<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clean Install RPi3 Rasp Buster fails at Electron install over and over and over]]></title><description><![CDATA[<p dir="auto">The fail states it was looking for OS: Darwin when it wanted OS: Linux. At this point after 10-12 attempts I am wondering if the installation scripts are hacked, since Darwin is/was a version of Linux run on early Apple hardware pre-2012… I am following the instructions to the letter, as far as I can tell. What could I be doing wrong to make the installation of Electron seek Darwin instead of Linux?  I’ve tried googling and installing Electron manually and am getting a similar result. NodeJs version is 10, which is recommended by the installer but which throws an error during install.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12903/clean-install-rpi3-rasp-buster-fails-at-electron-install-over-and-over-and-over</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 13:03:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12903.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 May 2020 01:37:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clean Install RPi3 Rasp Buster fails at Electron install over and over and over on Wed, 27 May 2020 21:39:35 GMT]]></title><description><![CDATA[<p dir="auto">I have not. I will certainly do so when I pick this project back up next week sometime.  Thanks for the reply, and I’ll let you know.</p>
]]></description><link>https://forum.magicmirror.builders/post/75983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75983</guid><dc:creator><![CDATA[clingonkelt]]></dc:creator><pubDate>Wed, 27 May 2020 21:39:35 GMT</pubDate></item><item><title><![CDATA[Reply to Clean Install RPi3 Rasp Buster fails at Electron install over and over and over on Sat, 23 May 2020 02:09:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clingonkelt" aria-label="Profile: clingonkelt">@<bdi>clingonkelt</bdi></a> have you tried my install scripts, which handle darwin and linux</p>
<p dir="auto">see the links here<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/75786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75786</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 02:09:12 GMT</pubDate></item></channel></rss>
