<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM GoogleAssistant mv client_secret_XXX.json credentials.json]]></title><description><![CDATA[<p dir="auto">hey</p>
<p dir="auto">when i follow the installation guide i try to do</p>
<pre><code>cd ~/MagicMirror/modules/MMM-GoogleAssistant
<p dir="auto">but he tel me : <em>No such file or folder</em></p>
<p dir="auto">and when i start my magic mirror the google assitant telle me : <em>not finding token.json</em></p>
<p dir="auto">maybe someone have an idea.</p>
<p dir="auto">thanks you for this amazing modules of course and for your answer 😃</p>
]]></description><link>https://forum.magicmirror.builders/topic/13259/mmm-googleassistant-mv-client_secret_xxx-json-credentials-json</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 15:59:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13259.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jul 2020 19:43:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 23:47:26 GMT]]></title><description><![CDATA[<p dir="auto">Hey thanks you this step is done</p>
<p dir="auto">but know im lost when i write the line</p>
node auth_and_test.js
<p dir="auto">i got this error</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ node auth_and_test.js
/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/components/auth.js:27
  const oauthClient = new OAuth2(key.client_id, key.client_secret, key.redirect_uris[0]);
TypeError: Cannot read property 'client_id' of undefined
    at new Auth (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/components/auth.js:27:38)
    at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/index.js:21:16)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:60:19)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    at startup (internal/bootstrap/node.js:283:19)
<p dir="auto">thank you again for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/78431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78431</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 23:47:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 23:15:03 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1594682101468-capture-d-e-cran-2020-07-14-a-01.14.39.png" alt="Capture d’écran 2020-07-14 à 01.14.39.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/78429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78429</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 23:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 22:54:53 GMT]]></title><description><![CDATA[<p dir="auto">honestly i think this is in my credentials :</p>
<pre><code>{"web":{"client_id":"109652145873-5nkqrfro300pe1pi6r5gd0v9sutdolmm.apps.googleusercontent.com","project_id":"smart-mirrorr-b3d55","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"hYgsFML7eyHnsy7HClmmUSzR","redirect_uris":["https://smart-mirrorr-b3d55.firebaseapp.com/__/auth/handler"],"javascript_origins":["http://localhost","http://localhost:5000","https://smart-mirrorr-b3d55.firebaseapp.com"]}}
]]></description><link>https://forum.magicmirror.builders/post/78428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78428</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 22:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 20:12:15 GMT]]></title><description><![CDATA[<p dir="auto">did u download the correct credentials?</p>
<p dir="auto">I would go recheck that step of the instructions… it worked for me when I did it</p>
]]></description><link>https://forum.magicmirror.builders/post/78424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78424</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jul 2020 20:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 20:10:53 GMT]]></title><description><![CDATA[<p dir="auto">but after</p>
]]></description><link>https://forum.magicmirror.builders/post/78423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78423</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 20:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 20:03:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wirdman" aria-label="Profile: wirdman">@<bdi>wirdman</bdi></a> said in <a href="/post/78421">MMM GoogleAssistant mv client_secret_XXX.json credentials.json</a>:</p>
<p dir="auto">credentials.json</p>
<p dir="auto">already in assistant folder</p>
]]></description><link>https://forum.magicmirror.builders/post/78422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78422</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jul 2020 20:03:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 20:01:58 GMT]]></title><description><![CDATA[<p dir="auto">nothing in download</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ ls *.json -laF
-rw-r--r-- 1 pi pi   546 jui 13 21:29 credentials.json
-rw-r--r-- 1 pi pi   132 jui 13 20:06 deviceInstance.sample.json
-rw-r--r-- 1 pi pi  1610 jui 13 20:06 package.json
-rw-r--r-- 1 pi pi 79267 jui 13 20:49 package-lock.json
]]></description><link>https://forum.magicmirror.builders/post/78421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78421</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 20:01:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 19:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wirdman" aria-label="Profile: wirdman">@<bdi>wirdman</bdi></a> is it in this google assistant folder or still in Downloads?</p>
ls *.json -laF
<p dir="auto">and</p>
<pre><code>cd ~/Downloads
ls *.json -laF
]]></description><link>https://forum.magicmirror.builders/post/78420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78420</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jul 2020 19:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 19:56:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/78418">MMM GoogleAssistant mv client_secret_XXX.json credentials.json</a>:</p>
<p dir="auto">you downloaded a file from google, yes?  credentials, yes</p>
<p dir="auto">yes i do but and i put it in MMM-GoogleAssistant</p>
<p dir="auto">and now i try do this command line</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ mv code_secret_client_109652145873-5nkqrfro300pe1pi6r5gd0v9sutdolmm.apps.googleusercontent.com.json crendentials.json
mv: impossible d'évaluer 'code_secret_client_109652145873-5nkqrfro300pe1pi6r5gd0v9sutdolmm.apps.googleusercontent.com.json': Aucun fichier ou dossier de ce type
]]></description><link>https://forum.magicmirror.builders/post/78419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78419</guid><dc:creator><![CDATA[wirdman]]></dc:creator><pubDate>Mon, 13 Jul 2020 19:56:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM GoogleAssistant mv client_secret_XXX.json credentials.json on Mon, 13 Jul 2020 19:45:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wirdman" aria-label="Profile: wirdman">@<bdi>wirdman</bdi></a> said in <a href="/post/78417">MMM GoogleAssistant mv client_secret_XXX.json credentials.json</a>:</p>
<p dir="auto">client_secret_XXX.json</p>
<p dir="auto">you downloaded a file from google, yes?  credentials, yes?</p>
<p dir="auto">where do files that are downloaded go ?  (same as on windows)  the Downloads folder</p>
]]></description><link>https://forum.magicmirror.builders/post/78418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78418</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jul 2020 19:45:12 GMT</pubDate></item></channel></rss>
