<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen after i added assistant and hotword to config]]></title><description><![CDATA[<p dir="auto">Can anyone help ? im new to coding so help would be appreciated</p>
 * MIT Licensed.
var config = {
	zoom: 1,
	address: "", // Address to listen on, can be:
	port: 8080,
	ipWhitelist: [], // Set [] to allow all IP addresses
	language: "en",
	timeFormat: 24,
	units: "metric",
			     // false, default for all  NON-armv6l devices
               module: "MMM-Hotword",
               position: "centre_top",
		chimeOnFinish: null,
		mic: {
			recordProgram: "arecord",
			device: "plughw:1"
		models: [
				hotwords    : "smart_mirror",
				file        : "smart_mirror.umdl",
				sensitivity : "0.5",
		commands: {
			"smart_mirror": {
				notificationExec: {
					notification: "ASSISTANT_ACTIVATE",
					payload: (detected, afterRecord) =&gt; {
						return {profile:"default"}
				restart:false,
				afterRecordLimit:0
	module: "MMM-AssistantMk2",
		deviceLocation: {
			coordinates: {
				latitude: 57.182937, // -90.0 - +90.0
				longitude: 2.201246, // -180.0 - +180.0
		record: {
			recordProgram : "arecord",
			device        : "plughw:1",
		notifications: {
			ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
			ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
		useWelcomeMessage: "brief today",
		profiles: {
			"default" : {
				lang: "en-US"
			module: "alert",
                        module: "compliments",
                        position: "lower_third"
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "UK Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
			module: "currentweather",
				locationID: "2657832",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "b577b21d7aa76d1c63a88af2513126d2"
			module: "weatherforecast",
			header: "Weather Forecast",
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "BBC News",
						url: "http://feeds.bbci.co.uk/news/rss.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
]]></description><link>https://forum.magicmirror.builders/topic/12846/black-screen-after-i-added-assistant-and-hotword-to-config</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 08:42:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12846.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2020 13:35:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen after i added assistant and hotword to config on Sat, 16 May 2020 17:54:43 GMT]]></title><description><![CDATA[<p dir="auto">hi, i think it’s better for you reading offical wiki in each module on github website</p>
]]></description><link>https://forum.magicmirror.builders/post/75314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75314</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 16 May 2020 17:54:43 GMT</pubDate></item></channel></rss>
