<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleMapsTraffic : black screen by copying the code in config.js]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I copied the file described in the link <a href="https://github.com/vicmora/MMM-GoogleMapsTraffic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/vicmora/MMM-GoogleMapsTraffic</a> in my config.js but since I have a black screen on MM, I can’t find the error …<br />
if I remove the part:</p>
<pre><code>var config = { modules: [
<p dir="auto">it’s the same problem</p>
<p dir="auto">here is my config.js:</p>
<pre><code>.....
						title: "Le Monde, Culture",
						url: "https://www.lemonde.fr/culture/rss_full.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true,
	var config = {
            module: 'MMM-GoogleMapsTraffic',
            position: 'top_left',
                key: 'AIzaSyBQ.....',
                lat: 49.182863,
                lng: -0.370679,
                height: '300px',
                width: '300px'
                styledMapType: "transparent",
                disableDefaultUI: true,
                backgroundColor: 'hsla(0, 0%, 0%, 0)',
                markers: [
                        lat: 49.182863,
                        lng: -0.370679,
                        fillColor: '#9966ff'
			disabled: false,
			module: "MMM-Climacell-Hourly",
<p dir="auto">Thanks you for your help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13151/mmm-googlemapstraffic-black-screen-by-copying-the-code-in-config-js</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:43:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13151.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 Jun 2020 07:02:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 14:46:35 GMT]]></title><description><![CDATA[<p dir="auto">that’s it the module finally appears but new bug … the map appears and immediately after a “problem” screen appears … Pfff</p>
]]></description><link>https://forum.magicmirror.builders/post/77765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77765</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 14:46:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 14:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1593353091636-2020-06-28-155930_1920x1080_scrot.png" alt="2020-06-28-155930_1920x1080_scrot.png" class="img-markdown  img-fluid" /><br />
<img src="/assets/uploads/files/1593353104254-2020-06-28-155938_1920x1080_scrot.png" alt="2020-06-28-155938_1920x1080_scrot.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/77763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77763</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 14:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 14:04:15 GMT]]></title><description><![CDATA[<pre><code>	{
            position: 'top_right',
                key: 'AIzaSyBQnp-WYA1IdK9sZr0lfvrtUcQ5Qu02sNw',
                lat: 49.182863,
                lng: -0.370679,
                height: '300px',
                width: '300px',
                markers: [
                        lat: 49.182863,
                        lng: -0.370679,
]]></description><link>https://forum.magicmirror.builders/post/77762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77762</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 14:04:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 14:02:15 GMT]]></title><description><![CDATA[<p dir="auto">ça y’est le module s’affiche enfin mais nouveau bug… la carte s’affiche et aussitot après un écran “problem” s’affiche… Pfff<br />
this the config.js modified :<br />
{<br />
module: ‘MMM-GoogleMapsTraffic’,<br />
position: ‘top_right’,<br />
config: {<br />
key: ‘AIzaSyBQnp-WYA1IdK9sZr0lfvrtUcQ5Qu02sNw’,<br />
lat: 49.182863,<br />
lng: -0.370679,<br />
height: ‘300px’,<br />
width: ‘300px’,<br />
styledMapType: “transparent”,<br />
disableDefaultUI: true,<br />
backgroundColor: ‘hsla(0, 0%, 0%, 0)’,<br />
markers: [<br />
{<br />
fillColor: ‘#9966ff’<br />
}<br />
]<br />
}</p>
<p dir="auto">},</p>
]]></description><link>https://forum.magicmirror.builders/post/77761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77761</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 14:02:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 13:42:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> thats why I suggested the link on modules for beginners, you have too many braces {} and brackets []</p>
<p dir="auto">just cutting and pasting what the author gives you is trouble if you don’t understand what ytou are supposed to do</p>
<p dir="auto">module entries no not HAVE to have a trailing , (comma)  UNLESS there are more entries after</p>
<p dir="auto">and showing the module in that whole list is bad, cause people just copy… and boom you have TWO config entries and two module lists… not good…</p>
]]></description><link>https://forum.magicmirror.builders/post/77758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77758</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 28 Jun 2020 13:42:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 13:23:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> the last thing you said was</p>
<pre><code>modified, but still the same problem …
<pre><code>"take out the addtional stuff u added ", I added nothing…
<p dir="auto">you added a new module definition (that is additional stuff)</p>
<p dir="auto">repo, the site on github is a repository, repo for short</p>
<p dir="auto">the original u are trying to use is<br />
