<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pi Freezes]]></title><description><![CDATA[<p dir="auto">hi,<br />
my pi freezes almost every 3 hours.<br />
I guess its about the Modules I use; I would suspect MMM-GroveGesture or Pages.</p>
<p dir="auto">Please tell me what Information I should share with you :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/13013/pi-freezes</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 09:22:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13013.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jun 2020 16:25:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pi Freezes on Sat, 06 Jun 2020 18:00:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rxldavid" aria-label="Profile: rxlDavid">@<bdi>rxlDavid</bdi></a> disable all the 3rd Party modules and enable them one by one to see which module causes to freeze the MM. That is the he easiest approacjh. If you suspect GroveGestures and pages then disable them first, restart MM and see what happens. From my experience it’s not to blame only one module. It happens that the combination of two modules that don’t play well together can be the cause. I had this recently with MMM- Rain-Map and MMM-Google-routes. Each of them runs fine, both together let my RPi freeze.</p>
]]></description><link>https://forum.magicmirror.builders/post/76688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76688</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sat, 06 Jun 2020 18:00:33 GMT</pubDate></item><item><title><![CDATA[Reply to Pi Freezes on Sat, 06 Jun 2020 17:24:47 GMT]]></title><description><![CDATA[<ul>
<li>default modules like clock calendar…</li>
<li>internet-monitor</li>
<li>MMM-GroveGestures</li>
<li>MMM-Mail</li>
<li>MMM-page-indicator</li>
<li>MMM-pages</li>
<li>MMM-PublicTransportHafas</li>
<li>MMM-quote-of-the-day</li>
<li>MMM-SystemStats</li>
<li>MMM-WiFiPassword</li>
</ul>
<p dir="auto">and some other which i dont use, i will uninstall them later -done</p>
]]></description><link>https://forum.magicmirror.builders/post/76685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76685</guid><dc:creator><![CDATA[rxlDavid]]></dc:creator><pubDate>Sat, 06 Jun 2020 17:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to Pi Freezes on Sat, 06 Jun 2020 16:36:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rxldavid" aria-label="Profile: rxlDavid">@<bdi>rxlDavid</bdi></a> which other modules are installed?</p>
]]></description><link>https://forum.magicmirror.builders/post/76684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76684</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sat, 06 Jun 2020 16:36:07 GMT</pubDate></item></channel></rss>
