<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Euromillions display on MagicMirror]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">First, sorry for my english.</p>
<p dir="auto">I would like to do appear the last Euromillions’ numbers.<br />
<img src="/assets/uploads/files/1589753828362-capture-d-e-cran-2020-05-18-a-00.14.58.png" alt="Capture d’écran 2020-05-18 à 00.14.58.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Is it possible ?<br />
I found one flux RSS. But this RSS is for the last 15.</p>
<p dir="auto">I need juste the last.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12860/euromillions-display-on-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 04:12:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12860.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 May 2020 22:20:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 25 May 2020 00:28:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> 10 is impossible… You’d need closer to at least 30… I agree with you.</p>
]]></description><link>https://forum.magicmirror.builders/post/75890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75890</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 25 May 2020 00:28:10 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Sun, 24 May 2020 21:55:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a><br />
Finally, we are a great idea too :)<br />
Thx !</p>
]]></description><link>https://forum.magicmirror.builders/post/75888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75888</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Sun, 24 May 2020 21:55:03 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Sun, 24 May 2020 21:19:55 GMT]]></title><description><![CDATA[<p dir="auto">Ok sorry I found.</p>
<pre><code>.MMM-Lotteries {
width : 400px;
]]></description><link>https://forum.magicmirror.builders/post/75886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75886</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Sun, 24 May 2020 21:19:55 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Fri, 22 May 2020 00:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> How disable ticket viewer ?<br />
And How modify the width to css ?</p>
<p dir="auto">Thanks in advance !</p>
<p dir="auto">:D :D<br />
<img src="/assets/uploads/files/1590105939474-img_2740.jpg" alt="IMG_2740.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/75697</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75697</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Fri, 22 May 2020 00:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 21:38:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> You are my man ! :D</p>
]]></description><link>https://forum.magicmirror.builders/post/75520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75520</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Tue, 19 May 2020 21:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 19:12:29 GMT]]></title><description><![CDATA[<p dir="auto">@Sean it is a good idea but you want to meet the perfect time to fetch the data (close to the drawing) and you only have one try…<br />
And also a second lottery would already blow the quota.<br />
But still,  thanks for the good ideas</p>
]]></description><link>https://forum.magicmirror.builders/post/75517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75517</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 19 May 2020 19:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 17:03:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a><br />
Just Idea. store recent lottery values from API with the date as JSON file, Then when you need new values (on restart or on every Sunday), Check the JSON file first then request API when the stored data is out-of-dated.</p>
<p dir="auto"><strong>PS</strong> Ah, you’ve already approached. :) Don’t mind.</p>
]]></description><link>https://forum.magicmirror.builders/post/75510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75510</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 19 May 2020 17:03:39 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 14:59:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
It is possible, and I thought about the same, but it’s dirty and you somehow have to determine and hard-code a proper request time for every lottery.<br />
Thinking about developing it to the end but I’d prefer another API.</p>
]]></description><link>https://forum.magicmirror.builders/post/75506</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75506</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 19 May 2020 14:59:29 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 14:51:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> when would it change?  in node_helper only download then and use the file as the data source</p>
]]></description><link>https://forum.magicmirror.builders/post/75504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75504</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 May 2020 14:51:40 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 14:30:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> That looks really good.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a>  I have pushed my initial work to<br />
<a href="https://github.com/lavolp3/MMM-Lotteries" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/lavolp3/MMM-Lotteries</a></p>
<p dir="auto">But as said, the API usage is not acceptable yet.<br />
Working with dummy data. it looks like this for now.<br />
<img src="/assets/uploads/files/1589898608920-6650c4bc-0072-40cc-96a3-8fc3caa71cf9-image.png" alt="6650c4bc-0072-40cc-96a3-8fc3caa71cf9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/75502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75502</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 19 May 2020 14:30:24 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 14:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a><br />
<img src="/assets/uploads/files/1589874053067-capture-d-%C3%A9cran-de-2020-05-19-09-40-00.png" alt="Capture d’écran de 2020-05-19 09-40-00.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hello,</p>
<p dir="auto">i 'm using the module MMM-smartwebdisplay to display some web url on my magicmirror, like sncf, magicmirror,…<br />
You can use this for the moment with this configuration</p>
<pre><code>		{
			module: 'MMM-SmartWebDisplay',//
			disabled: false,
			position: 'right',	// This can be any of the regions.
				logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
				height:"550", //hauteur du cadre en pixel ou %
				width:"500", //largeur
               				updateInterval: 10, //in min. Set it to 0 for no refresh (for videos)
                				NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                				displayLastUpdate: false, //to display the last update of the URL
				displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                				url: ["https://tirage-gagnant.com/euromillions/resultats-euromillions/"], //source of the URL to be displayed
                				scrolling: "no" // allow scrolling or not. html 4 only
<p dir="auto">change options like you want…It’s just an idea for you…Have fun !</p>
]]></description><link>https://forum.magicmirror.builders/post/75482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75482</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Tue, 19 May 2020 14:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 06:51:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thgmirror" aria-label="Profile: thgmirror">@<bdi>thgmirror</bdi></a><br />
Of course that’s a solution. From my point of view however not a nice one. Styling is a mess and it also creates some work. And everyone wanting to use it would have the work.<br />
With a proper module the community has less work and it can be integrated and styled much better.</p>
<p dir="auto">For <a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> s purpose it works of course.</p>
]]></description><link>https://forum.magicmirror.builders/post/75480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75480</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 19 May 2020 06:51:31 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Tue, 19 May 2020 06:38:25 GMT]]></title><description><![CDATA[<p dir="auto">Why don’t you create a local html-page on the RPI and display it with MMM-SmartWebDisplay?</p>
<ul>
<li>
<p dir="auto">Look for a website with the requested information (for example lottoland)</p>
</li>
<li>
<p dir="auto">in your local web-page, call this site and crop it to the part you need using iFrame</p>
</li>
<li>
<p dir="auto">use MMM-SmartWebDisplay and link to the local html…in the config write url: [“/modules/millions.html”] if you place your local html in the modules folder</p>
</li>
</ul>
<p dir="auto">no api, no problem, works with nearly every webpage</p>
]]></description><link>https://forum.magicmirror.builders/post/75479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75479</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Tue, 19 May 2020 06:38:25 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 21:25:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a></p>
<p dir="auto">Yes, I understand…</p>
]]></description><link>https://forum.magicmirror.builders/post/75454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75454</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Mon, 18 May 2020 21:25:02 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 21:12:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> 10 requests/month is very difficult to manage.<br />
You need to consider that every time the mirror gets restarted for whatever reason it will have forgotten the data and needs to send a new API request.<br />
A nightmare for people debugging or developing something.</p>
]]></description><link>https://forum.magicmirror.builders/post/75453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75453</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 18 May 2020 21:12:28 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 20:24:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a><br />
I found 10 request/month too :(</p>
<p dir="auto"><a href="https://collectapi.com/api/chancegame/lottery-api" target="_blank" rel="noopener noreferrer nofollow ugc">https://collectapi.com/api/chancegame/lottery-api</a></p>
<p dir="auto">But there are 2 results per week for the Euro Millions.<br />
:P</p>
]]></description><link>https://forum.magicmirror.builders/post/75451</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75451</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Mon, 18 May 2020 20:24:25 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 14:32:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> I tried out the magayo api and had the module near completion, and then found out magayo only takes 10 API calls PER MONTH in their free plan.<br />
These are exhausted for me so I need to think about using another API or some dummy data.</p>
<p dir="auto">I am quite far on a module, but I would prefer to include more lotteries than just euromillions. So if you could research for an API and provide one that covers more lotteries I’d be grateful.</p>
]]></description><link>https://forum.magicmirror.builders/post/75424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75424</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 18 May 2020 14:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 10:24:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> How does Gooogle get the info?</p>
<p dir="auto">I found this : <a href="https://rapidapi.com/creativesolutions/api/euromillions" target="_blank" rel="noopener noreferrer nofollow ugc">https://rapidapi.com/creativesolutions/api/euromillions</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75414</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Mon, 18 May 2020 10:24:46 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 10:19:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> I put in some first thoughts on this.<br />
The problem is for anyone who changes their own numbers, how to implement this.<br />
This person would need to put the numbers into the config every time.</p>
<p dir="auto">But still a great idea, especially for anyone having fixed numbers.</p>
<p dir="auto">Already started a project :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/75413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75413</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 18 May 2020 10:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 10:13:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> thanks for you interest.<br />
I have some time, but I’m not a developper :P :D</p>
]]></description><link>https://forum.magicmirror.builders/post/75412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75412</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Mon, 18 May 2020 10:13:50 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 09:51:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> It is a good very good idea. Not for me but for people who play the lottery.</p>
<p dir="auto">There is a free lottery API that supports lots of lotteries, including yours<br />
<a href="http://magayo.com/lottery-docs/api/content/" target="_blank" rel="noopener noreferrer nofollow ugc">magayo.com/lottery-docs/api/content/</a><br />
That might be a good start I guess.</p>
<p dir="auto">I’m happy to support but not sure if I can find time to write a module.</p>
]]></description><link>https://forum.magicmirror.builders/post/75411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75411</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 18 May 2020 09:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 07:57:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Ok Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/75406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75406</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Mon, 18 May 2020 07:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to Euromillions display on MagicMirror on Mon, 18 May 2020 00:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> I almost deleted your post as it didn’t appear to be about MM. but I saw you have posted a few times and recently about the fonts…</p>
<p dir="auto">so I edited the title of your post…</p>
]]></description><link>https://forum.magicmirror.builders/post/75390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75390</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 May 2020 00:54:07 GMT</pubDate></item></channel></rss>
