<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror Boot loop...]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Sorry for my english…<br />
But my MM reboot again and again.</p>
<pre><code>~/MagicMirror/installers $ sh mm.sh
&gt; magicmirror@2.12.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
/home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: |ibffi.so.6: cannot open shared object file: No such file or directory
npm ERR! code ELIFECYCLE
npm ERR! syscall spawn
npm ERR! file sh
npm ERR! errno ENOENT
npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
npm ERR! spawn ENOENT
npm ERR!
npm ERR! Failed at the magicmirror@2.12.0 start script.
npm ERR!     /home/pi/.npm/_logs/2020-07-15T20_28_46_768Z-debug.log
<p dir="auto"><strong>/home/pi/.npm/_logs/2020-07-15T20_28_46_768Z-debug.log</strong></p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@6.14.5
3 info using node@v10.20.1
5 info lifecycle magicmirror@2.12.0~prestart: magicmirror@2.12.0
6 info lifecycle magicmirror@2.12.0~start: magicmirror@2.12.0
7 verbose lifecycle magicmirror@2.12.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_module$
9 verbose lifecycle magicmirror@2.12.0~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.12.0~start: Args: [ '-c',
10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
11 info lifecycle magicmirror@2.12.0~start: Failed to exec start script
12 verbose stack Error: magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
12 verbose stack spawn ENOENT
12 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
12 verbose stack     at ChildProcess.emit (events.js:198:13)
12 verbose stack     at maybeClose (internal/child_process.js:982:16)
12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
13 verbose pkgid magicmirror@2.12.0
14 verbose cwd /home/pi/MagicMirror
15 verbose Linux 4.19.97-v7+
16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
17 verbose node v10.20.1
18 verbose npm  v6.14.5
19 error code ELIFECYCLE
20 error syscall spawn
21 error file sh
22 error errno ENOENT
23 error magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
23 error spawn ENOENT
24 error Failed at the magicmirror@2.12.0 start script.
24 error This is probably not a problem with npm. There is likely additional logging output above.
25 verbose exit [ 1, true ]
<p dir="auto">Thanks a lot in advance</p>
<p dir="auto">I have try : npm rebuild / npm install</p>
]]></description><link>https://forum.magicmirror.builders/topic/13281/magicmirror-boot-loop</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 21:20:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13281.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jul 2020 20:30:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror Boot loop... on Thu, 16 Jul 2020 00:50:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ok thx you for this information</p>
]]></description><link>https://forum.magicmirror.builders/post/78583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78583</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Thu, 16 Jul 2020 00:50:51 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Boot loop... on Thu, 16 Jul 2020 00:28:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> yeh, so I would start w a new sd card. never seen one recover</p>
]]></description><link>https://forum.magicmirror.builders/post/78581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78581</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jul 2020 00:28:30 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Boot loop... on Wed, 15 Jul 2020 23:52:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi !<br />
Thx for your interest.</p>
<pre><code>sudo apt-get update
sudo apt-get install libffi-dev
<p dir="auto">Nothing… same error</p>
]]></description><link>https://forum.magicmirror.builders/post/78577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78577</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Wed, 15 Jul 2020 23:52:42 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Boot loop... on Wed, 15 Jul 2020 23:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> try this… make a backup of you MM config.js</p>
<p dir="auto">then try to restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/78576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78576</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 15 Jul 2020 23:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Boot loop... on Wed, 15 Jul 2020 22:42:04 GMT]]></title><description><![CDATA[<p dir="auto">Recently.<br />
Three months ago.</p>
]]></description><link>https://forum.magicmirror.builders/post/78571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78571</guid><dc:creator><![CDATA[thymon]]></dc:creator><pubDate>Wed, 15 Jul 2020 22:42:04 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Boot loop... on Wed, 15 Jul 2020 21:16:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thymon" aria-label="Profile: thymon">@<bdi>thymon</bdi></a> how long has mm been installed?</p>
<p dir="auto">this looks like an SD card corruption</p>
<pre><code>
/home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: ***|ibffi.so.6***: cannot open shared object file:
]]></description><link>https://forum.magicmirror.builders/post/78569</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78569</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 15 Jul 2020 21:16:56 GMT</pubDate></item></channel></rss>
