<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cronjob doesn't work with my MM]]></title><description><![CDATA[<p dir="auto">Hi everybody</p>
<p dir="auto">I have a problem with crontab and cronjob. My magicmirror doesn’t stop or refresh or restart or start with a cronjob.</p>
<p dir="auto">I search a solution on the forum but i still have the problem</p>
<p dir="auto">I use crontab -e without sudo and pm2 launch my magicmirror in /home/pi/MagicMirror</p>
<p dir="auto">my crontab seems like:</p>
<pre><code># m h  dom mon dow   command
01 00 * * *   pi     /home/pi/pm2 stop MagicMirror
03 00 * * *   pi     /home/pi/pm2 reload MagicMirror
00 08 * * *   pi     /home/pi/pm2 stop MagicMirror
03 08 * * *   pi     /home/pi/pm2 reload MagicMirror
52 14 * * *   pi     pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1
18 20 * * *   pi     /home/pi/MagicMirror/pm2 start MagicMirror
<p dir="auto">i try different solution but nothing happens.</p>
<p dir="auto">Can anybody help me please?</p>
<p dir="auto">Thx for next answers</p>
]]></description><link>https://forum.magicmirror.builders/topic/12845/cronjob-doesn-t-work-with-my-mm</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 05:54:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12845.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2020 13:04:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Fri, 17 Sep 2021 19:19:09 GMT]]></title><description><![CDATA[<p dir="auto">I it working now for you? :)</p>
]]></description><link>https://forum.magicmirror.builders/post/94605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94605</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Fri, 17 Sep 2021 19:19:09 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Mon, 29 Jun 2020 16:26:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i apply your command line and magic mirror starts with raspbian. I’ll come back if i have problems with my crontab<br />
Thx</p>
]]></description><link>https://forum.magicmirror.builders/post/77822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77822</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Mon, 29 Jun 2020 16:26:15 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sun, 19 Sep 2021 12:43:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> i have seen this a couple times…  not sure why,</p>
<p dir="auto">run the <a href="http://fixuppm2.sh" target="_blank" rel="noopener noreferrer nofollow ugc">fixuppm2.sh</a> script from my repo and see if that fixes the problem</p>
<p dir="auto">one line to copy/paste</p>
]]></description><link>https://forum.magicmirror.builders/post/77716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77716</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Sep 2021 12:43:28 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sat, 27 Jun 2020 18:46:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi it’s me again<br />
So i made a fresh installation of raspbian buster and latest version of Magic mirror. I used the auto install from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> . At the end of autoinstall, a message appears and says: Do you want use pm2 to autostart your mirror?<br />
So i pressed yes.<br />
After this i restart my Magic mirror but it didn’t start with raspbian.</p>
<p dir="auto">I try my cronjob  in crontab-e but nothing happen</p>
<pre><code>SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
01 00 * * *   pi      pm2 restart MagicMirror
00 08 * * *   pi      pm2 restart MagicMirror
10 16 * * *   pi      pm2 stop MagicMirror
<p dir="auto">does this command line can resolve my problem from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> git script?</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
]]></description><link>https://forum.magicmirror.builders/post/77714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77714</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Sat, 27 Jun 2020 18:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Tue, 19 May 2020 00:06:35 GMT]]></title><description><![CDATA[<p dir="auto">Allow me to deliver a gentle reminder to use <a href="https://commonmark.org/help/" target="_blank" rel="noopener noreferrer nofollow ugc">the markdown features</a> of the forum when posting code and logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/75468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75468</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 19 May 2020 00:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Mon, 18 May 2020 21:44:48 GMT]]></title><description><![CDATA[<p dir="auto">Hello MisterT<br />
I’m not an expert, I’m more of a beginner, but I tried to use a cronjob to stop and start the mirror on my mirror.</p>
<p dir="auto">10 23 * * * pm2 stop mm&gt; / dev / null 2&gt; &amp; 1<br />
15 23 * * * pm2 start mm&gt; / dev / null 2&gt; &amp; 1<br />
it worked for me.<br />
I use the MagicMirror² v2.11.0 and NAME = “Raspbian GNU / Linux”<br />
VERSION_ID = “10”<br />
