<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NYC-Transit Module (Black Screen)]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
I am getting a black screen after installing this module. Can I get some help reviewing what might have caused it. This is a new install on a RPI 3.<br />
I read this <a href="https://forum.magicmirror.builders/topic/12836/mta-module-mm-newbie-here/14">post</a> thinking I may get insight into issue but to no avail. I even registered for a new API key and that wasn’t it.</p>
<p dir="auto">This is my current config.</p>
<pre><code>/* Magic Mirror Config JediJah
 * MIT Licensed.
var config = {
	address: "192.168.1.90",                                // Address to listen on, can be:
	port: 8080,
	ipWhitelist: [],                                       // Set [] to allow all IP addresses
	language: "en",
	timeFormat: 12,
	units: "imperial",
			   module: "alert",
 		     module: "stocks",
 				 position: "top_bar",
 						stocks: "ACB,AMC,AMD,AAPL,BPFH,JBLU,SQ,TSLA,XXII", // stock symbols
 						updateInterval: 37000 // update interval in milliseconds
		     module: "clock",
			   position: "bottom_left"
			   header: "Upcoming Events",
			   position: "bottom_left",
				 //maximumNumberOfDays: "15",
				 maximumEntries: "8",
				 colored: "true",
	       coloredSymbolOnly: "true",
				     // "MM Calendar"
				         symbol: "jedi",
					       color: "#0080FF",
						     url: "webcal://p27-calendars.icloud.com/published/2/pUk76zgtLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL"
					  // "Family Calendar"
						     symbol: "users",
						     color: "#FFFF33",
						     url: "webcal://p27-calendars.icloud.com/published/2/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
          module: "compliments",
			    position: "upper_third",
			  	compliments: {
					anytime: [
											"Hey there sexy!"
				  morning: [
												"It's a beautiful day \nIn Zamunda!",
												"Enjoy your day!",
												"How was your sleep?"
					afternoon: [
												"Hello!...",
												"You look sexy!",
												"Looking good today!"
					evening: [
												"Early to Bed, Early to Rise!",
												"You look nice!",
												"Hi, sexy!"
					module: "currentweather",
					position: "bottom_right",
					locationID: "5110302",  												//ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
					appid: "54220318a8f6202d9b47dbccf5102fbe"
					module: "weatherforecast",
					header: "Weather Forecast",
					locationID: "5110302",  											//ID from https://openweathermap.org/city
					module: "newsfeed",
					feeds: [
									title: "The Verge",
									url: "http://www.theverge.com/rss/full.xml"
									title: "9to5mac",
									url: "http://www.9to5mac.com/feed"
					showSourceTitle: true,
					showPublishDate: true
	 				module: "updatenotification",
					 module: 'MMM-nyc-transit',
					 header: "Next Train",
					 apiKey: '69c0a4199031a6dd60c00c3da86eae4c',
					 displayType: 'list',
					 mtaType: 'train',
					 stations: [
							 stationId: 95,
							 walkingTime: 5,
							 dir: {
									 upTown: false,
									 downTown: true
								 stationId: 95,
								 walkingTime: 5,
								 dir: {
										 upTown: true,
										 downTown: false
						 updateInterval: 300000
<p dir="auto">Any help or insight will be most appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12901/mmm-nyc-transit-module-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:56:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12901.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2020 21:28:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 01:19:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Thank you immensely for you help. It is running now.</p>
]]></description><link>https://forum.magicmirror.builders/post/75784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75784</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 01:19:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 01:10:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Looks like I ran npm install on modules dir.</p>
<pre><code>pi@MagicMirror2:~/MagicMirror/modules $ git clone https://github.com/Elaniobro/MMM-nyc-transit.git
Cloning into 'MMM-nyc-transit'...
remote: Enumerating objects: 67, done.
remote: Counting objects: 100% (67/67), done.
remote: Compressing objects: 100% (58/58), done.
remote: Total 176 (delta 34), reused 19 (delta 7), pack-reused 109
Receiving objects: 100% (176/176), 559.15 KiB | 649.00 KiB/s, done.
Resolving deltas: 100% (93/93), done.
pi@MagicMirror2:~/MagicMirror/modules $ npm install
<p dir="auto">I will correct as you noted.</p>
]]></description><link>https://forum.magicmirror.builders/post/75783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75783</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 01:10:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> said in <a href="/post/75780">MMM-NYC-Transit Module (Black Screen)</a>:</p>
<p dir="auto">Cannot find module ‘mta-realtime-subway-departures’</p>
<p dir="auto">but it looks like you didn’t follow the module install instructions</p>
<pre><code>1. clone this repo with the following command: git clone https://github.com/Elaniobro/MMM-nyc-transit.git
2. install all the npm modules with either yarn install or npm install
<p dir="auto">to do 2, you need to change into the module folder</p>
<pre><code>git clone ......
cd MMM-nyc-transit
npm install
]]></description><link>https://forum.magicmirror.builders/post/75781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75781</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 00:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:53:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/75772">MMM-NYC-Transit Module (Black Screen)</a>:</p>
<p dir="auto">npm start</p>
<p dir="auto">Looks like some files might be missing.<br />
Here is a dump of messages:</p>
<pre><code>[2020-05-22 20:49:37.148] [ERROR]  App threw an error during load
[2020-05-22 20:49:37.150] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
Require stack:
- /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
    at Module.require (internal/modules/cjs/loader.js:685:19)
    at require (internal/modules/cjs/helpers.js:16:16)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
    at Module._compile (internal/modules/cjs/loader.js:786:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
    at Module.load (internal/modules/cjs/loader.js:645:32)
[2020-05-22 20:49:37.155] [LOG]    Whoops! There was an uncaught exception...
