<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PIR sensor to turn monitor off. Nothing works :(]]></title><description><![CDATA[<p dir="auto">I have followed every tutorial to no avail. I’m using the MMM PIR module and followed the instructions detailed. Can anyone please help me? Is there a way in terminal I can make sure the sensor isn’t a dud?</p>
<p dir="auto">The monitor will not turn off</p>
]]></description><link>https://forum.magicmirror.builders/topic/12850/pir-sensor-to-turn-monitor-off-nothing-works</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 22:06:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12850.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2020 18:36:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 08 Jun 2020 06:50:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> True - however these commands do work the same as they did before. (Assuming you’re using the HDMI 0 plug closest to the power supply anyway)</p>
]]></description><link>https://forum.magicmirror.builders/post/76777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76777</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 08 Jun 2020 06:50:33 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 08 Jun 2020 01:56:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> commands that work on pi3, do not work on pi4… many struggling with things that worked, but don’t now</p>
]]></description><link>https://forum.magicmirror.builders/post/76771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76771</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 08 Jun 2020 01:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 08 Jun 2020 01:42:03 GMT]]></title><description><![CDATA[<p dir="auto">wait, the code comes back with errors?</p>
<p dir="auto">do us a favor.</p>
<p dir="auto">DISABLE the pir-sensor module for this test.</p>
<p dir="auto">SSH into the mirror when you’re gonna be away for a couple hours.</p>
<p dir="auto">type: <code>vcgencmd display_power 0</code> - Monitor should shut off.</p>
<p dir="auto">Go do whatever for a while. Come back,</p>
<p dir="auto">SSH back into the mirror, and type <code>vcgencmd display_power 1</code> Monitor should power on.</p>
<p dir="auto">If the monitor doesn’t power back up, there’s a good chance the monitor isn’t good for your use. If it does, then we need to look at how it’s interfacing with the PIR Sensor module.</p>
]]></description><link>https://forum.magicmirror.builders/post/76769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76769</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 08 Jun 2020 01:42:03 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 07 Jun 2020 17:43:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rafhtl" aria-label="Profile: rafhtl">@<bdi>rafhtl</bdi></a> can’t access it. Stripped down the monitor in my build a while ago</p>
]]></description><link>https://forum.magicmirror.builders/post/76747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76747</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Sun, 07 Jun 2020 17:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 01 Jun 2020 07:39:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> ok<br />
You need to acces the monitor’s menu<br />
I think I read you dont have a remote?<br />
You need to access the energy saving menu<br />
It musdt be something simple as that</p>
]]></description><link>https://forum.magicmirror.builders/post/76276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76276</guid><dc:creator><![CDATA[rafhtl]]></dc:creator><pubDate>Mon, 01 Jun 2020 07:39:58 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 31 May 2020 18:21:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rafhtl" aria-label="Profile: rafhtl">@<bdi>rafhtl</bdi></a> I was able to achieve this but my monitor stays off after a while and doesn’t come back on. Earlier in the thread I was suggested to just put the monitor to sleep but the code I used came back with errors. I needed help with those lines.</p>
]]></description><link>https://forum.magicmirror.builders/post/76216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76216</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Sun, 31 May 2020 18:21:10 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Fri, 29 May 2020 18:29:18 GMT]]></title><description><![CDATA[<p dir="auto">ok<br />
if u are using MMM-PIR-Sensor<br />
it should already be in the module<br />
please try from ssh (you have to log in to the pi) and then type<br />
/usr/bin/vcgencmd display_power 0<br />
you should first try this to see if monitor responds to command<br />
so first log in from a pc to your pi using putty<br />
r</p>
]]></description><link>https://forum.magicmirror.builders/post/76102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76102</guid><dc:creator><![CDATA[rafhtl]]></dc:creator><pubDate>Fri, 29 May 2020 18:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Fri, 29 May 2020 14:42:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rafhtl" aria-label="Profile: rafhtl">@<bdi>rafhtl</bdi></a> Can you give me more context on where to input this and where it should go?</p>
]]></description><link>https://forum.magicmirror.builders/post/76089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76089</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Fri, 29 May 2020 14:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Thu, 28 May 2020 19:13:22 GMT]]></title><description><![CDATA[<p dir="auto">I dont know if this is helpful but I use</p>
<p dir="auto">/usr/bin/vcgencmd display_power 0<br />
monitor off</p>
<p dir="auto">/usr/bin/vcgencmd display_power 1</p>
<p dir="auto">monitor on</p>
<p dir="auto">works flawlessly<br />
(ssh in pi and type the commands to try them)</p>
<p dir="auto">r</p>
]]></description><link>https://forum.magicmirror.builders/post/76030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76030</guid><dc:creator><![CDATA[rafhtl]]></dc:creator><pubDate>Thu, 28 May 2020 19:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Thu, 28 May 2020 18:04:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> Can you help me out with this?</p>
]]></description><link>https://forum.magicmirror.builders/post/76028</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76028</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Thu, 28 May 2020 18:04:41 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 25 May 2020 18:11:15 GMT]]></title><description><![CDATA[<p dir="auto">Honestly, I would resort to an out-of-MagicMirror experience. I whipped up some python code using GPIOZero to replace MMM-Buttons, for instance…</p>
]]></description><link>https://forum.magicmirror.builders/post/75912</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75912</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 25 May 2020 18:11:15 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 25 May 2020 17:21:36 GMT]]></title><description><![CDATA[<p dir="auto">For those unsuccessfully trying to put the monitor to sleep and wake up with PIR, are you running MM on pi4 with Rapsberian?<br />
I never managed to get this combination to work. Instead I did succeed with Lubuntu on pi4.</p>
<p dir="auto">Currently I have working PIR on pi3 with Rapsberian. No issue with this one.<br />
Just the pi4 is so different and worse to configure sleep/wakeup.</p>
]]></description><link>https://forum.magicmirror.builders/post/75909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75909</guid><dc:creator><![CDATA[uros76]]></dc:creator><pubDate>Mon, 25 May 2020 17:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 24 May 2020 19:45:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> well, u have 1 more close brace } then u have opens {</p>
<pre><code>{
        module: 'MMM-Screen-Powersave-Notification',
            delay: 60,
            hideInsteadShutoff:true,
        }                  //  ---- what is that guy?
