<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mmm assistant mk2]]></title><description><![CDATA[<p dir="auto">hi,first of all thanks for all the awesome modules, i just installed assistant mk2 and its working fine but im stuck with the configuration i was trying to integrate mmm-tool warning text and i have no idea where to place the warning text and along with that you might as well guide me where to place the transcript hook from mmm spotify control… totally beginner here… probably this is guess is a dumb question.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12907/mmm-assistant-mk2</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 22:31:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12907.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 May 2020 14:15:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mmm assistant mk2 on Fri, 05 Jun 2020 23:43:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcretu" aria-label="Profile: mcretu">@<bdi>mcretu</bdi></a> Hi . Lost in the Post.<br />
I think you refer to youtube not being displayed.<br />
If that is the case, as <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a>  keeps saying (he said it to me about this…), red the wiki. It’s all there.</p>
<p dir="auto">you need to change the config.js in config as follows:<br />
<a href="https://github.com/bugsounet/MMM-Assistant2Display/wiki/Configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/MMM-Assistant2Display/wiki/Configuration</a></p>
<pre><code>Assistant2Display need electron special configuration for web link displaying and Youtube functionality
start of the config.js configuration file
var config = {
  address: "localhost",
  electronOptions: {
    webPreferences: {
      webviewTag: true
  port: 8080,
address should be localhost for playing YouTube video
electronOptions is need if you want to display the link and Cast module
]]></description><link>https://forum.magicmirror.builders/post/76659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76659</guid><dc:creator><![CDATA[dvbit]]></dc:creator><pubDate>Fri, 05 Jun 2020 23:43:01 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Thu, 04 Jun 2020 13:35:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> : if you want, we can do some test</p>
]]></description><link>https://forum.magicmirror.builders/post/76524</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76524</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 04 Jun 2020 13:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 23:17:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dvbit" aria-label="Profile: dvbit">@<bdi>dvbit</bdi></a> Hi, did you managed to figure it out? I have the same issue. Youtube video audio works fine, I even hear the chime when the assistant is waked up.</p>
]]></description><link>https://forum.magicmirror.builders/post/76493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76493</guid><dc:creator><![CDATA[mcretu]]></dc:creator><pubDate>Wed, 03 Jun 2020 23:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 21:33:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> : fixed ;)</p>
<p dir="auto">wait next release :p</p>
]]></description><link>https://forum.magicmirror.builders/post/76492</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76492</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 03 Jun 2020 21:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:53:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Great, Ill wait till then. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/76490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76490</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:49:00 GMT]]></title><description><![CDATA[<p dir="auto">nop it not override all.</p>
<p dir="auto">Actually I’m working arround a new rending<br />
real time Transcription will be in next update in popup (like the response)<br />
and it will correct this problem ;)</p>
<p dir="auto">So wait a few days :)</p>
<p dir="auto">results:<br />
New animation (response screen)<br />
new animation (transcription)<br />
More reactive</p>
]]></description><link>https://forum.magicmirror.builders/post/76489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76489</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:49:00 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:45:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> main, then modules, then  custom.css last</p>
]]></description><link>https://forum.magicmirror.builders/post/76488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76488</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:45:43 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:34:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> :-)  So custom.css overides main.css , so does GoogleAssistant.css overide all ?</p>
]]></description><link>https://forum.magicmirror.builders/post/76486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76486</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:32:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a>: I don’t find too :face_with_tears_of_joy: :face_with_tears_of_joy: :face_screaming_in_fear:</p>
