<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[startup]]></title><description><![CDATA[<p dir="auto">hi,my mm has been running ok but unable to download updates.read that github was needed so did so or thought i had,now mirror will not open<br />
when i boot am asked for raspberry login tried pi ok but cant input p/word raspberry<br />
can anyone tell me where i have gone wrong<br />
cheers</p>
]]></description><link>https://forum.magicmirror.builders/topic/13194/startup</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 10:57:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13194.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jul 2020 10:35:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to startup on Tue, 07 Jul 2020 15:27:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> when u boot your pi, do you see the temples on the background? using raspian buster) or do you see a black screen with a command prompt</p>
]]></description><link>https://forum.magicmirror.builders/post/78189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78189</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jul 2020 15:27:39 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Tue, 07 Jul 2020 14:55:09 GMT]]></title><description><![CDATA[<p dir="auto">sorry but i have no idea what any of that is</p>
]]></description><link>https://forum.magicmirror.builders/post/78187</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78187</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Tue, 07 Jul 2020 14:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Tue, 07 Jul 2020 12:41:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> are u running in text mode? CLI</p>
<p dir="auto">you must have a graphical desktop</p>
<p dir="auto">if that is ok, display:0 is the physical display, do u have one attached?</p>
]]></description><link>https://forum.magicmirror.builders/post/78171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78171</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jul 2020 12:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Tue, 07 Jul 2020 12:35:23 GMT]]></title><description><![CDATA[<p dir="auto">hi,your command gives a no such file or directory<br />
when i try to start get   llectron2214 Gtk-warning cannot open display :0<br />
npm err codeelifecycle<br />
npm errmagicmirror@2.9.0 start: 'sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
npm errexit status 1<br />
err failed atthe magicmirror@2.9.0 start script<br />
npm errthis is not a problem with npm there is likely additional logging output above<br />
err a complete log of this run can be found in<br />
npm err /home/pi/.nmp/_logs/2020-07-02t19_18_26_6512-debug.log<br />
hope this makes<br />
cheers, geo</p>
]]></description><link>https://forum.magicmirror.builders/post/78168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78168</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Tue, 07 Jul 2020 12:35:23 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Sat, 04 Jul 2020 16:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> I’ll be 69 next week. don’t let it stop you. my install script will make fast work of getting running</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/78060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78060</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Jul 2020 16:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Sat, 04 Jul 2020 15:25:41 GMT]]></title><description><![CDATA[<p dir="auto">hi thx for the reply altho to start again is not something i could consider because of my lack of knowledge and the time it took me to get the mm up and running.<br />
i think my age,i’m 80, makes a daunting project.<br />
thx again for your input.<br />
regards,<br />
geo</p>
]]></description><link>https://forum.magicmirror.builders/post/78058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78058</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sat, 04 Jul 2020 15:25:41 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Sat, 04 Jul 2020 12:20:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> don’t know what that means. I’m guessing you may have to rebuild the SD card and start over</p>
]]></description><link>https://forum.magicmirror.builders/post/78051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78051</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Jul 2020 12:20:23 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Sat, 04 Jul 2020 10:08:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> also this appears init version 2.93 booting<br />
raspbian gnu/linux 10 raspberrypi.tty1</p>
]]></description><link>https://forum.magicmirror.builders/post/78050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78050</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sat, 04 Jul 2020 10:08:52 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Fri, 03 Jul 2020 11:53:25 GMT]]></title><description><![CDATA[<p dir="auto">hi i am asked for plword etc at boot but still dont get to homepage.i do get a stream of info headed by raspbian GNU/Linux 10raspberrypi tty1.<br />
i thought i had loaded something to do with github cant remember what and then got in to this mess.cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/77986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77986</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Fri, 03 Jul 2020 11:53:25 GMT</pubDate></item><item><title><![CDATA[Reply to startup on Fri, 03 Jul 2020 11:29:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> did u change the password?</p>
<p dir="auto">tell me more about unable to download updates and then did something</p>
]]></description><link>https://forum.magicmirror.builders/post/77981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77981</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Jul 2020 11:29:52 GMT</pubDate></item></channel></rss>
