<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Tado not working.]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">I need some help, after updating to V2.11.0 the MMM-Tado module is not working, if I set module to “disable: False” everything is working ok, and after setting “Disable: true” I get a black screen with a cursor??<br />
No errors just a black screen.<br />
what dit I do;<br />
Reinstalling the MMM-Tado module.<br />
recreating config.js.<br />
and even did a complete fresh install of MM.<br />
still no luck.</p>
<p dir="auto">Running MM on Raspberry pi 3 Model b+</p>
<p dir="auto">MMM-Buienradar,   works perfect<br />
MMM-NewPIR,  works perfect<br />
MMM-NOAA3,   works perfect<br />
MMM-SimpleLogo,   works perfect<br />
MMM-SystemStats,  works perfect<br />
MMM-Tado,  Not working<br />
MMM-TomTomTrafficIncidents, works perfect.</p>
<p dir="auto">Can someone tell me where to start looking??</p>
<p dir="auto">Thanks, wrangler.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12953/mmm-tado-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 00:45:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12953.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 May 2020 13:37:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 22:17:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/woutereekhout" aria-label="Profile: WouterEekhout">@<bdi>WouterEekhout</bdi></a></p>
<p dir="auto">Already did a new install of the module, and it is working now.</p>
]]></description><link>https://forum.magicmirror.builders/post/76174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76174</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 22:17:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 22:12:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> It looks like you’ve made some changes to the <code>MMM-Tado.js</code> file.</p>
<p dir="auto">Try:</p>
<pre><code>git checkout MMM-Tado.js
git pull
]]></description><link>https://forum.magicmirror.builders/post/76173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76173</guid><dc:creator><![CDATA[WouterEekhout]]></dc:creator><pubDate>Sat, 30 May 2020 22:12:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 22:09:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/woutereekhout" aria-label="Profile: WouterEekhout">@<bdi>WouterEekhout</bdi></a></p>
<p dir="auto">Thanks,</p>
<p dir="auto">Git pull dit not work.</p>
<pre><code>pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ git pull
remote: Enumerating objects: 20, done.
remote: Counting objects: 100% (20/20), done.
remote: Compressing objects: 100% (9/9), done.
remote: Total 14 (delta 8), reused 9 (delta 5), pack-reused 0
Unpacking objects: 100% (14/14), done.
From https://github.com/WouterEekhout/MMM-Tado
   7e91b79..59a7fc1  master     -&gt; origin/master
 * [new branch]      2020-june  -&gt; origin/2020-june
Updating 7e91b79..59a7fc1
error: Your local changes to the following files would be overwritten by merge:
	MMM-Tado.js
Please commit your changes or stash them before you merge.
Aborting
<p dir="auto">But after removing MMM-Tado and reinstalling it works.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/76172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76172</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 22:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 20:27:11 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the feedback. The master-branch has been updated. After <code>git pull</code>, do a <code>npm install</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/76164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76164</guid><dc:creator><![CDATA[WouterEekhout]]></dc:creator><pubDate>Sat, 30 May 2020 20:27:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 16:06:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">:thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/76152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76152</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 16:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 15:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> I added this topic to the issue already open on the node-modules libraries<br />
<a href="https://github.com/WouterEekhout/MMM-Tado/issues/8" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/WouterEekhout/MMM-Tado/issues/8</a></p>
]]></description><link>https://forum.magicmirror.builders/post/76150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76150</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 May 2020 15:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 15:07:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks for the effort, I wait for a update or try to live with it :confused_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/76147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76147</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 15:07:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 14:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> yep, looks like he used a private tado-client module… there is a public node-tado-client , but some of the code would have to change…</p>
<p dir="auto">sorry…</p>
]]></description><link>https://forum.magicmirror.builders/post/76146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76146</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 May 2020 14:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 14:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/76143">MMM-Tado not working.</a>:</p>
<p dir="auto">No luck ```</p>
<pre><code>pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install tado-client --save
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/tado-client - Not found
npm ERR! 404
npm ERR! 404  'tado-client@latest' is not in the npm registry.
npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR!     /home/pi/.npm/_logs/2020-05-30T14_54_13_631Z-debug.log
<pre><code>pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install mocha-logger --save
npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
+ mocha-logger@1.0.6
removed 3 packages, updated 1 package and audited 1120 packages in 37.011s
74 packages are looking for funding
  run `npm fund` for details
found 3 low severity vulnerabilities
  run `npm audit fix` to fix them, or `npm audit` for details
]]></description><link>https://forum.magicmirror.builders/post/76145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76145</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 14:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 14:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> ok, got it…</p>
<p dir="auto">MMM-Tado has a bug really… it USES stuff but doesn’t document them</p>
<p dir="auto">const TadoClient = require(“tado-client”);<br />
const logger = require(“mocha-logger”);</p>
<p dir="auto">but there is no package.json, and he loads a previous copy of node_modules in his folder which is now out of synch</p>
<p dir="auto">so, you need to do these updates manually</p>
<pre><code>cd MMM-Tado
rm -rf node_modules
rm package-lock.json
<p dir="auto">then you can restart MM and it should work…</p>
<p dir="auto">my script looks for package.json, and there isn’t one…</p>
]]></description><link>https://forum.magicmirror.builders/post/76143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76143</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 May 2020 14:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 14:36:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">First time I used you’re script, everything was working fine except the MMM-Tado module after the update.<br />
then I did a fresh install using you’re install script and started from scratch so I don’t think the log will give you the info you need but here it is:</p>
<pre><code>
pi@MagicMirror:~/MagicMirror/installers $ nano upgrade.log
  GNU nano 3.2        upgrade.log
   installers/mm.sh
   package-lock.json
save/restore files selection = n
restoring installers/mm.sh from repo
restoring package-lock.json from repo
test merge result rc='' , if empty, no conflicts
executing merge, apply specified
merge result rc= 0
 Already up to date.
processor architecture is armv7l
updating MagicMirror runtime, please wait
&gt; electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
&gt; node install.js
Downloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
[&gt;                                            ] 0.0% (0 B/s)
^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0K^&lsqb;&lsqb;1A^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0K^&lsqb;&lsqb;1A^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0KDownloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
&lt;####&gt;
^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0K^&lsqb;&lsqb;1A^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0K^&lsqb;&lsqb;1A^&lsqb;&lsqb;1000D^&lsqb;&lsqb;0KDownloading tmp-2885-1-SHASUMS256.txt-6.1.7
[============================================&gt;] 100.0% of 5.56 kB (5.56 kB/s)
&gt; magicmirror@2.11.0 install /home/pi/MagicMirror
&gt; echo "Installing vendor files ...
" &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error
audited 150 packages in 6.864s
found 8 vulnerabilities (7 low, 1 high)
&gt; magicmirror@2.11.0 postinstall /home/pi/MagicMirror
&gt; npm run install-fonts &amp;&amp; echo "MagicMirror installation finished successfully!
&gt; magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
&gt; echo "Installing fonts ...
" &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error
audited 1 package in 0.877s
found 0 vulnerabilities
added 3 packages from 39 contributors, removed 1 package, updated 30 packages and audited 1031 packages in 136.887s
11 packages are looking for funding
found 27 vulnerabilities (24 low, 3 moderate)
npm install completed - do mei 14 20:53:51 CEST 2020 on base
fixing sandbox permissions
downloading dumpactivemodules script
processing dependency changes for active modules with package.json files
processing for module MMM-Buienradar please wait
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN MMM-Buienradar@1.0.1 No repository field.
