<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Admin-Interface]]></title><description><![CDATA[<p dir="auto">Hey everyone<br />
I created a new module, to be able to edit the MM configuration from the browser<br />
[card:ItayXD/MMM-Admin-Interface]<br />
Would appreciate any input, hope you’ll enjoy it!</p>
]]></description><link>https://forum.magicmirror.builders/topic/1300/mmm-admin-interface</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 13:37:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1300.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Dec 2016 19:25:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Admin-Interface on Sun, 09 Dec 2018 18:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rockcitiman" aria-label="Profile: rockcitiman">@<bdi>rockcitiman</bdi></a> I had to modify the <strong>address:</strong> line above the <strong>ipWhitelist:</strong> entry as <a class="plugin-mentions-user plugin-mentions-a" href="/user/sandy2503" aria-label="Profile: Sandy2503">@<bdi>Sandy2503</bdi></a> alluded. My line became:</p>
<pre><code>address: ["localhost", "0.0.0.0"],
<p dir="auto">the <strong>localhost</strong> may be redundant with the <strong>0.0.0.0</strong>, but it works nonetheless (the interface). But … the writing of the config file is in a format that bunged up my mm so it fails to display anything.</p>
]]></description><link>https://forum.magicmirror.builders/post/47901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47901</guid><dc:creator><![CDATA[Arkitct]]></dc:creator><pubDate>Sun, 09 Dec 2018 18:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Mon, 24 Sep 2018 21:18:17 GMT]]></title><description><![CDATA[<p dir="auto">Are you still developing this module?  I followed all of the instructions but I get nothing.</p>
<p dir="auto"><img src="/assets/uploads/files/1537823886667-02264199-a14c-49fd-abcd-ccc0f9dbf270-image.png" alt="0_1537823886136_02264199-a14c-49fd-abcd-ccc0f9dbf270-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/44722</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44722</guid><dc:creator><![CDATA[rockcitiman]]></dc:creator><pubDate>Mon, 24 Sep 2018 21:18:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Tue, 19 Dec 2017 21:12:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shimue" aria-label="Profile: shimue">@<bdi>shimue</bdi></a> - na dann hast DU das hier ja auch in deiner config.js stehen:</p>
<pre><code>address:"0.0.0.0",
<p dir="auto">und achte mal auf deinen Ton …</p>
<p dir="auto">Sandy2503</p>
]]></description><link>https://forum.magicmirror.builders/post/32496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32496</guid><dc:creator><![CDATA[Sandy2503]]></dc:creator><pubDate>Tue, 19 Dec 2017 21:12:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Tue, 19 Dec 2017 20:12:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shimue" aria-label="Profile: shimue">@<bdi>shimue</bdi></a> search for ip whitelist on the forum, there plenty of threads</p>
]]></description><link>https://forum.magicmirror.builders/post/32492</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32492</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 19 Dec 2017 20:12:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 02 Dec 2017 22:16:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rubenlaureys" aria-label="Profile: rubenlaureys">@<bdi>rubenlaureys</bdi></a><br />
I’m not sure what you mean, there should be a tab list with the modules names on the left like in this photo:<br />
<img src="/assets/uploads/files/1512252933277-75807090-9cae-4d90-a125-f69a2eb1ffd0-image.png" alt="0_1512252932469_75807090-9cae-4d90-a125-f69a2eb1ffd0-image.png" class=" img-fluid img-markdown" /><br />
is this not the case?</p>
]]></description><link>https://forum.magicmirror.builders/post/31859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31859</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 02 Dec 2017 22:16:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Tue, 28 Nov 2017 18:31:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I love your module!<br />
I use it to modify my MagicMirror.</p>
<p dir="auto">But, is there a way to choose a module from a list, instead of entering the name myself?<br />
<img src="/assets/uploads/files/1511893804678-mmm.png" alt="0_1511893804705_MMM.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I want a dropdown list, just like the list of positions.</p>
<p dir="auto">Is this possible?</p>
<p dir="auto">Thank you.</p>
<p dir="auto">Have a great day,<br />
Ruben</p>
]]></description><link>https://forum.magicmirror.builders/post/31710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31710</guid><dc:creator><![CDATA[rubenlaureys]]></dc:creator><pubDate>Tue, 28 Nov 2017 18:31:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sun, 01 Jan 2017 18:41:36 GMT]]></title><description><![CDATA[<p dir="auto">You might also have to add <code>"::ffff:192.168.X.Y"</code> as well.  You could also just add <code>"192.168.X.1/24  , ::ffff:192.168.X.1/24"</code> to whitelist all of the IPs in your network (assuming you are using 192.168.X.1-254).</p>
]]></description><link>https://forum.magicmirror.builders/post/10141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10141</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sun, 01 Jan 2017 18:41:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sun, 01 Jan 2017 17:35:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi try putting your laptop’s up it the whitelist, it should probably by 192.168.X.X</p>
]]></description><link>https://forum.magicmirror.builders/post/10132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10132</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sun, 01 Jan 2017 17:35:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sun, 01 Jan 2017 15:57:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello, i made the MM2 update and now i can’t access the admin</p>
<pre><code>ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
<p dir="auto">I can’t insert my ip from my laptop.<br />
I want to access MagicMirror from laptop with Admin-Interface, but it’s not possible now with this update.</p>
<p dir="auto">Where i have to insert my ip address in the white-list?<br />
How to insert a range?</p>
