<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 ..]]></title><description><![CDATA[<pre><code class="language-npm">
&gt; magicmirror@2.11.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[2020-05-31 00:45:38.521] [LOG]    Starting MagicMirror: v2.11.0
[2020-05-31 00:45:38.527] [LOG]    Loading config ...
[2020-05-31 00:45:38.530] [LOG]    Loading module helpers ...
[2020-05-31 00:45:38.532] [LOG]    No helper found for module: alert.
[2020-05-31 00:45:38.570] [LOG]    Initializing new module helper ...
[2020-05-31 00:45:38.571] [LOG]    Module helper loaded: updatenotification
[2020-05-31 00:45:38.572] [LOG]    No helper found for module: clock.
[2020-05-31 00:45:38.839] [LOG]    Initializing new module helper ...
[2020-05-31 00:45:38.840] [LOG]    Module helper loaded: calendar
[2020-05-31 00:45:38.840] [LOG]    No helper found for module: compliments.
[2020-05-31 00:45:39.423] [LOG]    Initializing new module helper ...
[2020-05-31 00:45:39.423] [LOG]    Module helper loaded: MMM-AssistantMk2
[2020-05-31 00:45:39.424] [LOG]    No helper found for module: currentweather.
[2020-05-31 00:45:39.424] [LOG]    No helper found for module: weatherforecast.
[2020-05-31 00:45:39.443] [LOG]    Initializing new module helper ...
[2020-05-31 00:45:39.443] [LOG]    Module helper loaded: newsfeed
[2020-05-31 00:45:39.444] [LOG]    All module helpers loaded.
[2020-05-31 00:45:39.524] [LOG]    Starting server on port 8080 ...
[2020-05-31 00:45:39.534] [LOG]    Server started ...
[2020-05-31 00:45:39.535] [LOG]    Connecting socket for: updatenotification
[2020-05-31 00:45:39.536] [LOG]    Connecting socket for: calendar
[2020-05-31 00:45:39.536] [LOG]    Starting node helper for: calendar
[2020-05-31 00:45:39.537] [LOG]    Connecting socket for: MMM-AssistantMk2
[2020-05-31 00:45:39.538] [LOG]    Connecting socket for: newsfeed
[2020-05-31 00:45:39.538] [LOG]    Starting module: newsfeed
[2020-05-31 00:45:39.539] [LOG]    Sockets connected &amp; modules started ...
[2020-05-31 00:45:39.615] [LOG]    Launching application.
[2020-05-31 00:45:41.192] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
[2020-05-31 00:45:41.256] [LOG]    [AMK2] Recipe is loaded: hide_and_show_all_modules.js
[2020-05-31 00:45:41.260] [LOG]    [AMK2] Recipe is loaded: reboot.js
[2020-05-31 00:45:41.262] [LOG]    [AMK2] Recipe is loaded: screen_onoff.js
[2020-05-31 00:45:41.264] [LOG]    [AMK2] Recipe is loaded: shutdown.js
[2020-05-31 00:45:41.265] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
[2020-05-31 00:45:41.345] [LOG]    [AMK2] Temporal storage directory is clearing.
[2020-05-31 00:45:42.117] [LOG]    [AMK2] assistant ready
/home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
npm ERR! code ELIFECYCLE
npm ERR! syscall spawn
npm ERR! file sh
npm ERR! errno ENOENT
npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
npm ERR! spawn ENOENT
npm ERR!
npm ERR! Failed at the magicmirror@2.11.0 start script.
npm ERR!     /home/pi/.npm/_logs/2020-05-30T19_15_42_192Z-debug.log
]]></description><link>https://forum.magicmirror.builders/topic/12955/i-cant-figure-out-what-i-did-wrong-fresh-installation-of-raspberry-pi-os-on-raspberry-pi4</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 22:24:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12955.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 May 2020 19:19:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 .. on Fri, 10 Jul 2020 13:03:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have deprecied MMM-AssistantMk2 and will still in a very old version.<br />
Maybe using <a href="https://forum.magicmirror.builders/topic/12324/mmm-googleassistant-mmm-assistant2display">MMM-GoogleAssistant / MMM-Assistant2Display</a> can help for a modern assistant</p>
]]></description><link>https://forum.magicmirror.builders/post/78280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78280</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 10 Jul 2020 13:03:31 GMT</pubDate></item><item><title><![CDATA[Reply to i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 .. on Fri, 10 Jul 2020 10:40:58 GMT]]></title><description><![CDATA[<p dir="auto">THankyou so much for sharing.</p>
]]></description><link>https://forum.magicmirror.builders/post/78278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78278</guid><dc:creator><![CDATA[Yousbantor1951]]></dc:creator><pubDate>Fri, 10 Jul 2020 10:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 .. on Sun, 31 May 2020 02:48:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> said in <a href="/post/76162">i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 ..</a>:</p>
<p dir="auto">by look of it AssistantMK2 is to be replaced.</p>
<p dir="auto">What do you mean? That a new version will come out?</p>
]]></description><link>https://forum.magicmirror.builders/post/76177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76177</guid><dc:creator><![CDATA[reddyman]]></dc:creator><pubDate>Sun, 31 May 2020 02:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 .. on Sat, 30 May 2020 19:31:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: JohnBachini">@<bdi>JohnBachini</bdi></a> yeah i thought fresh installation and changing the config would help…</p>
]]></description><link>https://forum.magicmirror.builders/post/76163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76163</guid><dc:creator><![CDATA[sdmydbr9]]></dc:creator><pubDate>Sat, 30 May 2020 19:31:17 GMT</pubDate></item><item><title><![CDATA[Reply to i cant figure out what i did wrong, fresh installation of raspberry pi os on raspberry pi4 .. on Sat, 30 May 2020 19:30:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdmydbr9" aria-label="Profile: sdmydbr9">@<bdi>sdmydbr9</bdi></a>  Haven’t you posted this already ?, anyways you may want to wait, by look of it AssistantMK2 is to be replaced.</p>
]]></description><link>https://forum.magicmirror.builders/post/76162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76162</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Sat, 30 May 2020 19:30:08 GMT</pubDate></item></channel></rss>
