<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM keeps freezing]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have 2 MagicMirrors installed. Both are running fine until they freeze. Freezing may happen after 5 minutes, often it happens when I xrdp into the desktop, but this is not a neccessary condition. It may also happen after 6 hours or a day. But it happens. First I thought this was a cooling problem, I set the soft_temp_limit to 70 degrees Celsius and bought cooling cases, temp is around 48-55°C now when running for hours, but it still happens and I have no idea why.</p>
<p dir="auto">My setup (2x the same):<br />
Raspberry Pi 3B+ with 16GB Class 10 microSD-Card in a cooling case<br />
WLAN Connection (ethernet not available at the MM mounting points)<br />
Latest Raspbian 10 image.</p>
<p dir="auto">Installation of MM with Sam Detweiler’s installation script. pm2 autostart enabled and working, screensaver switched off.</p>
<p dir="auto">Active modules:</p>
<ul>
<li>Alert</li>
<li>Updatenotification</li>
<li>MMM-COVID-19</li>
<li>MyCovid19</li>
<li>MMM-WeatherOrNot</li>
<li>clock</li>
<li>calendar</li>
<li>MMM-Vrr</li>
<li>MMM-PlexNowPlaying</li>
<li>MMM-News</li>
</ul>
<p dir="auto">Currently disabled modules (by setting disabled: true in config.js)</p>
<ul>
<li>MMM-AVstock</li>
<li>MMM-Rain-Radar</li>
</ul>
<p dir="auto">Each module is working. I have no idea why MM is freezing (and while I am writing  this, one of the Mirrors froze again). Can someone walk me through troubleshooting this, it is very annoying.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12762/mm-keeps-freezing</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 10:49:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12762.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 May 2020 06:10:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM keeps freezing on Mon, 13 Jul 2020 05:59:06 GMT]]></title><description><![CDATA[<p dir="auto">I think I figured out:<br />
As soon as I use the MMM-News module, MagicMirror will freeze at some point. Uninstalled it - no issues.</p>
]]></description><link>https://forum.magicmirror.builders/post/78397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78397</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Mon, 13 Jul 2020 05:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sun, 07 Jun 2020 10:14:03 GMT]]></title><description><![CDATA[<p dir="auto">Installed to both fresh SD cards as well as USB stick before, fresh setup! Only thing that was copied over was the config.js and main.css</p>
]]></description><link>https://forum.magicmirror.builders/post/76712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76712</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sun, 07 Jun 2020 10:14:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sun, 07 Jun 2020 01:50:29 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, that would be a good idea, who knows what got screwed up on the old SD cards with the freezing.</p>
]]></description><link>https://forum.magicmirror.builders/post/76703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76703</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 07 Jun 2020 01:50:29 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sat, 06 Jun 2020 17:12:23 GMT]]></title><description><![CDATA[<p dir="auto">So, both mirrors are now running on an external 3A power supply.<br />
Unfortunately, the still keep freezing. I fear that I have to setup from scratch, step by step, to see what is causing this. :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/76686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76686</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sat, 06 Jun 2020 17:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Mon, 25 May 2020 14:16:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> - Good to know, thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/75900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75900</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 25 May 2020 14:16:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sun, 24 May 2020 20:15:03 GMT]]></title><description><![CDATA[<p dir="auto">FYI. the bolt is still active, fresh copy of the OS downloaded from their website, on RPI3b+. whipped it together so to test for mirror frame placement.</p>
]]></description><link>https://forum.magicmirror.builders/post/75883</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75883</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 24 May 2020 20:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sun, 24 May 2020 17:49:14 GMT]]></title><description><![CDATA[<p dir="auto">Okay, I’ll try this. Did also not know that the bolt signal is no longer available with current Raspbian.<br />
Oh, the controller does not enter standby, I have it running 24/7.<br />
Ordered a power supply with 3A to be sure. I’ll report back.</p>
]]></description><link>https://forum.magicmirror.builders/post/75871</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75871</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sun, 24 May 2020 17:49:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sat, 23 May 2020 18:29:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> Oooh, good call. Strong power is good power. Part of the reason I upgraded to Pi4’s for most everything, honestly. Got tired of the weak power supplies on the old USB spec, so…</p>
]]></description><link>https://forum.magicmirror.builders/post/75823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75823</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 23 May 2020 18:29:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sat, 23 May 2020 11:40:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a> Did I understand correctly that the display controller powers the Pi via its USB port? If so, I very strongly believe that this might be the source for the problem for two reasons:</p>
<ol>
<li>The USB port does not provide enough power for the Pi</li>
<li>If the display controller goes in standby, then probably the power provided via its USB port might also be reduced.</li>
</ol>
<p dir="auto">I would always recommend to connect the Pi directly to a dedicated power supply, which can supply min. 2.5A.</p>