VERSION = “10 (buster)”<br />
VERSION_CODENAME = buster.<br />
With older versions of the software I always had problems starting MagicMirror because of access violations with pm2 after a reboot.<br />
Maybe this will help you solve your problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/75457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75457</guid><dc:creator><![CDATA[Tribun]]></dc:creator><pubDate>Mon, 18 May 2020 21:44:48 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Mon, 18 May 2020 17:11:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> pm2 is a big node application, so if needs to be in the right folder and process</p>
]]></description><link>https://forum.magicmirror.builders/post/75428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75428</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 May 2020 17:11:00 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Mon, 18 May 2020 16:51:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> i tried your solution but still not work, same with pm2 stop/start MagicMirror</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> with this cron</p>
<p dir="auto">44 18 * * *   pi     pm2 start MagicMirror &gt; pm2 status 0<br />
or<br />
46 18 * * *   pi     pm2 start MagicMirror &gt; pm2 info 0</p>
<p dir="auto">i had a log in pi folder at the same time but a blank log</p>
<p dir="auto">I tested my cron with a simple Hello word .py and cronjob works.</p>
<p dir="auto">have you an other solution ?</p>
]]></description><link>https://forum.magicmirror.builders/post/75427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75427</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Mon, 18 May 2020 16:51:23 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sun, 17 May 2020 17:12:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a></p>
<p dir="auto">PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin<br />
SHELL=/bin/bash</p>
<p dir="auto">0 20 * * * pm2 stop mm<br />
0 6 * * 1-5 pm2 start mm</p>
]]></description><link>https://forum.magicmirror.builders/post/75378</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75378</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Sun, 17 May 2020 17:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sun, 17 May 2020 11:30:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> said in <a href="/post/75362">Cronjob doesn't work with my MM</a>:</p>
<p dir="auto">[12:51:04.343] [ERROR]  ERROR! Could not find main module js file for MMM-GooglemapsTraffic.original<br />
ATTENTION: default value of option force_s3tc_enable overridden by environment.<br />
[12:51:08.418] [ERROR]  ERROR! Could not find main module js file for MagicMirror-Display-Controller<br />
[12:51:09.801] [ERROR]  ERROR! Could not find main module js file for fabio</p>
<p dir="auto">you should add</p>
<pre><code>disabled: true,
<p dir="auto">to those three modules in you config.js<br />
right after the module name</p>
<p dir="auto">the times don’t line up on the reports…<br />
cron log</p>
<pre><code>May 17 12:52:01 raspberrypi CRON[25574]: (pi) CMD (pi     pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1)
<p dir="auto">pm2 log</p>
<pre><code>[12:55:40.854] [LOG]    Shutting down server...
<p dir="auto">take this off the shutdown command<br />
pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1<br />
add a couple commands to the cron right in front of the shutdown</p>
<pre><code>pm2 info 0
pm2 status 0
<p dir="auto">these should output to the cron log</p>
]]></description><link>https://forum.magicmirror.builders/post/75366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75366</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 17 May 2020 11:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sun, 17 May 2020 11:08:26 GMT]]></title><description><![CDATA[<p dir="auto">ok so with pm2 flush and this crontab</p>
<pre><code>52 12 * * *   pi     pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1
54 12 * * *   pi     pm2 start MagicMirror
<p dir="auto">the pm2 logs :<br />
pm2 errors</p>
<pre><code>[12:51:04.343] [ERROR]  ERROR! Could not find main module js file for MMM-GooglemapsTraffic.original
[12:51:21.774] [ERROR]  (node:25245) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
[12:51:35.140] [ERROR]  Error: status code: 401
    at /home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/omdb/index.js:211:25
    at done (/home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/needle/lib/needle.js:432:14)
    at PassThrough.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/needle/lib/needle.js:671:11)
    at PassThrough.emit (events.js:182:13)
    at endReadableNT (_stream_readable.js:1090:12)
    at process._tickCallback (internal/process/next_tick.js:63:19)
<p dir="auto">pm2 out</p>
<pre><code>
&gt; magicmirror@2.10.1 start /home/pi/MagicMirror
&gt; ./run-start.sh
[12:50:32.600] [LOG]    Starting MagicMirror: v2.10.1
[12:50:32.632] [LOG]    Loading config ...
