDate></item></channel></rss>