]]></description><link>https://forum.magicmirror.builders/post/10130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10130</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sun, 01 Jan 2017 15:57:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 16:59:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> Thanks for suggesting the Nav bar, i installed the module working great</p>
]]></description><link>https://forum.magicmirror.builders/post/10107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10107</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sat, 31 Dec 2016 16:59:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:47:44 GMT]]></title><description><![CDATA[<p dir="auto">im an idiot, it was still commented out in the config.js thanks for your help, it works great!</p>
]]></description><link>https://forum.magicmirror.builders/post/10099</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10099</guid><dc:creator><![CDATA[wrumble]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrumble" aria-label="Profile: wrumble">@<bdi>wrumble</bdi></a><br />
can you post your config.js? you can send a link to <a href="http://pastebin.com/" target="_blank" rel="noopener noreferrer nofollow ugc">pastebin</a>. can you also run <code>git status</code> in the module directory and post the output?<br />
it might also be useful if you post the output in the terminal when you start the MM (<code>npm start</code>).</p>
]]></description><link>https://forum.magicmirror.builders/post/10098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10098</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:26:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/itayxd" aria-label="Profile: ItayXD">@<bdi>ItayXD</bdi></a> thanks for your help! I have the mirror running now but when i try to access the interface i get <code>Cannot GET /MMM-Admin-Interface/</code> when i go to <code>http://192.168.0.13:8080/MMM-Admin-Interface/</code> i have MMM-Remote-Control and when i access <code>http://192.168.0.13:8080/remote.html</code> it woks fine, any ideas why its not working? i dont get any errors in terminal</p>
]]></description><link>https://forum.magicmirror.builders/post/10097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10097</guid><dc:creator><![CDATA[wrumble]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:19:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> thank you. there is a great module called <code>MMM-Remote-Control</code> that does just that. I believe there is a module request forum, if you have any other requests</p>
]]></description><link>https://forum.magicmirror.builders/post/10096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10096</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:19:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:15:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> there is one already, mmm-navbar</p>
]]></description><link>https://forum.magicmirror.builders/post/10095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10095</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:15:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 12:03:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/itayxd" aria-label="Profile: ItayXD">@<bdi>ItayXD</bdi></a> Hi, I installed the module works great, can you help me in creating module to hide and unhide each module on a touch screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/10094</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10094</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sat, 31 Dec 2016 12:03:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:31:51 GMT]]></title><description><![CDATA[<p dir="auto">Fixed, please try running <code>git pull &amp;&amp; npm install --only=production</code> in the module directory</p>
]]></description><link>https://forum.magicmirror.builders/post/10093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10093</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:23:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a>  it seems my package.json is invalid will fix that</p>
]]></description><link>https://forum.magicmirror.builders/post/10092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10092</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:23:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:21:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/itayxd" aria-label="Profile: ItayXD">@<bdi>ItayXD</bdi></a></p>
<p dir="auto">i do that step, but it doesn’t work.</p>
<p dir="auto">i mean the npm install in the Admin folder.</p>
<p dir="auto">Only after i install the missing files manually.</p>
]]></description><link>https://forum.magicmirror.builders/post/10091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10091</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:32:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi sorry I forgot to add install dependencies part to the readme.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/wrumble" aria-label="Profile: wrumble">@<bdi>wrumble</bdi></a> please run <code>cd ~/Desktop/MagicMirror/modules/MMM-Admin-Interface &amp;&amp;  git pull &amp;&amp; npm install --only=production</code><br />
It should work</p>
]]></description><link>https://forum.magicmirror.builders/post/10090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10090</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:32:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:05:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/itayxd" aria-label="Profile: ItayXD">@<bdi>ItayXD</bdi></a></p>
<p dir="auto">No, sorry.<br />
I’m only a small and unknown user.</p>
]]></description><link>https://forum.magicmirror.builders/post/10089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10089</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:05:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Admin-Interface on Sat, 31 Dec 2016 11:04:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> Thanks for your note on the port I’ll fix it.<br />
Do you have any idea why body-parser isn’t installed automatically? I thought it should be…</p>
]]></description><link>https://forum.magicmirror.builders/post/10088</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10088</guid><dc:creator><![CDATA[ItayXD]]></dc:creator><pubDate>Sat, 31 Dec 2016 11:04:02 GMT</pubDate></item></channel></rss>
