<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NetworkScanner No Devices]]></title><description><![CDATA[<p dir="auto">Hi - I am a newbie. Had to redo MM and all Modules, including NetworkScanner.  I did the install procedures as laid out.</p>
<p dir="auto">One thing I couldn’t do was updating the vendor databases using the:<br />
cd /usr/share/arp-scan<br />
sudo get-iab -v -u <a href="http://standards-oui.ieee.org/iab/iab.txt" target="_blank" rel="noopener noreferrer nofollow ugc">http://standards-oui.ieee.org/iab/iab.txt</a><br />
sudo get-oui -v -u <a href="http://standards-oui.ieee.org/oui/oui.txt" target="_blank" rel="noopener noreferrer nofollow ugc">http://standards-oui.ieee.org/oui/oui.txt</a></p>
<p dir="auto">When I try those commands, it says “unknown option u” and it also gives another default URL. When I drop the -u and http, it says it can’t get both the OUI and IAB data.</p>
<p dir="auto">The module works, but shows no devices in MM.  I ran the <a href="http://arps2mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">arps2mm.sh</a> script manually and it does show  a list of devices but none appear in MM.  the arps2mm script also tells me it can’t find the iab.txt and oui.txt file which is not surprising since it’s not there.</p>
<p dir="auto">So how do I get the said text files, and hopefully this solves my issues? Thanks in advance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12761/mmm-networkscanner-no-devices</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 18:23:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12761.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 May 2020 22:59:22 GMT</pubDate><ttl>60</ttl></channel></rss>
