<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Awesome-Alexa Trouble]]></title><description><![CDATA[<p dir="auto">Hey! I was wondering if anyone could help me figure out how to fix this. When I startup the mirror I get this error and the screen is just pitch black with no modules. Any help would be appreciated, thanks!</p>
<p dir="auto">WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module<br />
‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js</li>
<li>/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/12975/mmm-awesome-alexa-trouble</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 16:55:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12975.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Jun 2020 05:42:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 26 Jan 2021 19:44:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jste84" aria-label="Profile: jste84">@<bdi>jste84</bdi></a>   I have no issues since I used Sam’s steps</p>
]]></description><link>https://forum.magicmirror.builders/post/87842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87842</guid><dc:creator><![CDATA[shagtimetim]]></dc:creator><pubDate>Tue, 26 Jan 2021 19:44:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 26 Jan 2021 19:42:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shagtimetim" aria-label="Profile: shagtimetim">@<bdi>shagtimetim</bdi></a> you got this module working?</p>
]]></description><link>https://forum.magicmirror.builders/post/87840</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87840</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Tue, 26 Jan 2021 19:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 26 Jan 2021 13:45:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>   Thank you!!  Everything now working as designed.  One day, I will learn json!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/87833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87833</guid><dc:creator><![CDATA[shagtimetim]]></dc:creator><pubDate>Tue, 26 Jan 2021 13:45:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 25 Jan 2021 03:05:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shagtimetim" aria-label="Profile: shagtimetim">@<bdi>shagtimetim</bdi></a> it will do that  just hang on,<br />
all this does is take the steps on the wiki make them run in a script</p>
<p dir="auto">it does fix one dependency correction</p>
<p dir="auto">this is what my stuff does just a copy/paste<br />
<a href="https://awesome-alexa.js.org/#/installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://awesome-alexa.js.org/#/installation</a></p>
]]></description><link>https://forum.magicmirror.builders/post/87772</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87772</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Jan 2021 03:05:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 25 Jan 2021 02:44:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>   Thank you!  Installing now.  Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?</p>
]]></description><link>https://forum.magicmirror.builders/post/87770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87770</guid><dc:creator><![CDATA[shagtimetim]]></dc:creator><pubDate>Mon, 25 Jan 2021 02:44:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 25 Jan 2021 01:39:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shagtimetim" aria-label="Profile: shagtimetim">@<bdi>shagtimetim</bdi></a> i created a script of his steps,<br />
make executable.<br />
<a href="https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">doinstall.sh</a></p>
<p dir="auto">does all the module install steps, so remove the current awesome-alexa module folder,   ignore the errors, only result of last step matters</p>
]]></description><link>https://forum.magicmirror.builders/post/87768</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87768</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Jan 2021 01:39:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 25 Jan 2021 00:42:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
The information related to the capitalization is found on the developers install page.  He specifically calls out “MMM-awesome-alexa”.  However, I have yet to get this module to function.  Each time I add to the MM config, the black screen with cursor appears.</p>
]]></description><link>https://forum.magicmirror.builders/post/87766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87766</guid><dc:creator><![CDATA[shagtimetim]]></dc:creator><pubDate>Mon, 25 Jan 2021 00:42:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 04 Jan 2021 22:47:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hectoreg21" aria-label="Profile: hectoreg21">@<bdi>hectoreg21</bdi></a> unless u are following some old workbook of instructions</p>
]]></description><link>https://forum.magicmirror.builders/post/86736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86736</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Jan 2021 22:47:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 04 Jan 2021 22:23:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.</p>
<p dir="auto">And thanks for the reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/86735</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86735</guid><dc:creator><![CDATA[hectoreg21]]></dc:creator><pubDate>Mon, 04 Jan 2021 22:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 04 Jan 2021 22:15:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hectoreg21" aria-label="Profile: hectoreg21">@<bdi>hectoreg21</bdi></a> but when u git clone it uses the project name  so this shouldn’t happen</p>
]]></description><link>https://forum.magicmirror.builders/post/86734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86734</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Jan 2021 22:15:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Mon, 04 Jan 2021 22:06:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.</p>
<p dir="auto">Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.</p>
<p dir="auto">It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.</p>
<p dir="auto">Let me know if this helped you!</p>
<p dir="auto">Have fun!!</p>
]]></description><link>https://forum.magicmirror.builders/post/86733</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86733</guid><dc:creator><![CDATA[hectoreg21]]></dc:creator><pubDate>Mon, 04 Jan 2021 22:06:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Wed, 03 Jun 2020 02:07:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xfqbe" aria-label="Profile: xfqbe">@<bdi>xfqbe</bdi></a> no. the instructions in the module.</p>
<p dir="auto">i compiled fine</p>
<p dir="auto">see the readme</p>
]]></description><link>https://forum.magicmirror.builders/post/76408</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76408</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Jun 2020 02:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Wed, 03 Jun 2020 01:21:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> The electron-rebuild was normal without any error codes and yes I followed these steps. <a href="https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/76407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76407</guid><dc:creator><![CDATA[xfqbe]]></dc:creator><pubDate>Wed, 03 Jun 2020 01:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Wed, 03 Jun 2020 01:10:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xfqbe" aria-label="Profile: xfqbe">@<bdi>xfqbe</bdi></a> did u do all the instruction steps? some 15 of them</p>
]]></description><link>https://forum.magicmirror.builders/post/76406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76406</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Jun 2020 01:10:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 02 Jun 2020 23:11:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xfqbe" aria-label="Profile: xfqbe">@<bdi>xfqbe</bdi></a> not really.</p>
<p dir="auto">what did the electron-rebuild say?</p>
]]></description><link>https://forum.magicmirror.builders/post/76403</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76403</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jun 2020 23:11:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 02 Jun 2020 22:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for replying, I did exactly what you said correctly and it’s still showing the same errors :/ Is there anything else I should try? or maybe a different Alexa module?</p>
<p dir="auto">WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’<br />
Require stack:</p>
<ul>
<li></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/76402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76402</guid><dc:creator><![CDATA[xfqbe]]></dc:creator><pubDate>Tue, 02 Jun 2020 22:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Awesome-Alexa Trouble on Tue, 02 Jun 2020 12:00:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xfqbe" aria-label="Profile: xfqbe">@<bdi>xfqbe</bdi></a> maybe</p>
<p dir="auto">do</p>
<pre><code>cd ~/MagicMirror
npm install electron-rebuild
cd modules/MMM-Awesome-Alexa
~/MagicMirror/node_modules/.bin/electron-rebuild
<p dir="auto">let us know</p>
]]></description><link>https://forum.magicmirror.builders/post/76375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76375</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jun 2020 12:00:48 GMT</pubDate></item></channel></rss>
