<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[White screen after xx time]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am using a PI2 and i have the following problem. After xxx minutes the screen will be white and blank. If i am using a remote browser i can reach the right site without any problems. That means the service is available.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1294/white-screen-after-xx-time</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 02:52:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1294.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Dec 2016 00:29:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to White screen after xx time on Mon, 16 Jan 2017 14:01:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sillec123" aria-label="Profile: Sillec123">@<bdi>Sillec123</bdi></a> I followed the steps in the <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">Autostarting Magic Mirror tutorial</a>. It was trivial to add the motion startup script to the list of processes for PM2.</p>
]]></description><link>https://forum.magicmirror.builders/post/11254</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11254</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 16 Jan 2017 14:01:43 GMT</pubDate></item><item><title><![CDATA[Reply to White screen after xx time on Mon, 16 Jan 2017 11:39:45 GMT]]></title><description><![CDATA[<p dir="auto">Not exactly sure if it helps, but you might try this module: <a href="https://github.com/MichMich/MMM-WatchDog" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MMM-WatchDog</a></p>
]]></description><link>https://forum.magicmirror.builders/post/11246</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11246</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Mon, 16 Jan 2017 11:39:45 GMT</pubDate></item><item><title><![CDATA[Reply to White screen after xx time on Mon, 16 Jan 2017 07:21:11 GMT]]></title><description><![CDATA[<p dir="auto">How do you monitoring this process? Do you have an example script for it?</p>
]]></description><link>https://forum.magicmirror.builders/post/11210</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11210</guid><dc:creator><![CDATA[Sillec123]]></dc:creator><pubDate>Mon, 16 Jan 2017 07:21:11 GMT</pubDate></item><item><title><![CDATA[Reply to White screen after xx time on Sun, 15 Jan 2017 04:30:12 GMT]]></title><description><![CDATA[<p dir="auto">I had this problem a while ago when I was playing with Motion and a Raspicam. My solution was to have PM2 monitor the Motion process and restart it whenever it would hang. The process would occasionally hang when writing to the memory card, but I’m not sure if that’s the problem in your case.</p>
<p dir="auto">Anyhow, between PM2 monitoring the Motion process and restarting it when necessary and a scheduled reboot every morning at 2AM, it haven’t had the white screen problem in months.</p>
]]></description><link>https://forum.magicmirror.builders/post/11051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11051</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sun, 15 Jan 2017 04:30:12 GMT</pubDate></item><item><title><![CDATA[Reply to White screen after xx time on Sat, 14 Jan 2017 23:10:14 GMT]]></title><description><![CDATA[<p dir="auto">No one with a solution???</p>
]]></description><link>https://forum.magicmirror.builders/post/11032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11032</guid><dc:creator><![CDATA[Sillec123]]></dc:creator><pubDate>Sat, 14 Jan 2017 23:10:14 GMT</pubDate></item></channel></rss>