[12:50:32.668] [LOG]    Loading module helpers ...
[12:50:32.670] [LOG]    No helper found for module: alert.
[12:50:32.820] [LOG]    Initializing new module helper ...
[12:50:32.826] [LOG]    Module helper loaded: updatenotification
[12:50:32.829] [LOG]    No helper found for module: clock.
[12:50:34.340] [LOG]    Initializing new module helper ...
[12:50:34.341] [LOG]    Module helper loaded: calendar
[12:50:34.343] [LOG]    No helper found for module: weatherforecast.
[12:50:34.471] [LOG]    Initializing new module helper ...
[12:50:34.472] [LOG]    Module helper loaded: newsfeed
[12:50:34.483] [LOG]    No helper found for module: MMM-Globe.
[12:50:35.854] [LOG]    Initializing new module helper ...
[12:50:35.856] [LOG]    Module helper loaded: MMM-MovieListings
[12:50:35.862] [LOG]    No helper found for module: MMM-Scrobbler.
[12:50:37.296] [LOG]    Initializing new module helper ...
[12:50:37.297] [LOG]    Module helper loaded: MMM-soccer
[12:50:44.499] [LOG]    Initializing new module helper ...
[12:50:44.501] [LOG]    Module helper loaded: MMM-News
[12:50:44.521] [LOG]    Initializing new module helper ...
[12:50:44.528] [LOG]    Module helper loaded: WallberryTheme
[12:50:44.532] [LOG]    No helper found for module: WB-clock.
[12:50:44.541] [LOG]    Initializing new module helper ...
[12:50:44.543] [LOG]    Module helper loaded: WB-weather
[12:50:44.578] [LOG]    Initializing new module helper ...
[12:50:44.580] [LOG]    Module helper loaded: MMM-GroveGestures
[12:50:45.966] [LOG]    Initializing new module helper ...
[12:50:45.967] [LOG]    Module helper loaded: MMM-AQI
[12:50:48.096] [LOG]    Initializing new module helper ...
[12:50:48.099] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.10.1
[12:50:48.101] [LOG]    Version is ok!
[12:50:48.102] [LOG]    Module helper loaded: MMM-Strava
[12:50:48.834] [LOG]    Initializing new module helper ...
[12:50:48.836] [LOG]    Module helper loaded: MMM-GooglePhotos
[12:50:51.424] [LOG]    Initializing new module helper ...
[12:50:51.426] [LOG]    Module helper loaded: MMM-FreeBox-Monitor
[12:50:51.428] [LOG]    No helper found for module: currentweather.
[12:50:51.434] [LOG]    No helper found for module: domoticz.
[12:50:51.692] [LOG]    Initializing new module helper ...
[12:50:51.694] [LOG]    Module helper loaded: MMM-ModuleScheduler
[12:50:51.935] [LOG]    Initializing new module helper ...
[12:50:51.936] [LOG]    Module helper loaded: MMM-Remote-Control
[12:50:53.520] [LOG]    Initializing new module helper ...
[12:50:53.522] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
[12:50:54.681] [LOG]    Initializing new module helper ...
[12:50:54.687] [LOG]    Module helper loaded: MMM-COVID19-SPARKLINE
[12:50:55.499] [LOG]    Initializing new module helper ...
[12:50:55.500] [LOG]    Module helper loaded: MMM-Hotword
[12:51:01.172] [LOG]    Initializing new module helper ...
[12:51:01.173] [LOG]    Module helper loaded: MMM-AssistantMk2
[12:51:01.176] [LOG]    No helper found for module: MMM-pages.
[12:51:01.180] [LOG]    No helper found for module: MMM-page-indicator.
[12:51:01.182] [LOG]    All module helpers loaded.
[12:51:01.187] [LOG]    Starting server on port 8080 ...
[12:51:01.197] [INFO]   [33mYou're using a full whitelist configuration to allow for all IPs[39m
[12:51:01.210] [LOG]    Server started ...
