<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transparent glass in front of Acrylic Sheet to hold it together ?]]></title><description><![CDATA[<p dir="auto">I am building a Smart mirror and have got an Acrylic see through mirror (18" x 24") and a 24 inch monitor. Everything is setup and now i want to build the frame (which is the hard part for me).<br />
I have a questions though about the frame and fitting all together. Do i need a transparent glass in front of the acrylic sheet when i have it all together ?<br />
How will it hold firm with a wooden frame in front ?<br />
Any help / suggestions appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12890/transparent-glass-in-front-of-acrylic-sheet-to-hold-it-together</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 02:07:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12890.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 May 2020 22:41:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Fri, 22 May 2020 04:10:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/askmahesh" aria-label="Profile: askmahesh">@<bdi>askmahesh</bdi></a> Thank you for your kind response.<br />
For Acrylic sheet you will need to build a complete frame, after taking allowances as suggested by <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/75702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75702</guid><dc:creator><![CDATA[pandeyprakhar00]]></dc:creator><pubDate>Fri, 22 May 2020 04:10:46 GMT</pubDate></item><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Thu, 21 May 2020 20:45:59 GMT]]></title><description><![CDATA[<p dir="auto">Be sure to add a little room in your frame for wood expansion. Changes in humidity (and the fact that you’ve cut the wood into pieces) will make it expand slightly. If you don’t account for this, the wood will push on the sides of your acrylic, warping it.</p>
<p dir="auto">It shouldn’t take much to give it enough slack. Maybe half a centimeter all around.</p>
]]></description><link>https://forum.magicmirror.builders/post/75690</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75690</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 21 May 2020 20:45:59 GMT</pubDate></item><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Thu, 21 May 2020 13:06:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pandeyprakhar00" aria-label="Profile: pandeyprakhar00">@<bdi>pandeyprakhar00</bdi></a> Thanks. But in the video you are using a glass. I have an acrylic sheet which is slightly bigger than the monitor.<br />
The sheet is 18"x 24" and the monitor is 24" (which is 12.5" x 21.5 ").</p>
<p dir="auto">BTW: I did see your video and liked it. especially the dimensions and calculations with excel sheet…</p>
]]></description><link>https://forum.magicmirror.builders/post/75655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75655</guid><dc:creator><![CDATA[askmahesh]]></dc:creator><pubDate>Thu, 21 May 2020 13:06:06 GMT</pubDate></item><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Thu, 21 May 2020 05:32:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/askmahesh" aria-label="Profile: askmahesh">@<bdi>askmahesh</bdi></a> You can take some ideas from the link below !<br />
<a href="https://youtu.be/BZ_JVD9ReMk" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/BZ_JVD9ReMk</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75630</guid><dc:creator><![CDATA[pandeyprakhar00]]></dc:creator><pubDate>Thu, 21 May 2020 05:32:47 GMT</pubDate></item><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Thu, 21 May 2020 01:07:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/75621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75621</guid><dc:creator><![CDATA[askmahesh]]></dc:creator><pubDate>Thu, 21 May 2020 01:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to Transparent glass in front of Acrylic Sheet to hold it together ? on Wed, 20 May 2020 23:05:51 GMT]]></title><description><![CDATA[<p dir="auto">If you’ve got the sheet the right size, you shouldn’t need anything - the frame on top would do the job of holding it in place if built correctly. See standard woodworking videos on youtube for frame building ideas, or hit up a frame shop.</p>
]]></description><link>https://forum.magicmirror.builders/post/75602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75602</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 20 May 2020 23:05:51 GMT</pubDate></item></channel></rss>
