<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After update WARNING! Could not load config file.]]></title><description><![CDATA[<p dir="auto"><strong>I use sdetweil pi0 script and i upgrade with his script. but after i update mm i got error here is my log and config file.</strong><br />
Log</p>
<pre><code>0|MagicMir | [2020-07-12 23:06:47.162] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
0|MagicMir | was compiled against a different Node.js version using
0|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
0|MagicMir | NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
0|MagicMir | [2020-07-12 23:06:47.332] [ERROR]  Whoops! There was an uncaught exception...
0|MagicMir | [2020-07-12 23:06:47.340] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
0|MagicMir |     at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
0|MagicMir |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings/bindings.js:112:48)
0|MagicMir |     at module.exports (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:7:31)
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:15:3)
0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
0|MagicMir | [2020-07-12 23:06:47.381] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [2020-07-12 23:06:47.383] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|MagicMir | [2020-07-12 23:09:02.052] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
0|MagicMir | [2020-07-12 23:09:02.222] [ERROR]  Whoops! There was an uncaught exception...
0|MagicMir | [2020-07-12 23:09:02.229] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
0|MagicMir | [2020-07-12 23:09:02.288] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [2020-07-12 23:09:02.293] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
/home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
0|MagicMir | [2020-07-12 23:06:46.926] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:06:46.936] [LOG] Module helper loaded: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:06:47.172] [LOG] Loading module helpers ...
0|MagicMir | [2020-07-12 23:06:47.181] [LOG] No helper found for module: alert.
0|MagicMir | [2020-07-12 23:06:47.194] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:06:47.203] [LOG] Module helper loaded: updatenotification
0|MagicMir | [2020-07-12 23:06:47.211] [LOG] No helper found for module: clock.
0|MagicMir | [2020-07-12 23:06:47.220] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:06:47.227] [LOG] Module helper loaded: calendar
0|MagicMir | [2020-07-12 23:06:47.237] [LOG] No helper found for module: currentweather.
0|MagicMir | [2020-07-12 23:06:47.249] [LOG] No helper found for module: weatherforecast.
0|MagicMir | [2020-07-12 23:06:47.256] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:06:47.262] [LOG] Module helper loaded: newsfeed
0|MagicMir | [2020-07-12 23:06:47.271] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:06:47.280] [LOG] Module helper loaded: MMM-MyPrayerTimes
0|MagicMir | Starting chromium browser now, have patience, it takes a minute
0|MagicMir |
0|MagicMir | &gt; magicmirror@2.12.0 start /home/pi/MagicMirror
0|MagicMir | &gt; ./run-start.sh $1
0|MagicMir |
0|MagicMir | [2020-07-12 23:08:56.716] [LOG] Starting MagicMirror: v2.12.0
0|MagicMir | [2020-07-12 23:08:56.843] [LOG] Loading config ...
0|MagicMir | [2020-07-12 23:08:56.888] [LOG] Loading module helpers ...
0|MagicMir | [2020-07-12 23:08:56.909] [LOG] No helper found for module: alert.
0|MagicMir | [2020-07-12 23:08:57.343] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:08:57.353] [LOG] Module helper loaded: updatenotification
0|MagicMir | [2020-07-12 23:08:57.365] [LOG] No helper found for module: clock.
0|MagicMir | [2020-07-12 23:09:01.433] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:01.441] [LOG] Module helper loaded: calendar
0|MagicMir | [2020-07-12 23:09:01.454] [LOG] No helper found for module: currentweather.
0|MagicMir | [2020-07-12 23:09:01.462] [LOG] No helper found for module: weatherforecast.
0|MagicMir | [2020-07-12 23:09:01.776] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:01.785] [LOG] Module helper loaded: newsfeed
0|MagicMir | [2020-07-12 23:09:01.815] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:01.824] [LOG] Module helper loaded: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:09:02.060] [LOG] Loading module helpers ...
0|MagicMir | [2020-07-12 23:09:02.074] [LOG] No helper found for module: alert.
0|MagicMir | [2020-07-12 23:09:02.083] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:02.092] [LOG] Module helper loaded: updatenotification
0|MagicMir | [2020-07-12 23:09:02.101] [LOG] No helper found for module: clock.
0|MagicMir | [2020-07-12 23:09:02.110] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:02.117] [LOG] Module helper loaded: calendar
0|MagicMir | [2020-07-12 23:09:02.127] [LOG] No helper found for module: currentweather.
0|MagicMir | [2020-07-12 23:09:02.136] [LOG] No helper found for module: weatherforecast.
