<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[installing mm]]></title><description><![CDATA[<p dir="auto">hi just installed new raspian on pi3 and no problems.however when i tried to auto install mm it failed and message line 404 missing,<br />
can anyone help.<br />
cheers,geo</p>
]]></description><link>https://forum.magicmirror.builders/topic/13270/installing-mm</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 13:38:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13270.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jul 2020 19:06:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 21:23:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> I understand the words, but don’t understand why you have this problem. I tested 2.12 on buster a couple weeks ago, again.</p>
]]></description><link>https://forum.magicmirror.builders/post/78879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78879</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Jul 2020 21:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 19:17:34 GMT]]></title><description><![CDATA[<p dir="auto">debian stretch v 9.11.tried to install buster several times and failed.messages unmet depedencies,and try,apt – fixbroken install<br />
hope this makes sense</p>
]]></description><link>https://forum.magicmirror.builders/post/78876</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78876</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sun, 19 Jul 2020 19:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 12:00:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> we’ve all been there, patience.</p>
]]></description><link>https://forum.magicmirror.builders/post/78860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78860</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Jul 2020 12:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 11:57:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> hi again, yes i realise that its more to do with my frustration and lack of understanding.</p>
]]></description><link>https://forum.magicmirror.builders/post/78859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78859</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sun, 19 Jul 2020 11:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 11:41:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> can u please try with buster, stretch is too old</p>
]]></description><link>https://forum.magicmirror.builders/post/78858</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78858</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 19 Jul 2020 11:41:16 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 10:00:26 GMT]]></title><description><![CDATA[<p dir="auto">nstall starting  - Wed Jul 15 11:26:24 BST 2020<br />
installing on armv7l processor system<br />
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretc$<br />
^&lsqb;&lsqb;96mUpdating packages …^&lsqb;&lsqb;90m<br />
Get:1 <a href="http://raspbian.raspberrypi.org/raspbian" target="_blank" rel="noopener noreferrer nofollow ugc">http://raspbian.raspberrypi.org/raspbian</a> stretch InRelease [15.0 kB] Hit:$<br />
apt-get update  completed ok<br />
apt-get upgrade  started<br />
apt upgrade result =rc=100 Reading package lists…<br />
Building dependency tree…<br />
Reading state information…<br />
You might want to run ‘apt --fix-broken install’ to correct these.<br />
The following packages have unmet dependencies:<br />
apt-utils : Depends: apt (= 1.4.8) but 1.4.10 is installed<br />
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or spec$<br />
^&lsqb;&lsqb;96mInstalling helper tools …^&lsqb;&lsqb;90m<br />
build-essential is already the newest version (12.3).<br />
[ Read 415 lines ]<br />
^G Get Help  ^O Write Out ^W Where Is  ^K Cut Text  ^J Justify   ^C Cur Pos<br />
^X Exit      ^R Read File ^\ Replace   ^U Uncut Text^T To Spell  ^_ Go To Line</p>
]]></description><link>https://forum.magicmirror.builders/post/78846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78846</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sun, 19 Jul 2020 10:00:26 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sun, 19 Jul 2020 01:58:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> said in <a href="/post/78743">installing mm</a>:</p>
<p dir="auto">i am at a loss as to what to do next other than to sell everything.</p>
<p dir="auto">It may take a little time and a few attempts but follow <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s directions and he will help you get it running.</p>
]]></description><link>https://forum.magicmirror.builders/post/78839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78839</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 19 Jul 2020 01:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sat, 18 Jul 2020 15:54:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> so, it still makes no sense</p>
<p dir="auto">you open a terminal window, ctrl-alt-t, and the install.log should be right there</p>
<p dir="auto">u have to edit it,<br />
nano install.log<br />
or type it<br />
cat install.log</p>
]]></description><link>https://forum.magicmirror.builders/post/78771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78771</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Jul 2020 15:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sat, 18 Jul 2020 15:49:38 GMT]]></title><description><![CDATA[<p dir="auto">hi i loaded the  mm from your script</p>
]]></description><link>https://forum.magicmirror.builders/post/78769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78769</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sat, 18 Jul 2020 15:49:38 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sat, 18 Jul 2020 12:04:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> are you running MagicMirrorOS?   and not the raw MagicMirror app on raspian?</p>
<p dir="auto">you did NOT use sudo when u ran the install, correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/78749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78749</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Jul 2020 12:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Sat, 18 Jul 2020 09:34:21 GMT]]></title><description><![CDATA[<p dir="auto">hi thx for that.<br />