[12:51:01.215] [LOG]    Connecting socket for: updatenotification
[12:51:01.219] [LOG]    Connecting socket for: calendar
[12:51:01.222] [LOG]    Starting node helper for: calendar
[12:51:01.225] [LOG]    Connecting socket for: newsfeed
[12:51:01.228] [LOG]    Starting module: newsfeed
[12:51:01.230] [LOG]    Connecting socket for: MMM-MovieListings
[12:51:01.231] [LOG]    MMM-MovieListing helper started...
[12:51:01.233] [LOG]    Connecting socket for: MMM-soccer
[12:51:01.234] [LOG]    Starting module: MMM-soccer
[12:51:01.235] [LOG]    Connecting socket for: MMM-News
[12:51:01.237] [LOG]    Connecting socket for: WallberryTheme
[12:51:01.238] [LOG]    Starting module helper: WallberryTheme
[12:51:01.239] [LOG]    Connecting socket for: WB-weather
[12:51:01.242] [LOG]    Connecting socket for: MMM-GroveGestures
[12:51:01.245] [LOG]    Connecting socket for: MMM-AQI
[12:51:01.247] [LOG]    MMM-AQI helper started ...
[12:51:01.250] [LOG]    Connecting socket for: MMM-Strava
[12:51:01.253] [LOG]    Starting module helper: MMM-Strava
[12:51:01.258] [LOG]    Connecting socket for: MMM-GooglePhotos
[12:51:01.261] [LOG]    Connecting socket for: MMM-FreeBox-Monitor
[12:51:01.265] [LOG]    Starting module: MMM-FreeBox-Monitor
[12:51:01.266] [LOG]    Connecting socket for: MMM-ModuleScheduler
[12:51:01.267] [LOG]    Starting node helper for: MMM-ModuleScheduler
[12:51:01.269] [LOG]    Connecting socket for: MMM-Remote-Control
[12:51:01.270] [LOG]    Starting node helper for: MMM-Remote-Control
[12:51:01.293] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
[12:51:01.296] [LOG]    Connecting socket for: MMM-COVID19-SPARKLINE
[12:51:01.297] [LOG]    Starting node helper for: MMM-COVID19-SPARKLINE
[12:51:01.298] [LOG]    Connecting socket for: MMM-Hotword
[12:51:01.299] [LOG]    [HOTWORD] MMM-Hotword starts
[12:51:01.301] [LOG]    Connecting socket for: MMM-AssistantMk2
[12:51:01.302] [LOG]    Sockets connected &amp; modules started ...
[12:51:02.126] [LOG]    Launching application.
[12:51:20.629] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/lxxxxxxx/basic.ics - Interval: 300000
[12:51:20.672] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxxxx/basic.ics - Interval: 300000
[12:51:20.866] [LOG]    Create new news fetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
[12:51:21.153] [LOG]    Get league table for url http://api.football-data.org/v2/competitions/FL1/standings
[12:51:21.209] [LOG]    [NEWS] Initialized.
[12:51:21.298] [LOG]    FREEBOX: "CONNECT" [object Object]
[12:51:21.308] [LOG]    { track_id: 0,
  app_token:
   'rxxxxxxx,
  appId: 'fr.freebox',
  challenge: 'xxxxxxxxxxx',
  session_token:
   'xa5r1W+kxfU+tnnR9U/10YzBJ1/xxxxxxxx }
[12:51:21.355] [LOG]    MMM-ModuleScheduler is removing all scheduled jobs
[12:51:21.356] [LOG]    MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
[12:51:21.360] [LOG]    MMM-ModuleScheduler is scheduling SHOW_ALERT using "35 11 * * *
[12:51:21.445] [LOG]    MMM-ModuleScheduler has scheduled SHOW_ALERT
[12:51:21.461] [LOG]    MMM-ModuleScheduler will next send SHOW_ALERT at Mon May 18 2020 11:35:00 GMT+0200 (CEST)
[12:51:21.463] [LOG]    MMM-ModuleScheduler is scheduling SHOW_ALERT using "13 15 * * *
[12:51:21.477] [LOG]    MMM-ModuleScheduler has scheduled SHOW_ALERT
[12:51:21.485] [LOG]    MMM-ModuleScheduler will next send SHOW_ALERT at Sun May 17 2020 15:13:00 GMT+0200 (CEST)
[12:51:21.486] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "55 11 * * *
[12:51:21.502] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
[12:51:21.540] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Mon May 18 2020 11:55:00 GMT+0200 (CEST)
[12:51:21.544] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "00 08 * * *
[12:51:21.556] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
[12:51:21.570] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Mon May 18 2020 08:00:00 GMT+0200 (CEST)
[12:51:21.573] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "00 19 * * *
[12:51:21.583] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
[12:51:21.587] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Sun May 17 2020 19:00:00 GMT+0200 (CEST)
[12:51:21.642] [LOG]    [COVID:CORE] Scan starts.