]]></description><link>https://forum.magicmirror.builders/post/75794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75794</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sat, 23 May 2020 11:40:40 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Thu, 21 May 2020 20:13:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a> IIRC, the lightning bolt went away with Raspbian Buster.</p>
]]></description><link>https://forum.magicmirror.builders/post/75684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75684</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 21 May 2020 20:13:41 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Thu, 21 May 2020 12:54:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I have never seen the lightning bolt icon on any of the mirrors displays. I use the USB output of the display controller. Power comes from this <a href="https://www.amazon.de/gp/product/B01AA83VHA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/gp/product/B01AA83VHA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1</a> and is attached to  this display controller: <a href="https://www.amazon.de/gp/product/B0756ZBB2G/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/gp/product/B0756ZBB2G/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&amp;psc=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75652</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Thu, 21 May 2020 12:54:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Wed, 20 May 2020 15:18:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a> - I have some general troubleshooting suggestions, but unfortunately nothing approaching a solution.</p>
<p dir="auto">For starters, you can examine the system log at <code>/var/log/syslog</code> which may give you some insight to system-level events. My gut tells me it’s a power problem, but my gut is notoriously bad at debugging.</p>
<p dir="auto">Since you have two mirrors, I would back up your <code>config.js</code> file on one and sacrifice it to the troubleshooting effort. Reflash the SD card, format the USB and reinstall Raspbian. Perform a barebones Mirror installation on it using <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s script. Do not install anything other than the OS and Magic Mirror framework. Then wait and see if the freeze behavior affects the slicked mirror.</p>
<p dir="auto">If the rebuild mirror stays up, start adding things one at a time. I would start with the Lights-Out client as it is unknown to me and I am inherently suspicious of it.</p>
]]></description><link>https://forum.magicmirror.builders/post/75565</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75565</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 20 May 2020 15:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Wed, 20 May 2020 09:22:54 GMT]]></title><description><![CDATA[<p dir="auto">Anyone? :-( Both mirrors keep freezing… (whole system).</p>
]]></description><link>https://forum.magicmirror.builders/post/75542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75542</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Wed, 20 May 2020 09:22:54 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Sun, 17 May 2020 06:41:51 GMT]]></title><description><![CDATA[<p dir="auto">Okay, getting back to this. <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thanks for the tip, I bought a 32gb usb stick and made my Pi3B+ boot from it. Complete new setup of Raspbian Buster. Boots up fine.<br />
Complete new setup of MM2 with your script, works fine.<br />
Reinstalled modules and config, works fine.</p>
<p dir="auto">Cooling with passive cooling case, Temp not higher than 55°C.</p>
<p dir="auto">Setup a reboot cronjob every 6 hours.</p>
<p dir="auto">Still, the system keeps freezing. Sometimes after minutes, sometimes after days.</p>
<p dir="auto">Only other software installed is the lights-out client (which needs mono). (<a href="http://green-it-software.com/" target="_blank" rel="noopener noreferrer nofollow ugc">green-it-software.com/</a>)</p>
<p dir="auto">I have no idea on what to look for or what to do to fix this :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/75352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75352</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sun, 17 May 2020 06:41:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Mon, 04 May 2020 19:42:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a> i have started configuring my systems to boot from SD, but RUN from USB disk (SSD is fast an reliable)</p>
<p dir="auto"><a href="https://www.tomshardware.com/news/boot-raspberry-pi-from-usb,39782.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.tomshardware.com/news/boot-raspberry-pi-from-usb,39782.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/74660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74660</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 May 2020 19:42:16 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Mon, 04 May 2020 18:32:56 GMT]]></title><description><![CDATA[<p dir="auto">That would be my first fix.</p>
]]></description><link>https://forum.magicmirror.builders/post/74654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74654</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 04 May 2020 18:32:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Mon, 04 May 2020 15:19:44 GMT]]></title><description><![CDATA[<p dir="auto">Whole system. So, even a cronjob with sudo reboot every x hours does not help.<br />
As the Pis came bundles with some noname SD cards, I just ordered 2 new cards to rule out any problems with them.</p>
]]></description><link>https://forum.magicmirror.builders/post/74640</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74640</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Mon, 04 May 2020 15:19:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM keeps freezing on Mon, 04 May 2020 08:41:55 GMT]]></title><description><![CDATA[<p dir="auto">Does the whole system freeze or just the MM Software?</p>
]]></description><link>https://forum.magicmirror.builders/post/74615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74615</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 04 May 2020 08:41:55 GMT</pubDate></item></channel></rss>