<p dir="auto">I got lost in my css code !!!</p>
]]></description><link>https://forum.magicmirror.builders/post/76485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76485</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:27:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a></p>
<p dir="auto">Yes i have it set to fullscreen_above, i confirmed it works fine if i remove the css code i posted above</p>
]]></description><link>https://forum.magicmirror.builders/post/76484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76484</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:27:59 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:26:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> :</p>
<pre><code class="language-js">{
  module: "MMM-GoogleAssistant",
  position: "fullscreen_above",
<p dir="auto">don’t work with this position ?</p>
<p dir="auto">Edit : Ah yes don’t work</p>
]]></description><link>https://forum.magicmirror.builders/post/76483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76483</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Wed, 03 Jun 2020 20:17:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a></p>
<p dir="auto">HI, Amazing work with GoogleAssist, it seems to be more responsive and accurate than AssistantMK2.</p>
<p dir="auto">Have an issue with the display of the googleAssistant banner. My Mirror is full screen, ie in custom.css i have :-</p>
<pre><code> body {
     margin: 0px;
     position: absolute;
     height: 100%;
     width: 100%;
<p dir="auto">Which i hope is correct, im struggling with css side of things !! :-)<br />
But when the banner appears i have this issue,</p>
<p dir="auto"><img src="/assets/uploads/files/1591214808408-googleassistant-resized.png" alt="GoogleAssistant.png" class=" img-fluid img-markdown" /><br />
As top of banner is missing and width</p>
<p dir="auto">I looked at GoogleAssistant.css, but couldnt work out what needs to change.</p>
]]></description><link>https://forum.magicmirror.builders/post/76481</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76481</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Wed, 03 Jun 2020 20:17:18 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Tue, 02 Jun 2020 19:00:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Thanks that has fixed it, I need to have another go at learning css to try and sort out all the positions.</p>
<p dir="auto">Ill get back to trying to sort out sound.</p>
<p dir="auto">Thanks again</p>
]]></description><link>https://forum.magicmirror.builders/post/76399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76399</guid><dc:creator><![CDATA[James Farmer]]></dc:creator><pubDate>Tue, 02 Jun 2020 19:00:06 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Tue, 02 Jun 2020 18:41:26 GMT]]></title><description><![CDATA[<p dir="auto">hi,</p>
<ol>
<li>
<p dir="auto">what the problem ?</p>
</li>
<li>
<p dir="auto">for pages:<br />
I don’t know what this developer means …<br />
edit pages.css<br />
change it to:</p>
</li>
</ol>
<pre><code class="language-js">.fullscreen.above {
    z-index: 9999
<p dir="auto">page should now works correctly</p>
]]></description><link>https://forum.magicmirror.builders/post/76398</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76398</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 02 Jun 2020 18:41:26 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Tue, 02 Jun 2020 18:29:28 GMT]]></title><description><![CDATA[<p dir="auto">First, I say thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> , I only started my mirror a few weeks and have had Assistant working.  Upgraded to GoogleAssistant and it is much quicker.</p>
<p dir="auto">Unfortunately I have a few problems with it now, one is sound, but im 99.99% sure because i have sound config wrong. Nothing to do with module. !<br />
The only other issue i have is i use pages and when googleAssisatnt comes on screen part of it is still hidden by the modules on screen.<br />
Just wondering if anyone have this problem. ?<br />
Ive set it to fullscreen_above in GoogleAssistant so thought this wouldnt be a problem. it worked ok with AssistantMK.</p>
<p dir="auto">Thankyou</p>
]]></description><link>https://forum.magicmirror.builders/post/76397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76397</guid><dc:creator><![CDATA[James Farmer]]></dc:creator><pubDate>Tue, 02 Jun 2020 18:29:28 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 23:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reddyman" aria-label="Profile: reddyman">@<bdi>reddyman</bdi></a> : don’t worry, it’s arrive to me too sometime !</p>
]]></description><link>https://forum.magicmirror.builders/post/76367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76367</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 01 Jun 2020 23:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 23:06:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> said in <a href="/post/76363">mmm assistant mk2</a>:</p>
<pre><code> config: {
    debug:true,
    // make you config there !
