<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I am in need of help]]></title><description><![CDATA[<p dir="auto">hey, everyone, I am new to Linux and pies and such but I’ve been wanting to make a smart mirror for some time so I thought let’s do it I wanted to run it on a vm first to make sure I knew I could do it before I went out and bought stuff after fighting to get it to work I finally got raspbian on a VM I then went about installing magic mirror I followed the steps on the installation page and keep getting met with a EER in red when I try to run the “npm install” command<img src="/assets/uploads/files/1589442027526-broken.png" alt="broken.PNG" class=" img-fluid img-markdown" /><br />
this is the error I am getting if anyone knows how to fix this, please let me know asap</p>
]]></description><link>https://forum.magicmirror.builders/topic/12824/i-am-in-need-of-help</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 13:58:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12824.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 May 2020 07:42:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I am in need of help on Fri, 15 May 2020 07:45:00 GMT]]></title><description><![CDATA[<p dir="auto">How to Install MM &amp; Getting started with MM Modules using <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Installation Scripts ! - <a href="https://youtu.be/PHpth_KQHcE" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/PHpth_KQHcE</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75225</guid><dc:creator><![CDATA[pandeyprakhar00]]></dc:creator><pubDate>Fri, 15 May 2020 07:45:00 GMT</pubDate></item><item><title><![CDATA[Reply to I am in need of help on Thu, 14 May 2020 11:30:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/braden" aria-label="Profile: braden">@<bdi>braden</bdi></a> I am running buster in a vm on my linux machine. I didn’t see anything odd</p>
<p dir="auto">I did use my script…</p>
<p dir="auto">read the readme on my repo <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a>  mentioned, fir the command to issue… you will have to rename or delete the current MagicMirror folder  as ‘install’ thinks this is the 1st time…</p>
]]></description><link>https://forum.magicmirror.builders/post/75176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75176</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 May 2020 11:30:31 GMT</pubDate></item><item><title><![CDATA[Reply to I am in need of help on Thu, 14 May 2020 11:18:14 GMT]]></title><description><![CDATA[<p dir="auto">Did you try using <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> installation scripts? They handle most of the setup questions and quirks.</p>
<p dir="auto">You can find them here: <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75174</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 14 May 2020 11:18:14 GMT</pubDate></item></channel></rss>