0|MagicMir | [2020-07-12 23:09:02.149] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:02.156] [LOG] Module helper loaded: newsfeed
0|MagicMir | [2020-07-12 23:09:02.162] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:09:02.170] [LOG] Module helper loaded: MMM-MyPrayerTimes
0|MagicMir |
0|MagicMir |
0|MagicMir | [2020-07-12 23:11:30.385] [LOG] Starting MagicMirror: v2.12.0
0|MagicMir | [2020-07-12 23:11:30.529] [LOG] Loading config ...
0|MagicMir | [2020-07-12 23:11:30.577] [LOG] Loading module helpers ...
0|MagicMir | [2020-07-12 23:11:30.596] [LOG] No helper found for module: alert.
0|MagicMir | [2020-07-12 23:11:31.031] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:11:31.041] [LOG] Module helper loaded: updatenotification
0|MagicMir | [2020-07-12 23:11:31.052] [LOG] No helper found for module: clock.
0|MagicMir | [2020-07-12 23:11:35.076] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:11:35.085] [LOG] Module helper loaded: calendar
0|MagicMir | [2020-07-12 23:11:35.095] [LOG] No helper found for module: currentweather.
0|MagicMir | [2020-07-12 23:11:35.105] [LOG] No helper found for module: weatherforecast.
0|MagicMir | [2020-07-12 23:11:35.423] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:11:35.431] [LOG] Module helper loaded: newsfeed
0|MagicMir | [2020-07-12 23:11:35.461] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:11:35.471] [LOG] Module helper loaded: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:11:35.494] [LOG] Initializing new module helper ...
0|MagicMir | [2020-07-12 23:11:35.516] [LOG] All module helpers loaded.
0|MagicMir | [2020-07-12 23:11:36.464] [LOG] Starting server on port 8080 ...
0|MagicMir | [2020-07-12 23:11:36.583] [LOG] Server started ...
0|MagicMir | [2020-07-12 23:11:36.598] [LOG] Connecting socket for: updatenotification
0|MagicMir | [2020-07-12 23:11:36.610] [LOG] Connecting socket for: calendar
0|MagicMir | [2020-07-12 23:11:36.621] [LOG] Starting node helper for: calendar
0|MagicMir | [2020-07-12 23:11:36.634] [LOG] Connecting socket for: newsfeed
0|MagicMir | [2020-07-12 23:11:36.645] [LOG] Starting node helper for: newsfeed
0|MagicMir | [2020-07-12 23:11:36.655] [LOG] Connecting socket for: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:11:36.663] [LOG] Starting node_helper for: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:11:36.694] [LOG] Sockets connected &amp; modules started ...
0|MagicMir | [2020-07-12 23:11:36.703] [LOG]
0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
0|MagicMir | [2020-07-12 23:12:53.342] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
0|MagicMir | [2020-07-12 23:13:00.472] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
0|MagicMir | [2020-07-12 23:13:01.012] [LOG]    Create new news fetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
0|MagicMir | [2020-07-12 23:13:02.017] [LOG]    Create new news fetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
0|MagicMir | [2020-07-12 23:13:11.411] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
0|MagicMir | [2020-07-12 23:13:21.911] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
0|MagicMir | [2020-07-12 23:13:22.391] [INFO]   Checking git for module: MMM-MyPrayerTimes
0|MagicMir | [2020-07-12 23:13:23.143] [INFO]   Checking git for module: MMM-LICE
0|MagicMir | [2020-07-12 23:13:24.001] [LOG]    200[object Object]
0|MagicMir | [2020-07-12 23:17:48.646] [LOG]    Use existing calendar fetcher for url: x
0|MagicMir | [2020-07-12 23:17:48.653] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
0|MagicMir | [2020-07-12 23:17:49.895] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
0|MagicMir | [2020-07-12 23:18:15.530] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
0|MagicMir | [2020-07-12 23:18:27.760] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
<p dir="auto">My config:</p>
 * MIT Licensed.
