<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No numbers in analog watch face]]></title><description><![CDATA[<p dir="auto">Hi, since the update to 2.12.0 my anlog watch no longer has any numbers in the watchface.<br />
It is the default clock module. Is there a font missing?</p>
<p dir="auto">Jörg</p>
]]></description><link>https://forum.magicmirror.builders/topic/13190/no-numbers-in-analog-watch-face</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 05:48:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13190.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jul 2020 16:31:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No numbers in analog watch face on Mon, 04 Jan 2021 14:43:48 GMT]]></title><description><![CDATA[<p dir="auto">hello,<br />
ive been using Face5 for a while pretty nice ,is there a way to change it to arabic numbers ?<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/86718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86718</guid><dc:creator><![CDATA[hayman]]></dc:creator><pubDate>Mon, 04 Jan 2021 14:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Wed, 09 Sep 2020 01:17:56 GMT]]></title><description><![CDATA[<p dir="auto">OK. That did it! Ran the update, now at version 2.13.0-develop<br />
Changed the clock back to analog with face-010  and it is looking like I want it!<br />
Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  !!</p>
]]></description><link>https://forum.magicmirror.builders/post/81484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81484</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Wed, 09 Sep 2020 01:17:56 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Wed, 09 Sep 2020 00:59:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> yes u can copy the originals back.</p>
<p dir="auto">never edit them, use the config.js to change the config.</p>
<p dir="auto">git diff &gt; somefile</p>
<p dir="auto">will show u the changes into somefile</p>
<p dir="auto">u can erase the package-lock.json file</p>
]]></description><link>https://forum.magicmirror.builders/post/81483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81483</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Sep 2020 00:59:38 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Wed, 09 Sep 2020 00:40:50 GMT]]></title><description><![CDATA[<p dir="auto">I edited the clock.js to change the default clock from digital to analog.<br />
Not sure about the weatherforcast.js though. I did make a copy of the files before editing anything. Could I just rename the backup file to the regular one and try the update again?</p>
]]></description><link>https://forum.magicmirror.builders/post/81482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81482</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Wed, 09 Sep 2020 00:40:50 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Tue, 08 Sep 2020 23:08:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> do u remember why you edited the clock and weatherforecast files?</p>
]]></description><link>https://forum.magicmirror.builders/post/81480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81480</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Sep 2020 23:08:19 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Tue, 08 Sep 2020 22:25:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78135">No numbers in analog watch face</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> interesting, my script tries to minimize space used, so only downloads the master branch<br />
to down develop do</p>
<pre><code>git fetch origin develop:develop
git checkout develop
<p dir="auto">I am probably doing something wrong.</p>
<p dir="auto">I typed in “git fetch origin develop:develop” and then “git checkout develop” and got an error.</p>
<pre><code>git checkout develop
error: Your local changes to the following files would be overwritten by checkout:
	modules/default/clock/clock.js
	modules/default/weatherforecast/weatherforecast.js
	package-lock.json
Please commit your changes or stash them before you switch branches.
Aborting
]]></description><link>https://forum.magicmirror.builders/post/81479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81479</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Tue, 08 Sep 2020 22:25:15 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 26 Jul 2020 01:02:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ice-cream" aria-label="Profile: Ice-cream">@<bdi>Ice-cream</bdi></a> do not edit the default files.</p>
<p dir="auto">config in config.js and css in custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/79157</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79157</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jul 2020 01:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 26 Jul 2020 00:32:20 GMT]]></title><description><![CDATA[<ol>
<li>Haha thanks guys - that worked!</li>
</ol>
<p dir="auto">Very good point in regard to ‘‘how you update the code if you don’t know to create custom.css?’’- I previouly edited the config.js, clock.js and clock_styles.css  &gt; I created a really pretty analog clock with the centre, second hand, minute and hour each with different colours.</p>
<ol start="3">
<li>For some reason I thought that a custom.css was really technical but I easily created this from my terminal.</li>
</ol>
<p dir="auto">For what it’s worth, I’ve connected to a few APIs and have configued these in the main confg folder and the css’s.</p>
<p dir="auto">Going forward I’m going to play with customising the default modules (well the ones which I haven’t hidden in the  main config file) in the custom CSS.</p>
<p dir="auto">Thanks again Xx</p>
