<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I change remote access address?]]></title><description><![CDATA[<p dir="auto">Can’t seem to figure out how to phrase this question, so I’m having a hard time googling it.  Running MM in a docker container, along with other containers that all want to be on port 80.  How can I change my setup so I can access MM remotely at 192.168.1.3/magic_mirror:80 rather than just 192.168.1.3:80?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12913/can-i-change-remote-access-address</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 02:11:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12913.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 May 2020 04:54:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I change remote access address? on Sun, 24 May 2020 10:55:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chemikaze" aria-label="Profile: Chemikaze">@<bdi>Chemikaze</bdi></a> not without installing another server that will map /magicmirror to some other port.</p>
<p dir="auto">the value of docker and containers is that what happens on the inside of the container can be standardized and reused without change,   while outside you can still access the app…</p>
<p dir="auto">so, the ‘design’ is that the magicmirror container would be 8080 on the inside and 2040 (or whatever) on the outside</p>
]]></description><link>https://forum.magicmirror.builders/post/75852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75852</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 May 2020 10:55:35 GMT</pubDate></item></channel></rss>
