<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Customized frames for MM]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I am wondering if anyone here have any experience with any companies that are able to make a MM frame? I have looked around from time to time, but I mostly only find frames that is thin or dont have the necessary breath for a MM to be behind the glass.</p>
<p dir="auto">I dont want to make my own frame (mostly because I’m not a very good woodworker, and I dont want the MM to look rubbish with a bad frame), and are therefore looking for other solutions.</p>
<p dir="auto">It would also be necessary for the frame to be shipped to Norway.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13104/customized-frames-for-mm</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 01:57:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13104.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jun 2020 23:36:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Customized frames for MM on Tue, 23 Jun 2020 21:14:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
another idea may be to look at a kitchen-store. Maybe they have a used kitchen-unit with a glas-window you can take as a front-frame. The frame behind is much easier to built because you need no miter. Just buy the wood for the back-frame in a hardware-store, ask them to cut it into pieces. Paint it as you like, should not be so expensive.</p>
]]></description><link>https://forum.magicmirror.builders/post/77489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77489</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Tue, 23 Jun 2020 21:14:14 GMT</pubDate></item><item><title><![CDATA[Reply to Customized frames for MM on Fri, 19 Jun 2020 21:35:29 GMT]]></title><description><![CDATA[<p dir="auto">I’m using a standard photo aluminium frame for my mirror. The monitor covers only the bottom half of the mirror. The problem is that this construction needs to be placed on a board or something else, the monitor inside the frame is to heavy for the frame.</p>
<p dir="auto"><img src="https://live.staticflickr.com/3824/33096408715_00f824062e_c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/77324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77324</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Fri, 19 Jun 2020 21:35:29 GMT</pubDate></item><item><title><![CDATA[Reply to Customized frames for MM on Fri, 19 Jun 2020 07:01:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/77280">Customized frames for MM</a>:</p>
<p dir="auto">@adrian-k are there any wood working groups near you?  that might make one for you?  or metal working,  or…</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> said in <a href="/post/77281">Customized frames for MM</a>:</p>
<p dir="auto">You may have luck checking with the local school shop class and/or technical college. People learning how to use the tools can easily make the frame for a monitor. I’m not familiar with Norway’s educational system, but someone has to make furniture and they have to learn somewhere. Find them.</p>
<p dir="auto">Thank for both of your suggestions! Local schools are closed until the end of summer atm, but if I cant find someone to help me out with it I might try there when they open.</p>
<p dir="auto">I checked out with a local company that could make one for me, but the best price that I got was 430 USD, and thats way to much imo.</p>
]]></description><link>https://forum.magicmirror.builders/post/77304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77304</guid><dc:creator><![CDATA[adrian.k]]></dc:creator><pubDate>Fri, 19 Jun 2020 07:01:41 GMT</pubDate></item><item><title><![CDATA[Reply to Customized frames for MM on Fri, 19 Jun 2020 00:26:22 GMT]]></title><description><![CDATA[<p dir="auto">You may have luck checking with the local school shop class and/or technical college. People learning how to use the tools can easily make the frame for a monitor. I’m not familiar with Norway’s educational system, but someone has to make furniture and they have to learn somewhere. Find them.</p>
]]></description><link>https://forum.magicmirror.builders/post/77281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77281</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 19 Jun 2020 00:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Customized frames for MM on Fri, 19 Jun 2020 00:06:40 GMT]]></title><description><![CDATA[<p dir="auto">@adrian-k are there any wood working groups near you?  that might make one for you?  or metal working,  or…</p>
]]></description><link>https://forum.magicmirror.builders/post/77280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77280</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 19 Jun 2020 00:06:40 GMT</pubDate></item></channel></rss>