var config = {
	address: "0.0.0.0", // Address to listen on, can be:
	port: 8080,
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/255"], // Set [] to allow all IP addresses
	language: "tr",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			disabled: false,
			module: "updatenotification",
			disabled: false,
			position: "top_bar"
			module: "clock",
			disabled: false,
			position: "top_left"
			disabled: false,
			header: "Takvimim Ve Ozel Gunler",
						symbol: "calendar-plus-o",
						url: "x"
			module: "currentweather",
			disabled: false,
				locationID: "306569",
				appid: "x"
			module: "weatherforecast",
			disabled: false,
			header: "Hava Durumu",
				appid: "x"
			module: "newsfeed",
			disabled: false,
			position: "bottom_center",
				feeds: [
						title: "CNN Türk",
						url: "https://www.cnnturk.com/feed/rss/turkiye/news"
						title: "BirGun",
						url: "https://www.birgun.net/xml/rss.xml"
				showSourceTitle: true,
				showPublishDate: true
		  module: 'MMM-MyPrayerTimes',
		  position: 'top_center',
		  header: 'Namaz Vakitleri',
			module: "MMM-PIR",
				sensorPin: 24,
				delay: 300000,
				turnOffDisplay: true,
				showCountdown: false,
				callbackScripts: []
]]></description><link>https://forum.magicmirror.builders/topic/13256/after-update-warning-could-not-load-config-file</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 17:09:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13256.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jul 2020 20:23:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:08:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> awesome, thanks for hanging in there with me…</p>
]]></description><link>https://forum.magicmirror.builders/post/78501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78501</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:08:17 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:07:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78499">After update WARNING! Could not load config file.</a>:</p>
<p dir="auto">t</p>
<p dir="auto">yep its is working thx</p>
]]></description><link>https://forum.magicmirror.builders/post/78500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78500</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:05:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> and after all that weather should show more than 2 days</p>
]]></description><link>https://forum.magicmirror.builders/post/78499</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78499</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:05:48 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:05:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i did restarting mm.</p>
]]></description><link>https://forum.magicmirror.builders/post/78498</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78498</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:05:11 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:03:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> yeh, always something…<br />
execute the two git commands</p>
<p dir="auto">in the script I do this</p>
<pre><code> git config --global user.name "upgrade_script"
 git config --global user.email "script@upgrade.com"
<p dir="auto">then resume the prior commands at git stash</p>
]]></description><link>https://forum.magicmirror.builders/post/78497</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78497</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:03:46 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 18:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1594749264730-18b7adfb-e2b0-454e-a2f8-a8d8714809e9-image.png" alt="18b7adfb-e2b0-454e-a2f8-a8d8714809e9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/78496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78496</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 18:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 17:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> yes</p>
]]></description><link>https://forum.magicmirror.builders/post/78493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78493</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 17:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 17:52:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> in mm folder right?</p>
]]></description><link>https://forum.magicmirror.builders/post/78492</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78492</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 17:52:50 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 17:52:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a><br />
do</p>
<pre><code># remove tracked file, un-needed
rm package-lock.json
# save the package.json changes
git stash
# switch to the other branch
git checkout develop
# restore the package.json file
git stash pop
<p dir="auto">restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/78491</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78491</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 17:52:35 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 17:49:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1594748989457-2e5899db-9c1a-4f06-a725-e8e4b9316c61-image.png" alt="2e5899db-9c1a-4f06-a725-e8e4b9316c61-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/78490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78490</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 17:49:53 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 17:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> 2 days, bug, switch to develop branch</p>
<pre><code>cd ~/MagicMirror
git fetch origin develop:develop
<p dir="auto">then restart MM</p>
]]></description><link>https://forum.magicmirror.builders/post/78486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78486</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 17:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 16:52:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I already did and my relay is not working i was pissed of so much.<br />
i need to unbuilt my mirror :(<br />
and my weather forecast shows 2 day<br />
<img src="/assets/uploads/files/1594745534610-9f1e6456-8c62-4df0-8d58-4bef1c17093e-image.png" alt="9f1e6456-8c62-4df0-8d58-4bef1c17093e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/78482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78482</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 16:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 16:44:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> man what a pain,</p>
<p dir="auto">ok, delete the module folder (MMM-PIR) and then reclone and npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/78479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78479</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 16:44:30 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 12:37:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Not working</p>
]]></description><link>https://forum.magicmirror.builders/post/78451</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78451</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 12:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Tue, 14 Jul 2020 08:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok</p>
]]></description><link>https://forum.magicmirror.builders/post/78442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78442</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Tue, 14 Jul 2020 08:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Mon, 13 Jul 2020 17:36:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> what a mess.</p>
<p dir="auto">so. now I think u need to erase module folder and then reinstall module. the two back recovery mechanisms don’t work</p>
]]></description><link>https://forum.magicmirror.builders/post/78413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78413</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jul 2020 17:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Mon, 13 Jul 2020 15:04:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>0|MagicMir | [2020-07-13 18:04:01.849] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:11:18)
0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
0|MagicMir |     at loadModule (/home/pi/MagicMirror/js/app.js:124:17)
0|MagicMir |     at loadNextModule (/home/pi/MagicMirror/js/app.js:158:5)
0|MagicMir | [2020-07-13 18:04:02.059] [ERROR]  Whoops! There was an uncaught exception...
