<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror fails to be started via SSH console]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I installed MagicMirror according the guide from github. MagicMirror can be started without problems from the GUI terminal. But it fails to start if I am not using the GUI but a SSH console connection instead.</p>
<p dir="auto">Here is the command to start MagicMirror and the resulting error message.</p>
<pre><code>user@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
&gt; magicmirror@2.1.0 start /home/user/MagicMirror
&gt; electron js/electron.js
npm ERR! Linux 4.4.38-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
npm ERR! node v6.9.2
npm ERR! npm  v4.0.5
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     electron js/electron.js
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
npm ERR!     /home/user/MagicMirror/npm-debug.log
<p dir="auto">Here you find the log file mentioned in the error message: <a href="https://gist.githubusercontent.com/wewa00/c61b27dc4991e94ccc78880e25afaa89/raw/f94ec26139a7afd47add78fdc8c92b56cd45d103/npm-debug.log" target="_blank" rel="noopener noreferrer nofollow ugc">https://gist.githubusercontent.com/wewa00/c61b27dc4991e94ccc78880e25afaa89/raw/f94ec26139a7afd47add78fdc8c92b56cd45d103/npm-debug.log</a><br />
How can I get MagicMirror started from SSH console?</p>
<p dir="auto">Regards, wewa00</p>
]]></description><link>https://forum.magicmirror.builders/topic/1330/magicmirror-fails-to-be-started-via-ssh-console</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 12:18:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1330.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Jan 2017 16:59:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror fails to be started via SSH console on Mon, 16 Jan 2017 20:38:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wewa00" aria-label="Profile: wewa00">@<bdi>wewa00</bdi></a> Have you tried enable auto login?<br />
Can be configured with raspi-config.</p>
]]></description><link>https://forum.magicmirror.builders/post/11302</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11302</guid><dc:creator><![CDATA[jag]]></dc:creator><pubDate>Mon, 16 Jan 2017 20:38:23 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror fails to be started via SSH console on Mon, 16 Jan 2017 19:31:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello jag,</p>
<p dir="auto">my Raspberry is configured for Desktop boot (without Autologin). During boot I see the text console for some seconds but then I see the MagicMirror splash screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/11296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11296</guid><dc:creator><![CDATA[wewa00]]></dc:creator><pubDate>Mon, 16 Jan 2017 19:31:44 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror fails to be started via SSH console on Tue, 03 Jan 2017 20:06:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wewa00" aria-label="Profile: wewa00">@<bdi>wewa00</bdi></a> what do you see on your display before starting up?<br />
(Text console or graphical)</p>
]]></description><link>https://forum.magicmirror.builders/post/10353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10353</guid><dc:creator><![CDATA[jag]]></dc:creator><pubDate>Tue, 03 Jan 2017 20:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror fails to be started via SSH console on Tue, 03 Jan 2017 17:56:34 GMT]]></title><description><![CDATA[<p dir="auto">See here: <a href="https://github.com/MichMich/MagicMirror#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror#manual-installation</a></p>
<p dir="auto">Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start &amp; instead. This starts the mirror on the remote display.</p>
<p dir="auto">And if I execute <code>DISPLAY=:0 nohup npm start &amp;</code>, I get the same error message, but logged to <code>nohup.out</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/10346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10346</guid><dc:creator><![CDATA[wewa00]]></dc:creator><pubDate>Tue, 03 Jan 2017 17:56:34 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror fails to be started via SSH console on Tue, 03 Jan 2017 17:21:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wewa00" aria-label="Profile: wewa00">@<bdi>wewa00</bdi></a></p>
<p dir="auto">Shouldn’t Display=:0 come after npm start?</p>
]]></description><link>https://forum.magicmirror.builders/post/10343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10343</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 03 Jan 2017 17:21:19 GMT</pubDate></item></channel></rss>
