<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding more Compliments]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">So I want to be able lots of compliments on my mirror, is this possible? I have changed the existing ones but when I add more the module doesn’t work. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13073/adding-more-compliments</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 03:43:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13073.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jun 2020 18:37:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding more Compliments on Sat, 20 Jun 2020 14:54:34 GMT]]></title><description><![CDATA[<p dir="auto">@hango Thanks so much, that is what I was missing :)</p>
]]></description><link>https://forum.magicmirror.builders/post/77349</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77349</guid><dc:creator><![CDATA[xxLulaBelle]]></dc:creator><pubDate>Sat, 20 Jun 2020 14:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to Adding more Compliments on Sat, 20 Jun 2020 11:24:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xxlulabelle" aria-label="Profile: xxLulaBelle">@<bdi>xxLulaBelle</bdi></a> no, should work,</p>
<p dir="auto">you are supposed to edit the config.js and add the config data for the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/77344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77344</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 Jun 2020 11:24:42 GMT</pubDate></item><item><title><![CDATA[Reply to Adding more Compliments on Sat, 20 Jun 2020 08:58:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry for late reply. I literally just added a new quote under what was there but I’m guessing there is code somewhere else that I need to adjust in order to add those extra lines?</p>
]]></description><link>https://forum.magicmirror.builders/post/77341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77341</guid><dc:creator><![CDATA[xxLulaBelle]]></dc:creator><pubDate>Sat, 20 Jun 2020 08:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to Adding more Compliments on Sun, 14 Jun 2020 18:39:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xxlulabelle" aria-label="Profile: xxLulaBelle">@<bdi>xxLulaBelle</bdi></a> yes, you  can add more…    show us what you did to add more…</p>
<p dir="auto">use the code block (&lt;/&gt;) to mark the text</p>
]]></description><link>https://forum.magicmirror.builders/post/77065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77065</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Jun 2020 18:39:19 GMT</pubDate></item></channel></rss>