0|MagicMir | [2020-07-13 18:04:02.071] [ERROR]  ReferenceError: NodeHelper is not defined
0|MagicMir | [2020-07-13 18:04:02.143] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [2020-07-13 18:04:02.145] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
<p dir="auto">Same</p>
]]></description><link>https://forum.magicmirror.builders/post/78405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78405</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Mon, 13 Jul 2020 15:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Mon, 13 Jul 2020 14:57:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm rebuild
&gt; epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
&gt; node-gyp rebuild
make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epol        l/build'
 CXX(target) Release/obj.target/epoll/src/epoll.o
 SOLINK_MODULE(target) Release/obj.target/epoll.node
 COPY Release/epoll.node
make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll        /build'
child_process@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/child_proc        ess
electron-rebuild@1.11.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/electr        on-rebuild
colors@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/colors
debug@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/debug
ms@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ms
detect-libc@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/detect-libc
fs-extra@8.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-extra
graceful-fs@4.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/graceful-fs
jsonfile@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsonfile
universalify@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/universalif        y
node-abi@2.18.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-abi
semver@5.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/semver
node-gyp@6.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-gyp
env-paths@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/env-paths
glob@7.1.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/glob
fs.realpath@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs.realpath
inflight@1.0.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inflight
once@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/once
wrappy@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrappy
inherits@2.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inherits
minimatch@3.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimatch
brace-expansion@1.1.11 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/brace-e        xpansion
balanced-match@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/balanced-        match
concat-map@0.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/concat-map
path-is-absolute@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-is        -absolute
mkdirp@0.5.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mkdirp
minimist@1.2.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimist
nopt@4.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nopt
abbrev@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/abbrev
osenv@0.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/osenv
os-homedir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-homedir
os-tmpdir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-tmpdir
npmlog@4.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/npmlog
are-we-there-yet@1.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/are-we-        there-yet
delegates@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delegates
readable-stream@2.3.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/readable        -stream
core-util-is@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/core-util-i        s
isarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isarray
process-nextick-args@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/pro        cess-nextick-args
safe-buffer@5.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safe-buffer
string_decoder@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string_de        coder
util-deprecate@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/util-depr        ecate
console-control-strings@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        console-control-strings
gauge@2.7.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/gauge
aproba@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aproba
has-unicode@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-unicode
object-assign@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/object-ass        ign
signal-exit@3.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/signal-exit
string-width@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string-widt        h
code-point-at@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/code-point        -at
is-fullwidth-code-point@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        is-fullwidth-code-point
number-is-nan@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/number-is-        nan
strip-ansi@3.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/strip-ansi
ansi-regex@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-regex
wide-align@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wide-align
set-blocking@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/set-blockin        g
request@2.88.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/request
aws-sign2@0.7.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws-sign2
aws4@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws4
caseless@0.12.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/caseless
combined-stream@1.0.8 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/combined        -stream
delayed-stream@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delayed-s        tream
extend@3.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extend
forever-agent@0.6.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/forever-ag        ent
form-data@2.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/form-data
asynckit@0.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asynckit
mime-types@2.1.27 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-types
mime-db@1.44.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-db
har-validator@5.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-valida        tor
ajv@6.12.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ajv
fast-deep-equal@3.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fast-dee        p-equal
fast-json-stable-stringify@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modul        es/fast-json-stable-stringify
json-schema-traverse@0.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jso        n-schema-traverse
uri-js@4.2.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uri-js
punycode@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/punycode
har-schema@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-schema
http-signature@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/http-sign        ature
assert-plus@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/assert-plus
jsprim@1.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsprim
extsprintf@1.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extsprintf
json-schema@0.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json-schema
verror@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/verror
sshpk@1.16.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/sshpk
asn1@0.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asn1
safer-buffer@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safer-buffe        r
bcrypt-pbkdf@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bcrypt-pbkd        f
tweetnacl@0.14.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tweetnacl
dashdash@1.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/dashdash
ecc-jsbn@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ecc-jsbn
jsbn@0.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsbn
getpass@0.1.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/getpass
is-typedarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/is-typedar        ray
isstream@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isstream
json-stringify-safe@5.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json        -stringify-safe
oauth-sign@0.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/oauth-sign
performance-now@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/performa        nce-now
qs@6.5.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/qs
tough-cookie@2.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tough-cooki        e
