<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PM2 autostart not working]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">I try start pm2 autostart Magic Mirror try to start, but return Raspi main display.<br />
I see follow error message PM2 logs file:</p>
<p dir="auto"><strong>0|mm       | [20057:0516/174947.405746:FATAL:atom_main_delegate.cc(210)] Running as root without --no-sandbox is not supported. See <a href="https://crbug.com/638180." target="_blank" rel="noopener noreferrer nofollow ugc">https://crbug.com/638180.</a></strong></p>
<p dir="auto">What going wrong? See follow screen shot:</p>
<p dir="auto"><img src="/assets/uploads/files/1590236790623-magic_mirror_pm2_start_problem.png" alt="Magic_Mirror_pm2_start_problem.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/12906/pm2-autostart-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 07:17:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12906.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 May 2020 12:27:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PM2 autostart not working on Sun, 24 May 2020 16:56:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi sdetweil,</p>
<p dir="auto">Thank you very much.<br />
This help my start up problem.</p>
<p dir="auto">BR.<br />
-VesaLa59</p>
]]></description><link>https://forum.magicmirror.builders/post/75867</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75867</guid><dc:creator><![CDATA[VesaLa59]]></dc:creator><pubDate>Sun, 24 May 2020 16:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to PM2 autostart not working on Sat, 23 May 2020 12:30:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vesala59" aria-label="Profile: VesaLa59">@<bdi>VesaLa59</bdi></a> the newer versions of  chrome have added support for some protected environment (sandbox), but its very restrictive</p>
<p dir="auto">run the fixsandbox script from here<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
]]></description><link>https://forum.magicmirror.builders/post/75799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75799</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 23 May 2020 12:30:59 GMT</pubDate></item></channel></rss>
