<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM v2.1 update with iframe]]></title><description><![CDATA[<p dir="auto">Hi. I just updated MM and it works pretty well. However…<br />
I have my MM in a Virtual Machine and have a own local website that acceess the MM with iframe, but can’t get it to work.</p>
<p dir="auto">I can access the MM through chrome direct IP but when it access through the website, it doesn’t work. I have whitelisted the whole network (192.168.X.X)<br />
im no pro at this so, any help will do.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1317/mm-v2-1-update-with-iframe</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 03:58:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1317.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Jan 2017 07:08:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM v2.1 update with iframe on Wed, 25 Mar 2020 12:49:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gshimself" aria-label="Profile: gshimself">@<bdi>gshimself</bdi></a><br />
<strong>Yes!</strong> I’ve been working on this for about 3 days now, and I never came across this page! Instantly solved my issue!</p>
<p dir="auto">One small change though. I commented out line: “<code>res.setHeader(‘X-Frame-Options’, headerValue)</code>”, in the file at: “<code>/MagicMirror/node_modules/frameguard/dist/index.js</code>”.</p>
<p dir="auto">Still it was your post that solved my issue.<br />
Thanks so much! :thumbs_up: :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/71109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71109</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 25 Mar 2020 12:49:26 GMT</pubDate></item><item><title><![CDATA[Reply to MM v2.1 update with iframe on Mon, 02 Jan 2017 09:23:44 GMT]]></title><description><![CDATA[<p dir="auto">I’ve sovled it.<br />
You have to edit /MagicMirror/node_modules/frameguard$/index.js and comment the line<br />
<em>“//    res.setHeader(‘X-Frame-Options’, directive)”</em></p>
]]></description><link>https://forum.magicmirror.builders/post/10186</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10186</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Mon, 02 Jan 2017 09:23:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM v2.1 update with iframe on Mon, 02 Jan 2017 08:29:24 GMT]]></title><description><![CDATA[<p dir="auto">After some googlesearch I’ve discoverd that now you can’t iFrame MM in chrome due to X-frame-options on the page.<br />
Is there a way to bypass this through MM or is it just time to revert to MM 2.0 again?</p>
<p dir="auto"><em>EDIT</em> Narrowed it down to that I must change the X-Frame-Options in the MM… I think.</p>
]]></description><link>https://forum.magicmirror.builders/post/10184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10184</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Mon, 02 Jan 2017 08:29:24 GMT</pubDate></item></channel></rss>