psl@1.8.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/psl
tunnel-agent@0.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tunnel-agen        t
uuid@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uuid
rimraf@2.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rimraf
tar@4.4.13 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tar
chownr@1.1.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chownr
fs-minipass@1.2.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-minipass
minipass@2.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minipass
yallist@3.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yallist
minizlib@1.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minizlib
which@1.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which
isexe@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isexe
ora@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora
chalk@2.4.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chalk
ansi-styles@3.2.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-styles
color-convert@1.9.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-conv        ert
color-name@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-name
escape-string-regexp@1.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/esc        ape-string-regexp
supports-color@5.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/supports-        color
has-flag@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-flag
cli-cursor@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-cursor
restore-cursor@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/restore-c        ursor
onetime@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onetime
mimic-fn@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mimic-fn
cli-spinners@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-spinner        s
log-symbols@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/log-symbols
strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/strip-ansi
ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/ansi-regex
wcwidth@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wcwidth
defaults@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/defaults
clone@1.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/clone
spawn-rx@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx
debug@2.6.9 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modu        les/debug
ms@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modules        /ms
lodash.assign@4.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/lodash.ass        ign
rxjs@6.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rxjs
tslib@1.13.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tslib
yargs@14.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs
cliui@5.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui
string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_        modules/string-width
emoji-regex@7.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/emoji-regex
is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        cliui/node_modules/is-fullwidth-code-point
strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/strip-ansi
ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/ansi-regex
wrap-ansi@5.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi
string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/n        ode_modules/string-width
is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        wrap-ansi/node_modules/is-fullwidth-code-point
strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/strip-ansi
ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/ansi-regex
decamelize@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/decamelize
find-up@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/find-up
locate-path@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/locate-path
p-locate@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-locate
p-limit@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-limit
p-try@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-try
path-exists@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-exists
get-caller-file@2.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/get-call        er-file
require-directory@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/requir        e-directory
require-main-filename@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/re        quire-main-filename
string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_        modules/string-width
is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        yargs/node_modules/is-fullwidth-code-point
strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/strip-ansi
ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/ansi-regex
which-module@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which-modul        e
y18n@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/y18n
yargs-parser@15.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs-pars        er
camelcase@5.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/camelcase
onoff@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff
epoll@2.0.10 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
bindings@1.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings
file-uri-to-path@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/file-ur        i-to-path
nan@2.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nan
]]></description><link>https://forum.magicmirror.builders/post/78404</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78404</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Mon, 13 Jul 2020 14:57:05 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 22:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> any progress?</p>
]]></description><link>https://forum.magicmirror.builders/post/78394</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78394</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jul 2020 22:59:22 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 21:37:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> sorry, dumb of me to take  u down the electron path when u don’t have electron.</p>
<pre><code>cd ~/MagicMirror/modules/MMM-PIR
npm rebuild
]]></description><link>https://forum.magicmirror.builders/post/78393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78393</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jul 2020 21:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 21:29:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78387">After update WARNING! Could not load config file.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> thanks for posting… another troublesome module</p>
<p dir="auto">do</p>
npm install electron-rebuild
cd modules/MMM-PIR
~/MagicMirror/node_modules/.bin/electron-rebuild
pm2 flush
<p dir="auto">then restart your MM</p>
<p dir="auto">let me know</p>
<p dir="auto"><img src="/assets/uploads/files/1594589346741-ff1f5692-adb9-4dfa-b10c-e9a45e333d3e-image.png" alt="ff1f5692-adb9-4dfa-b10c-e9a45e333d3e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/78392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78392</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sun, 12 Jul 2020 21:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 21:26:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78387">After update WARNING! Could not load config file.</a>:</p>
cd modules/MMM-PIR
pm2 flush
<p dir="auto">i got error but i cant share my log cause of “Post content was flagged as spam by <a href="http://Akismet.com" target="_blank" rel="noopener noreferrer nofollow ugc">Akismet.com</a>” error in npm install electron-rebuild</p>
]]></description><link>https://forum.magicmirror.builders/post/78391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78391</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sun, 12 Jul 2020 21:26:30 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 21:12:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I was trying out of desperation</p>
]]></description><link>https://forum.magicmirror.builders/post/78390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78390</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sun, 12 Jul 2020 21:12:25 GMT</pubDate></item><item><title><![CDATA[Reply to After update WARNING! Could not load config file. on Sun, 12 Jul 2020 21:09:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> no problem… didn’t need to reinstall module</p>
]]></description><link>https://forum.magicmirror.builders/post/78389</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78389</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jul 2020 21:09:03 GMT</pubDate></item></channel></rss>