<p dir="auto">before u fix it run the config checker</p>
<pre><code>cd ~/magicMirror
npm run config:check
<p dir="auto">so u can learn how to fix them</p>
]]></description><link>https://forum.magicmirror.builders/post/75882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75882</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 May 2020 19:45:58 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 24 May 2020 19:43:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> yes I changed it… know nothing about the module sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/75881</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75881</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 May 2020 19:43:44 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 24 May 2020 19:34:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Did you change it for me, because it looks in the correct format?  Any help with the code?</p>
]]></description><link>https://forum.magicmirror.builders/post/75880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75880</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Sun, 24 May 2020 19:34:32 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 24 May 2020 18:34:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> said in <a href="/post/75868">PIR sensor to turn monitor off. Nothing works :(</a>:</p>
<p dir="auto">What am I doing wrong?</p>
<p dir="auto">please use the markup for code or config info</p>
<p dir="auto">mark the text, and hit the button above the editor &lt;/&gt;</p>
]]></description><link>https://forum.magicmirror.builders/post/75876</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75876</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 May 2020 18:34:47 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 24 May 2020 18:34:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> I’m using this in the config file but its coming back with an error.  What am I doing wrong?</p>
<pre><code>{
            delay: 60,
]]></description><link>https://forum.magicmirror.builders/post/75868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75868</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Sun, 24 May 2020 18:34:02 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Wed, 20 May 2020 19:19:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> Black causes the display to turn off the backlight which saves energy. But it is surely less effective than switching the display to standby mode.</p>
]]></description><link>https://forum.magicmirror.builders/post/75580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75580</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Wed, 20 May 2020 19:19:13 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Wed, 20 May 2020 13:32:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> Since the monitor would stay on… would that have any benefits? I can’t access the menu of the monitor due to taking it apart and not knowing where the button to access the menu is located.  Thanks for all the assistance and advice, I appreciate it.</p>
]]></description><link>https://forum.magicmirror.builders/post/75552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75552</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Wed, 20 May 2020 13:32:31 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 18 May 2020 17:45:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
it depends on your monitor. Maybe there is an option in the monitor configuration menu.<br />
If not you can configure the MMM-Screen-Powersave-Notification module to only hide all modules and show the black background instead of turning the hdmi off (hideInsteadShutoff option)</p>
]]></description><link>https://forum.magicmirror.builders/post/75431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75431</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Mon, 18 May 2020 17:45:06 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 18 May 2020 15:25:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> said in <a href="/post/75376">PIR sensor to turn monitor off. Nothing works :(</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> Hi, do you see any output of the Gpio module in the log file?</p>
<p dir="auto">So I got it working with your tutorial.  My only issue now is when the monitor doesn’t have a signal it turns completely off and won’t turn back on unless its unplugged and plugged back in.  Is there a way to keep the monitor on, just asleep so that the HDMI signal when signaled, activates the screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/75425</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75425</guid><dc:creator><![CDATA[elleclouds]]></dc:creator><pubDate>Mon, 18 May 2020 15:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Mon, 18 May 2020 01:47:09 GMT]]></title><description><![CDATA[<p dir="auto">It won’t get any easier then this…</p>
<p dir="auto"><a href="https://github.com/cowboysdude/Pir-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/Pir-Sensor</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75393</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 18 May 2020 01:47:09 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 17 May 2020 21:21:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a><br />
the cmdline.txt was already ok , i really had to install xscreensaver and disable screensaver to solve my problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/75386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75386</guid><dc:creator><![CDATA[satsatt]]></dc:creator><pubDate>Sun, 17 May 2020 21:21:41 GMT</pubDate></item><item><title><![CDATA[Reply to PIR sensor to turn monitor off. Nothing works :( on Sun, 17 May 2020 16:20:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elleclouds" aria-label="Profile: elleclouds">@<bdi>elleclouds</bdi></a> Hi, do you see any output of the Gpio module in the log file?</p>
]]></description><link>https://forum.magicmirror.builders/post/75376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75376</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sun, 17 May 2020 16:20:55 GMT</pubDate></item></channel></rss>