i now have mm installed as per your instructions i can open the config and everything else but still cant get the mm display.you asked to see the install log but permission was denied.<br />
i am finding it difficult to understand why matters seem more complicated which makes everything more daunting especially after having an up and running mm which was ruined by me installing out of date info.<br />
i am at a loss as to what to do next other than to sell everything.<br />
regards,<br />
geo</p>
]]></description><link>https://forum.magicmirror.builders/post/78743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78743</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Sat, 18 Jul 2020 09:34:21 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Fri, 17 Jul 2020 14:20:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> &gt;would still like to know why the original command did not work.</p>
<p dir="auto">because u copied some old instructions.<br />
the install scripts were removed 2 releases ago, because they require constant updating, which the project felt was not in the core mission of MagicMirror.</p>
<p dir="auto">I have taken over maintenance and updates for the scripts, and this is mentioned on the project GitHub site, as alternative install methods<br />
see after<br />
<a href="https://docs.magicmirror.builders/getting-started/installation.html#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/installation.html#manual-installation</a></p>
]]></description><link>https://forum.magicmirror.builders/post/78687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78687</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jul 2020 14:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Fri, 17 Jul 2020 12:14:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> I don’t understand.</p>
<p dir="auto">to start mm after install, you navigate to the MagicMirror folder and execute npm start</p>
<pre><code>cd ~/MagicMirror
npm start
]]></description><link>https://forum.magicmirror.builders/post/78683</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78683</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jul 2020 12:14:31 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Fri, 17 Jul 2020 11:38:05 GMT]]></title><description><![CDATA[<p dir="auto">hi,finally got my numb brain partially working and installed scripts,easy when you know how,thankyou.now how do i open mm cos npm start does not work.<br />
would still like to know why the original command did not work.thx again,geocd MgicMirror<br />
hi when i tried to find the install.log file permission was denied</p>
]]></description><link>https://forum.magicmirror.builders/post/78682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78682</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Fri, 17 Jul 2020 11:38:05 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Thu, 16 Jul 2020 15:29:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> show me the ~/install.log file</p>
<p dir="auto">something is missing</p>
]]></description><link>https://forum.magicmirror.builders/post/78630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78630</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jul 2020 15:29:09 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Thu, 16 Jul 2020 15:08:15 GMT]]></title><description><![CDATA[<p dir="auto">npm start command not found</p>
]]></description><link>https://forum.magicmirror.builders/post/78629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78629</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Thu, 16 Jul 2020 15:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Thu, 16 Jul 2020 15:05:09 GMT]]></title><description><![CDATA[<p dir="auto">hi yes i havs done that but how do i  open the mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/78627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78627</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Thu, 16 Jul 2020 15:05:09 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Thu, 16 Jul 2020 11:46:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> you don’t install the scripts… u execute one line</p>
<p dir="auto">to install you copy/paste this line</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
<p dir="auto">which will execute the install process</p>
]]></description><link>https://forum.magicmirror.builders/post/78600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78600</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jul 2020 11:46:35 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Thu, 16 Jul 2020 11:00:38 GMT]]></title><description><![CDATA[<p dir="auto">hi installed the scripts but cant open the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/78598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78598</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Thu, 16 Jul 2020 11:00:38 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Tue, 14 Jul 2020 22:24:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> open an ssh session from your pc to pi.</p>
<p dir="auto">or slow way, open a browser on pi, and terminal window, and copy. paste that way</p>
]]></description><link>https://forum.magicmirror.builders/post/78525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78525</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 22:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Tue, 14 Jul 2020 22:21:27 GMT]]></title><description><![CDATA[<p dir="auto">hi thx for that but as i have said before i have no idea how to copy and paste from pi<br />
geo</p>
]]></description><link>https://forum.magicmirror.builders/post/78523</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78523</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Tue, 14 Jul 2020 22:21:27 GMT</pubDate></item><item><title><![CDATA[Reply to installing mm on Tue, 14 Jul 2020 19:24:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> did u use my install script?  all scripts have been removed from base repo<br />
use the install script from here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/78505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78505</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Jul 2020 19:24:00 GMT</pubDate></item></channel></rss>