[12:51:21.739] [LOG]    [HOTWORD] Recipe is loaded: with-AMk2v3_Jarvis.js
[12:51:22.200] [LOG]    CallbackGetChallenge -&gt; [object Object]
[12:51:22.722] [LOG]    Electron's cache successfully cleared.
[12:51:23.375] [LOG]    Refreshed access token because it has expired. Expired at: 12:51:21 now is: 12:51:23
[12:51:25.260] [LOG]    [NEWS] Articles are aggregated :  45
[12:51:25.784] [LOG]    [HOTWORD] begins.
[12:51:25.788] [LOG]    [HOTWORD] Detector starts listening.
[12:51:26.050] [LOG]    [COVID:CORE] Access to data source.
[12:51:27.283] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
[12:51:27.963] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
[12:51:30.338] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
[12:51:30.422] [LOG]    can't find property recovered Canada:
[12:51:30.423] [LOG]    adding...
[12:51:30.677] [LOG]    [COVID:CORE] Calculating Wordlwide total.
[12:51:30.888] [LOG]    [COVID:CORE] Scan Completed.
[12:51:33.466] [LOG]    [AMK2] MMM-AssistantMk2 Version: 3.3.0
[12:51:33.478] [LOG]    [AMK2] Response delay is set to 0.5 second
[12:51:33.481] [LOG]    [AMK2] Use HTML5 for audio response
[12:51:33.496] [LOG]    [AMK2] RECIPE_LOADED: with-MMM-Hotword.js
[12:51:33.498] [LOG]    [AMK2] NO_ACTION_TO_MANAGE
[12:51:33.521] [LOG]    [AMK2] ASSISTANT_WEB Started
[12:51:33.538] [LOG]    [AMK2] AssistantMk2 is initialized.
[12:51:33.906] [LOG]    FREEBOX: "GET_CALLS" [object Object]
[12:51:33.960] [LOG]    FREEBOX: "GET_DOWNLOADS" [object Object]
[12:51:34.090] [LOG]    FREEBOX: "GET_CONNECTIONSTATUS" [object Object]
[12:55:40.865] [LOG]    Stopping module helper: updatenotification
[12:55:40.876] [LOG]    Stopping module helper: calendar
[12:55:40.882] [LOG]    Stopping module helper: newsfeed
[12:55:40.884] [LOG]    Stopping module helper: MMM-MovieListings
[12:55:40.886] [LOG]    Stopping module helper: MMM-soccer
[12:55:40.891] [LOG]    Stopping module helper: MMM-News
[12:55:40.897] [LOG]    Stopping module helper: WallberryTheme
[12:55:40.903] [LOG]    Stopping module helper: WB-weather
[12:55:40.914] [LOG]    Stopping module helper: MMM-AQI
[12:55:40.916] [LOG]    Stopping module helper: MMM-Strava
[12:55:40.918] [LOG]    Stopping module helper: MMM-GooglePhotos
[12:55:40.920] [LOG]    Stopping module helper: MMM-FreeBox-Monitor
[12:55:40.921] [LOG]    Stopping module helper: MMM-ModuleScheduler
[12:55:40.932] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
[12:55:40.936] [LOG]    Stopping module helper: MMM-COVID19-SPARKLINE
[12:55:40.941] [LOG]    Stopping module helper: MMM-Hotword
[12:55:40.946] [LOG]    Stopping module helper: MMM-AssistantMk2
<p dir="auto">and cron log</p>
<pre><code>May 17 12:49:33 raspberrypi crontab[25141]: (pi) BEGIN EDIT (pi)
May 17 12:50:12 raspberrypi crontab[25141]: (pi) REPLACE (pi)
May 17 12:50:12 raspberrypi crontab[25141]: (pi) END EDIT (pi)
May 17 12:51:01 raspberrypi cron[410]: (pi) RELOAD (crontabs/pi)
May 17 12:54:01 raspberrypi CRON[25592]: (pi) CMD (pi     pm2 start MagicMirror)
May 17 12:54:01 raspberrypi CRON[25582]: (CRON) info (No MTA installed, discarding output)
<p dir="auto">Do you see something wrong ?</p>
