<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newbie Problem! Custom.CSS with Pi Zero W]]></title><description><![CDATA[<p dir="auto">Hey there!</p>
<p dir="auto">This is my first dip into MM and I’ve got it set up on my Pi Zero W, but I want to play around with sizing and other custom css things. After searching for a while I can’t seem to find any way to get into the custom css file? I’ve been trying to get into it through my ssh by trying to sudo nano /MagicMirror/css/custom.css, but it can’t find the file?</p>
<p dir="auto">I figure I’m being stupid in some way so was trying to figure this out by myself, but ended up giving in and asking the forums. Can anyone help me out?</p>
<p dir="auto">Cheers!</p>
<p dir="auto">Elliot</p>
]]></description><link>https://forum.magicmirror.builders/topic/13113/newbie-problem-custom-css-with-pi-zero-w</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:47:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13113.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Jun 2020 14:41:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newbie Problem! Custom.CSS with Pi Zero W on Sun, 21 Jun 2020 19:23:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elliotexplicit" aria-label="Profile: Elliotexplicit">@<bdi>Elliotexplicit</bdi></a> if u did the manual install  the file is not created<br />
so u have to create it yourself  (my scripted install DOES create the file for you, see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a>)</p>
]]></description><link>https://forum.magicmirror.builders/post/77352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77352</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Jun 2020 19:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie Problem! Custom.CSS with Pi Zero W on Sat, 20 Jun 2020 15:30:37 GMT]]></title><description><![CDATA[<p dir="auto">Use Bitvise SSH Client - its free and allows you to see the contents of the SD Card - you can then open the Magic Mirror folders on the RHS (remote files) and you can edit custom and main css using Notepad++ (again free download)</p>
]]></description><link>https://forum.magicmirror.builders/post/77350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77350</guid><dc:creator><![CDATA[Bromley47]]></dc:creator><pubDate>Sat, 20 Jun 2020 15:30:37 GMT</pubDate></item></channel></rss>