]]></description><link>https://forum.magicmirror.builders/post/79151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79151</guid><dc:creator><![CDATA[Ice-cream]]></dc:creator><pubDate>Sun, 26 Jul 2020 00:32:20 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sat, 25 Jul 2020 12:04:19 GMT]]></title><description><![CDATA[<p dir="auto">@hango if one uses my installer script, I create the empty custom.css as part of the install.</p>
]]></description><link>https://forum.magicmirror.builders/post/79132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79132</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Jul 2020 12:04:19 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sat, 25 Jul 2020 07:02:40 GMT]]></title><description><![CDATA[<p dir="auto">@hango Thanks Hango.</p>
<ol>
<li>I have updated the code (still not working presumably because of point 3 below)</li>
<li>I don’t know where to download the old SVG faces - when I installed MM there was/is a folder full of SVG clock faces</li>
<li>Please don’t laugh - I don’t know how to create/use a custom css folder - I plan to learn this soon! X</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/79125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79125</guid><dc:creator><![CDATA[Ice-cream]]></dc:creator><pubDate>Sat, 25 Jul 2020 07:02:40 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Mon, 20 Jul 2020 11:01:54 GMT]]></title><description><![CDATA[<p dir="auto">@hango Hi again, I’ve modified my script but it isn’t working:</p>
<p dir="auto">.clockCircle {<br />
margin: 0 auto;<br />
position: relative;<br />
border-radius: 50%;<br />
background-size: 100%;<br />
background: transparent /home/pi/MagicMirror/modules/default/clock/faces(“faces/face-005.svg”) center no-repeat;<br />
}</p>
<p dir="auto">In this context, is url an actual url or my fie path? x</p>
]]></description><link>https://forum.magicmirror.builders/post/78902</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78902</guid><dc:creator><![CDATA[Ice-cream]]></dc:creator><pubDate>Mon, 20 Jul 2020 11:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 12 Jul 2020 20:15:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78135">No numbers in analog watch face</a>:</p>
<p dir="auto">git checkout develop</p>
<p dir="auto">that works. thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/78384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78384</guid><dc:creator><![CDATA[nagaculun]]></dc:creator><pubDate>Sun, 12 Jul 2020 20:15:28 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Mon, 06 Jul 2020 09:35:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> interesting, my script tries to minimize space used, so only downloads the master branch<br />
]]></description><link>https://forum.magicmirror.builders/post/78135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78135</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 06 Jul 2020 09:35:58 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Mon, 06 Jul 2020 07:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nagaculun" aria-label="Profile: nagaculun">@<bdi>nagaculun</bdi></a> Odd.<br />
I have the same error message and</p>
git branch -a
<p dir="auto">do not show the develop branch on remote</p>
<p dir="auto"><code>git checkout -b develop origin/develop</code> gives a fatal error:</p>
<pre><code>fatal: Cannot update paths and switch to branch 'develop' at the same time.
Did you intend to checkout 'origin/develop' which can not be resolved as commit?
<p dir="auto">Haven’t seen this before.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> have not used your install script</p>
]]></description><link>https://forum.magicmirror.builders/post/78128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78128</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 06 Jul 2020 07:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 05 Jul 2020 19:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nagaculun" aria-label="Profile: nagaculun">@<bdi>nagaculun</bdi></a> did u use my install script?</p>
]]></description><link>https://forum.magicmirror.builders/post/78111</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78111</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Jul 2020 19:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 05 Jul 2020 19:00:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> said in <a href="/post/78080">No numbers in analog watch face</a>:</p>
<p dir="auto">git checkout develop &amp;&amp; git pull</p>
<p dir="auto">I got error</p>
<pre><code>pi@MM:~/MagicMirror $ git checkout develop
error: pathspec 'develop' did not match any file(s) known to git
pi@MM:~/MagicMirror $ git pull
Already up to date.
pi@MM:~/MagicMirror $ git status
On branch master
Your branch is up to date with 'origin/master'.
Untracked files:
<p dir="auto">What should I do next ?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/78110</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78110</guid><dc:creator><![CDATA[nagaculun]]></dc:creator><pubDate>Sun, 05 Jul 2020 19:00:39 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 05 Jul 2020 11:50:17 GMT]]></title><description><![CDATA[<p dir="auto">I just merged a fix into the develop branch. That should fix it.</p>
<pre><code>git checkout develop &amp;&amp; git pull
]]></description><link>https://forum.magicmirror.builders/post/78080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78080</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 05 Jul 2020 11:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to No numbers in analog watch face on Sun, 05 Jul 2020 07:24:22 GMT]]></title><description><![CDATA[<p dir="auto">Thats it, it works, thank you :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/78076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78076</guid><dc:creator><![CDATA[JoeFranz]]></dc:creator><pubDate>Sun, 05 Jul 2020 07:24:22 GMT</pubDate></item></channel></rss>