[2020-05-22 20:49:37.158] [ERROR]  Error: Cannot find module 'mta-realtime-subway-departures'
Require stack:
    at Module.load (internal/modules/cjs/loader.js:645:32) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js',
    '/home/pi/MagicMirror/js/app.js',
    '/home/pi/MagicMirror/js/electron.js',
    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[2020-05-22 20:49:37.173] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-05-22 20:49:37.175] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[2020-05-22 20:49:37.336] [LOG]    Launching application.
<p dir="auto">I did clone the repo as required??</p>
]]></description><link>https://forum.magicmirror.builders/post/75780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75780</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:25:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> ok, no stop mm using pm2</p>
<p dir="auto">fix the config.js,<br />
change the disabled to false</p>
<pre><code>disabled: false,
<p dir="auto">go to the MagicMirror folder with a terminal window or ssh</p>
<pre><code>cd ~/MagicMirror
npm start
<p dir="auto">watch the messages</p>
]]></description><link>https://forum.magicmirror.builders/post/75772</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75772</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 00:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:16:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I use pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/75771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75771</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:14:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> how do you start MM? using pm2 or manually</p>
]]></description><link>https://forum.magicmirror.builders/post/75770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75770</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 00:14:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah that was my bad… the mirror loads now without the module…<br />
:man_facepalming_medium-dark_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/75769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75769</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:12:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> come on , the original instructions said</p>
<pre><code>disabled: true,
<p dir="auto">just about any new line requires a comma at the end</p>
]]></description><link>https://forum.magicmirror.builders/post/75768</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75768</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 00:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> pm2</p>
<p dir="auto">After adding <code>disabled: true </code></p>
<p dir="auto">Got "Please create a config file " error</p>
]]></description><link>https://forum.magicmirror.builders/post/75767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75767</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:07:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Aww OK will adjust</p>
]]></description><link>https://forum.magicmirror.builders/post/75766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75766</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:07:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:07:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> said in <a href="/post/75764">MMM-NYC-Transit Module (Black Screen)</a>:</p>
<pre><code>          disabled: "true",
<p dir="auto">no, i said</p>
<p dir="auto">no quotes</p>
<p dir="auto">how do you start MM?  using pm2 or manually</p>
]]></description><link>https://forum.magicmirror.builders/post/75765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75765</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 00:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Sat, 23 May 2020 00:05:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I figured thats why I said it was weird.</p>
<p dir="auto">This is what the module looked like in my config</p>
<pre><code>  {
              disabled: "true",
                     apiKey: '9b76b0b756f7f9a76d4fe883075c00cf',
                                mtaType: 'train',
                                stations: [
                                        stationId: 95,
                                        walkingTime: 5,
                                        dir: {
                                                upTown: false,
                                                downTown: true
                                        stationId: 95,
                                        walkingTime: 5,
                                        dir: {
                                                upTown: true,
                                                downTown: false
<p dir="auto">These are the steps I just tried…<br />
recreated original circumstances that caused black screen (added Module to config) and yes the black screen still exist.</p>
<p dir="auto">I assume that means there is issue with module config settings.</p>
<p dir="auto">I tried to launch the Dev console, but it did not launch in same page as black mirror screen but a white page.</p>
<p dir="auto">I will wait for your response before making changes to  config.js file again.</p>
]]></description><link>https://forum.magicmirror.builders/post/75764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75764</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Sat, 23 May 2020 00:05:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 23:51:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> it is not disabled according to the picture<br />
and the screen is not black</p>
<p dir="auto">if it were disabled, NOTHING about the module would show…</p>
<p dir="auto">same as if that entry was not in config.js at all</p>
]]></description><link>https://forum.magicmirror.builders/post/75763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75763</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 May 2020 23:51:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 23:48:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I added the module to config, disabled!<br />
The Mirror loads as normal.<br />
Something I find weird is even with the module disabled, its header is still shown.<br />
<a href="https://share.icloud.com/photos/09o6PENxnrT-_fTLvp8JN2mhw" target="_blank" rel="noopener noreferrer nofollow ugc">https://share.icloud.com/photos/09o6PENxnrT-_fTLvp8JN2mhw</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75762</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Fri, 22 May 2020 23:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 23:16:42 GMT]]></title><description><![CDATA[<p dir="auto">I realized I have since removed the config. I will re-add and check again.</p>
]]></description><link>https://forum.magicmirror.builders/post/75760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75760</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Fri, 22 May 2020 23:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 23:16:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> ok, take the nyc out of the filter field…  black screen means the UI died… so its gotta be there somewhere</p>
<p dir="auto">if u add</p>
<p dir="auto">disabled: true,</p>
<p dir="auto">to the module definition<br />
right after the module name</p>
<pre><code>{
 module:'MMM-NYC-Transit',
 disabled: true,                                 // add this line
<p dir="auto">does the black screen go away?</p>
]]></description><link>https://forum.magicmirror.builders/post/75759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75759</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 May 2020 23:16:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 23:13:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the response. There are no errors shown.</p>
]]></description><link>https://forum.magicmirror.builders/post/75758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75758</guid><dc:creator><![CDATA[JediJah]]></dc:creator><pubDate>Fri, 22 May 2020 23:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NYC-Transit Module (Black Screen) on Fri, 22 May 2020 22:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jedijah" aria-label="Profile: JediJah">@<bdi>JediJah</bdi></a> open the developers console, ctrl-shift-i on the mirror keyboard, select the tab labeled  console, and put nyc in the filter field</p>
<p dir="auto">are there any errors shown, typically red text</p>
]]></description><link>https://forum.magicmirror.builders/post/75755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75755</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 May 2020 22:43:05 GMT</pubDate></item></channel></rss>