up to date in 1.353s
processing complete for module MMM-Buienradar
processing for module MMM-NewPIR please wait
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
&gt; epoll@3.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
&gt; node-gyp rebuild
make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt binnengegaan
  CXX(target) Release/obj.target/epoll/src/epoll.o
  SOLINK_MODULE(target) Release/obj.target/epoll.node
  COPY Release/epoll.node
make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt verlaten
&gt; MMM-NewPIR@2.3.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
&gt; scripts/installer.sh
+ electron-rebuild@1.11.0
updated 1 package and audited 171 packages in 28.741s
- Searching dependency tree
✔ Rebuild Complete
added 171 packages from 120 contributors and audited 171 packages in 127.848s
2 packages are looking for funding
processing complete for module MMM-NewPIR
processing for module MMM-NOAA3 please wait
added 83 packages from 74 contributors and audited 83 packages in 11.955s
processing complete for module MMM-NOAA3
processing for module MMM-SystemStats please wait
added 1 package from 1 contributor and audited 1 package in 1.621s
processing complete for module MMM-SystemStats
restoring custom.css
removing git alias
Upgrade ended - do mei 14 20:57:27 CEST 2020
Upgrade started - do mei 14 21:02:17 CEST 2020
system is Linux MagicMirror 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
user requested to force apply changes
doing test run = false
saving custom.css
remote name = origin
upgrading from version 2.11.0 to 2.11.0
fetching latest revisions
git fetch rc=0
current branch = master
On branch master
Your branch is up to date with 'origin/master'.
Changes not staged for commit:
  (use "git add &lt;file&gt;..." to update what will be committed)
  (use "git checkout -- &lt;file&gt;..." to discard changes in working directory)
        modified:   package-lock.json
        modified:   package.json
Untracked files:
  (use "git add &lt;file&gt;..." to include in what will be committed)
        css/save_custom.css
        installers/pm2_MagicMirror.json
        run-start.sh
no changes added to commit (use "git add" and/or "git commit -a")
there are 2 local files that are different than the master repo
   package-lock.json
   package.json
restoring package.json from repo
merge result rc= 0
 Already up to date.
audited 150 packages in 7.296s
audited 1 package in 0.849s
added 3 packages from 3 contributors, removed 20 packages, updated 3 packages and audited 1031 packages in 59.72s
npm install completed - do mei 14 21:03:28 CEST 2020 on base
up to date in 1.384s
updated 1 package and audited 171 packages in 23.5s
✔ Rebuild Complete
added 171 packages from 120 contributors and audited 171 packages in 84.616s
added 83 packages from 74 contributors and audited 83 packages in 12.286s
added 1 package from 1 contributor and audited 1 package in 3.883s
removing git alias
Upgrade ended - do mei 14 21:06:07 CEST 2020
Upgrade started - zo mei 17 08:02:04 CEST 2020
user requested to apply changes
saving custom.css
local version 2.11.0 already same as master 2.11.0
removing git alias
Upgrade ended - zo mei 17 08:02:05 CEST 2020
Upgrade started - do mei 21 08:02:38 CEST 2020
saving custom.css
removing git alias
Upgrade ended - do mei 21 08:02:39 CEST 2020
Upgrade started - za mei 23 07:56:26 CEST 2020
saving custom.css
removing git alias
Upgrade ended - za mei 23 07:56:27 CEST 2020
Upgrade started - vr mei 29 23:01:44 CEST 2020
saving custom.css
removing git alias
Upgrade ended - vr mei 29 23:01:45 CEST 2020
]]></description><link>https://forum.magicmirror.builders/post/76142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76142</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 14:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 13:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> i don’t know what that means…   just now or before?<br />
show me the ~/MagicMirror/installers/upgrade.log</p>
]]></description><link>https://forum.magicmirror.builders/post/76140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76140</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 May 2020 13:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 13:52:17 GMT]]></title><description><![CDATA[<p dir="auto">I updated using you’re update script ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/76139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76139</guid><dc:creator><![CDATA[Wrangler]]></dc:creator><pubDate>Sat, 30 May 2020 13:52:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Tado not working. on Sat, 30 May 2020 13:49:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrangler" aria-label="Profile: Wrangler">@<bdi>Wrangler</bdi></a> how did u update to  2.11?  there were dependency changes that force you to find each module with a package.json file and do an npm install in each such module folder</p>
<p dir="auto">if u had used the new upgrade script, this would have been done for you<br />
see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/76138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76138</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 May 2020 13:49:26 GMT</pubDate></item></channel></rss>
