<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar aggregation by date rather than quantity]]></title><description><![CDATA[<p dir="auto">Is it possible to configure the default calendar module, or create an alternative module, to automatically output the events contained on a calendar within a period of X days rather than output by event quantity of X?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12915/calendar-aggregation-by-date-rather-than-quantity</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 09:19:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12915.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 May 2020 09:41:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar aggregation by date rather than quantity on Sun, 24 May 2020 10:03:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerbookins" aria-label="Profile: jerbookins">@<bdi>jerbookins</bdi></a></p>
<p dir="auto">Hi,</p>
<p dir="auto">I suppose that when you play around with those 2 parameters, you will get want you want:</p>
<pre><code>maximumNumberOfDays: 7,
maximumEntries: 100,
<p dir="auto">Where <code>maximumEntries </code> is limited to the range 0 to 100, so if you are a very busy person …</p>
<p dir="auto">Good luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/75847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75847</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sun, 24 May 2020 10:03:05 GMT</pubDate></item></channel></rss>