]]></description><link>https://forum.magicmirror.builders/post/75362</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75362</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Sun, 17 May 2020 11:08:26 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sat, 16 May 2020 16:42:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a> do a pm2 flush   to clear the log, then  also show the error log… (its above the log output)<br />
or look at the files in the ~/./pm2/logs folder</p>
<p dir="auto">i looks like it works</p>
]]></description><link>https://forum.magicmirror.builders/post/75311</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75311</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 May 2020 16:42:05 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sat, 16 May 2020 14:02:04 GMT]]></title><description><![CDATA[<p dir="auto">ok so with this crontab</p>
<p dir="auto">51 15 * * *   pi     pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1<br />
53 15 * * *   pi     pm2 start MagicMirror</p>
<p dir="auto">i have in .pm2/logs</p>
<pre><code>2020-05-16T14:49:45: PM2 log: App [MagicMirror:0] starting in -fork mode-
2020-05-16T14:49:45: PM2 log: App [MagicMirror:0] online
2020-05-16T14:52:43: PM2 log: Stopping app:MagicMirror id:0
2020-05-16T14:52:44: PM2 log: pid=15018 msg=failed to kill - retrying in 100ms
2020-05-16T14:52:44: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
2020-05-16T14:52:44: PM2 log: pid=15018 msg=process killed
2020-05-16T15:39:20: PM2 log: [PM2] This PM2 is not UP TO DATE
2020-05-16T15:39:20: PM2 log: [PM2] Upgrade to version 4.4.0
2020-05-16T15:49:50: PM2 log: App [MagicMirror:0] starting in -fork mode-
2020-05-16T15:49:50: PM2 log: App [MagicMirror:0] online
2020-05-16T15:55:25: PM2 log: Stopping app:MagicMirror id:0
2020-05-16T15:55:26: PM2 log: pid=16655 msg=failed to kill - retrying in 100ms
2020-05-16T15:55:26: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
2020-05-16T15:55:26: PM2 log: pid=16655 msg=process killed
<p dir="auto">and cron logs:</p>
<pre><code>May 16 15:48:21 raspberrypi crontab[16627]: (pi) BEGIN EDIT (pi)
May 16 15:49:40 raspberrypi crontab[16627]: (pi) REPLACE (pi)
May 16 15:49:40 raspberrypi crontab[16627]: (pi) END EDIT (pi)
May 16 15:50:01 raspberrypi cron[410]: (pi) RELOAD (crontabs/pi)
May 16 15:51:02 raspberrypi CRON[17002]: (pi) CMD (pi     pm2 stop MagicMirror &gt;/dev/null 2&gt;&amp;1)
May 16 15:53:01 raspberrypi CRON[17032]: (pi) CMD (pi     pm2 start MagicMirror)
May 16 15:53:01 raspberrypi CRON[17026]: (CRON) info (No MTA installed, discarding output)
<p dir="auto">so i don’t understand nothing on pm2 but cronjob seems to work</p>
<p dir="auto">Have you an idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/75297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75297</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Sat, 16 May 2020 14:02:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cronjob doesn't work with my MM on Sat, 16 May 2020 13:08:31 GMT]]></title><description><![CDATA[<p dir="auto">does anything show in the pm2 logs?</p>
<pre><code>pm2 logs --lines=100 (or more)
<p dir="auto">pm2 is sensitive to the user who created the entries (pm2 start/save), as they are stored in the users home folder in .pm2 (notice the dot in the start of the name)</p>
]]></description><link>https://forum.magicmirror.builders/post/75294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75294</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 May 2020 13:08:31 GMT</pubDate></item></channel></rss>