 // not there
<p dir="auto">…I am an idiot. Hahaha, I knew it was something super simple. Smh, thanks for putting up with idiots like me :p</p>
]]></description><link>https://forum.magicmirror.builders/post/76364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76364</guid><dc:creator><![CDATA[reddyman]]></dc:creator><pubDate>Mon, 01 Jun 2020 23:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 22:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reddyman" aria-label="Profile: reddyman">@<bdi>reddyman</bdi></a> : turn on modules. just YouTube by default is turn on<br />
link / photo is disabled by default</p>
    debug:true,
 // not there
]]></description><link>https://forum.magicmirror.builders/post/76363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76363</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 01 Jun 2020 22:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 22:39:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dvbit" aria-label="Profile: dvbit">@<bdi>dvbit</bdi></a>: no problem ! with pleasure ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/76361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76361</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 01 Jun 2020 22:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 22:36:23 GMT]]></title><description><![CDATA[<p dir="auto">A big thank You to <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> for his help in troubleshooting.<br />
It was nothing to do with the modules but with my asoundrc config.<br />
the ouput card/device were not correct.<br />
Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/76360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76360</guid><dc:creator><![CDATA[dvbit]]></dc:creator><pubDate>Mon, 01 Jun 2020 22:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 21:59:03 GMT]]></title><description><![CDATA[<p dir="auto">well, I though i’d give it a try… see what all the fuss is about!</p>
<ol>
<li>on the install y/n prompts, the protocol is the Uppercased letter is the default, so whn you hit enter is does the default<br />
it doesn’t do anything, have to enter Y or N (and then it takes off without waiting??)</li>
<li>audio doesn’t work for me…<br />
and none of the choices match the system config (and none of them work)<br />
system config, sounds fine, music, web sounds, system sounds.<br />
<img src="/assets/uploads/files/1591048655041-screenshot-at-2020-06-01-16-54-20.png" alt="Screenshot at 2020-06-01 16-54-20.png" class=" img-fluid img-markdown" /></li>
</ol>
<p dir="auto">aplay -l info<br />
<img src="/assets/uploads/files/1591048675401-screenshot-at-2020-06-01-16-54-32.png" alt="Screenshot at 2020-06-01 16-54-32.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/76359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76359</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jun 2020 21:59:03 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 21:54:33 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm sorry to go a bit off topic but has anyone tried the new Assistant2Display module with the new GoogleAssistant? I can’t get it to work but I suspect I am missing something very obvious. I just don’t know what.</p>
<p dir="auto">I can’t get the screen, briefToday, or Pir to work. I don’t get any errors, just nothing happens.</p>
<p dir="auto">Config file:</p>
<pre><code>{
   A2DServer: {
      useA2D: true,
    assistantConfig: {
      //latitude: 51.508530,
      //longitude: -0.076132,
    micConfig: { // put there configuration generated by auto-installer
      recorder: "arecord",
      device: "plughw:2",
    snowboy: {
      Model: "smart_mirror",
  module: "MMM-Assistant2Display",
    debug:true,
  pir: {
      usePir: true,
      pin: 4,
      reverseValue: false
  screen: {
  useScreen: true,
  delay: 1 * 60 * 1000,
  turnOffDisplay: true,
  ecoMode: true,
  displayCounter: true,
  text: "Auto Turn Off Screen:",
  detectorSleeping: false,
  governorSleeping: false,
  rpi4: false
briefToday: {
      useBriefToday: true,
      welcome: "brief Today"
<p dir="auto">I don’t see the debug working either? Nothing generated on the terminal while the mirror is running at least.</p>
<pre><code>[2020-06-01 16:51:49.870] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.0.0
[2020-06-01 16:51:49.885] [LOG]    [SNOWBOY] Model selected: smart_mirror
[2020-06-01 16:51:49.893] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
[2020-06-01 16:51:49.902] [LOG]    [ASSISTANT] Assistant2Display Server Started
[2020-06-01 16:51:49.908] [LOG]    [ASSISTANT] Google Assistant is initialized.
[2020-06-01 16:51:49.916] [LOG]    [A2D] MMM-Assistant2Display Version: 2.0.0
[2020-06-01 16:51:49.928] [LOG]    [A2D] Assistant2Display is initialized.
<p dir="auto">Anyone see what I’m missing? I suspect it’s something super simple but I can’t figure out what.</p>
]]></description><link>https://forum.magicmirror.builders/post/76357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76357</guid><dc:creator><![CDATA[reddyman]]></dc:creator><pubDate>Mon, 01 Jun 2020 21:54:33 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 17:35:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> nope I just grep my grep :-D</p>
]]></description><link>https://forum.magicmirror.builders/post/76346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76346</guid><dc:creator><![CDATA[dvbit]]></dc:creator><pubDate>Mon, 01 Jun 2020 17:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to mmm assistant mk2 on Mon, 01 Jun 2020 17:34:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dvbit" aria-label="Profile: dvbit">@<bdi>dvbit</bdi></a> do</p>
<pre><code>ps -ef | grep aplay
<p dir="auto">and see if its still running…</p>
]]></description><link>https://forum.magicmirror.builders/post/76345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76345</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jun 2020 17:34:15 GMT</pubDate></item></channel></rss>