<a href="https://github.com/vicmora/MMM-GoogleMapsTraffic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/vicmora/MMM-GoogleMapsTraffic</a></p>
<p dir="auto">mine is<br />
<a href="https://github.com/sdetweil/MMM-GoogleMapsTraffic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-GoogleMapsTraffic</a></p>
<p dir="auto">note that the userids are different.</p>
<p dir="auto">so, instead of git cloning vic’s repo, do that with mine (instead)</p>
]]></description><link>https://forum.magicmirror.builders/post/77756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77756</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 28 Jun 2020 13:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 13:20:18 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1593350417193-2020-06-28-150831_1080x1920_scrot.png" alt="2020-06-28-150831_1080x1920_scrot.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/77755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77755</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 13:20:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 13:16:15 GMT]]></title><description><![CDATA[<p dir="auto">II have read the post : <a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121</a></p>
<p dir="auto">I don’t anderstand what you say : "take out the addtional stuff u added ", I added nothing…<br />
And I d’ont anderstand what is your “repo instead”,</p>
<p dir="auto">and this my config.js, I had already installed modules where I had encountered the problem of} and not}, but there everything seems good, I do not see the error … :</p>
]]></description><link>https://forum.magicmirror.builders/post/77754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77754</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 13:16:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 11:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a>  also, the GoogleMapsTraffic module has a bug, which I fixed, but th e author has not taken,</p>
<p dir="auto">you can use my repo instead of the original<br />
]]></description><link>https://forum.magicmirror.builders/post/77751</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77751</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 28 Jun 2020 11:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 11:37:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> <a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121</a><br />
take out the addtional stuff u added and read the above post and try again</p>
]]></description><link>https://forum.magicmirror.builders/post/77750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77750</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 28 Jun 2020 11:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 09:28:58 GMT]]></title><description><![CDATA[<p dir="auto">modified, but still the same problem …</p>
<pre><code>				broadcastNewsFeeds: true,
                lat: 49.182863,
                lng: -0.370679,
                height: '300px',
                width: '300px',
                markers: [
                        lat: 49.182863,
                        lng: -0.370679,
<p dir="auto">![0_1593336531621_2020-06-28-112809_1920x1080_scrot.png](Uploading 100%)</p>
]]></description><link>https://forum.magicmirror.builders/post/77748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77748</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 09:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 09:20:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> said in <a href="/post/77739">MMM-GoogleMapsTraffic : black screen by copying the code in config.js</a>:</p>
<p dir="auto">width: ‘300px’</p>
<p dir="auto">I think you missed a comma at the end of that line.</p>
]]></description><link>https://forum.magicmirror.builders/post/77747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77747</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Sun, 28 Jun 2020 09:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 07:24:41 GMT]]></title><description><![CDATA[<p dir="auto">it’s the same problem… :</p>
<pre><code>...
                lat: 49.182863,
                lng: -0.370679,
                height: '300px',
                width: '300px'
                markers: [
                        lat: 49.182863,
                        lng: -0.370679,
<p dir="auto"><img src="/assets/uploads/files/1593329070162-2020-06-28-092405_1920x1080_scrot.png" alt="2020-06-28-092405_1920x1080_scrot.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/77739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77739</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 28 Jun 2020 07:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic : black screen by copying the code in config.js on Sun, 28 Jun 2020 07:05:28 GMT]]></title><description><![CDATA[<p dir="auto">They included too much in their config sample. If you have a backup of your old config, back out and redo it, with this sample instead.</p>
<pre><code>  {
                key: 'YOUR_KEY',
                lat: 37.8262306,
                lng: -122.2920096,
                height: '300px',
                width: '300px'
                markers: [
                        lat: 37.8262316,
                        lng: -122.2920196,
]]></description><link>https://forum.magicmirror.builders/post/77738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77738</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 28 Jun 2020 07:05:28 GMT</pubDate></item></channel></rss>
